LIKE2LOOP(at)aol.com Guest
Posted: Mon Jul 17, 2006 7:18 pm Post subject: Oshkosh Subaru Engine Specials |
In a message dated 7/17/06 9:57 pm, bob.kaufmann(at)cox.net writes:
<< I will easily get 280 horsepower from the engine and will burn a little
more gas. I'll burn .50 lbs per horsepower instead on .42. >>
Is that fuel consumption number estimated or from a flying plane? I
drive a Mazda RX-8 and the gas milage sucks!!! Between 14-18mpg with one
165# driver and NO heavy loads. The EPA says I should get 18/24 (but they don't
test drive the cars, they estmate) NO Way can I get their numbers.
Driving like a granny in flat Florida, 18 mpg is the best keeping rpm below
3000. It does run smooth, and I bet TBO will be good due to very low parts
count, but the three firings per rotation eats fuell. The higher rpm the more fuel
flow x3. Just something to think about. I was thinking about how to adjust
fuel use by firing once per rev at cruise.....vs 3 times....???
Steve
Port St. Lucie, FL
772-475-5556
Sent from my Treo 600
ainut(at)hiwaay.net Guest
Posted: Mon Jul 17, 2006 9:16 pm Post subject: Oshkosh Subaru Engine Specials |
Rotaries do burn more fuel per hp than 'regular' engines. Partly due to
fuel cooling. However, one can't really compare the auto mpg to
aviation use unless you factor in the tranny and rear end losses, as
well as gearing.
David M.
LIKE2LOOP(at)aol.com wrote:
Steve
Port St. Lucie, FL
772-475-5556
jclarkmail(at)gmail.com Guest
Posted: Mon Jul 17, 2006 9:52 pm Post subject: Oshkosh Subaru Engine Specials |
You are welcome. But more so important is for someone (in this case YOU) to come back and say "thanks" to someone who (hopefully politely) questions how stuff is "put out there". To me that says way more about you than even your detailed response.
James
On 7/17/06, RV Builder (Michael Sausen) <rvbuilder(at)sausen.net (rvbuilder(at)sausen.net)> wrote: | Quote: |
James, thanks for calling BS on me BTW. I'm always happy to have someone question a statement on the list as there is waaaay too much fluff thrown around on the net. I TRY to have facts when I post as I don't like it when people point to me and say he's full of it. Of course no one is perfect and I can always rely on John, Dan, and others to point out the errors of my ways and I will always be the first to stand up and say I'm wrong. I just try to make sure it doesn't happen very often.
<<<SNIP>>>
GRANSCOTT(at)aol.com Guest
Posted: Tue Jul 18, 2006 5:26 am Post subject: Oshkosh Subaru Engine Specials |
I've not in the market place, but it seems to me that if you are taking orders on a product underdevelopment, that is; that one hopes to deliver with in a 6 month time frame, then you are not taking orders to sell your product...you are discussing how individuals can become temporary investors in your product unless your deposit money will be held in escrow by a certified escrow company such as AOPA's escrow service. If a company cashes your check it is a sale--you've become part of their cash flow system and at 50% that's probably close to the raw materials future cost. If they don't deliver a product then you are a credit holder to the company awaiting the product promised. If they go Chapter whatever in the mean time you are generally at the back of the line with all the creditors and near the rear along with raw material supplies, non-secured creditors.
I'd think 6 months is a relatively short period for a custom product but still they are not selling you a product but booking a future product...IMHO...and one should expect a healthy discount for the finance risk.
I've got a real good buddy still awaiting a Delta Hawk engine...and it's said to have been deliverable more than two years ago, and it still has not seen the light of day.
Please I'm not putting these two engine companies in the same grouping but in the aviation business there are lots of strange twist and turns.
Patrick
PS I think the opening gambit was a bit odd but I don't know the history nor "have a dog in this fight".
Posted: Tue Jul 18, 2006 5:57 am Post subject: Oshkosh Subaru Engine Specials |
Bob when you do a XC in the RV 10, how many airports will be stocking Mogas?
Patrick
Rick S.
bsponcil(at)belinblank.or Guest
Posted: Tue Jul 18, 2006 12:20 pm Post subject: Oshkosh Subaru Engine Specials |
I'd assume it doesn't really matter. Can't the cosmo be just as happy burning 100LL as MoGas? I'd think the same is true of the Subie, but perhaps I'm wrong. One of the advantages, at least as I see it, to the low compression lycosaurs (ie - the 235HP B4B5) is the ability to burn MoGas or 100LL or any combination inbetween.
-Brian
#40497
N211BD
Iowa City, IA
Rick S.
bob.kaufmann(at)cox.net Guest
Posted: Tue Jul 18, 2006 4:31 pm Post subject: Oshkosh Subaru Engine Specials |
There is always the option to put in 100 LL, but more than I first thought. The price differential of my engine will pay for a lot of 100 LL and the overhaul costs will pay for a lot more.
Bob K
The engine and finish kit
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GRANSCOTT(at)aol.com
Sent: Tuesday, July 18, 2006 5:54 AM
Subject: Re: Oshkosh Subaru Engine Specials
Patrick
dav1111(at)cox.net Guest
Posted: Tue Jul 18, 2006 4:35 pm Post subject: Oshkosh Subaru Engine Specials |
And both of them will most likely ask me for their ride home!!!
At least they better ask for a ride home or I might just leave them at some
wayward airport.
Two good guys even if they are both a little crazy.
Russ Daves
N710RV
Posted: Tue Jul 18, 2006 4:37 pm Post subject: Oshkosh Subaru Engine Specials |
And silver, Rick, its two tone. Hoping to get it all together this weekend.
All 4 major parts.
Bob K
Posted: Tue Jul 18, 2006 5:05 pm Post subject: Oshkosh Subaru Engine Specials |
Actually the real truth is I have been known to fly with the shiny side down
and some people don't like looking down to see up or visa versa. Its only a
momentary thing and lots of fun. Kind of like cloud dancing.
Bob K
dmasys(at)cox.net Guest
john.erickson(at)cox.net Guest
Posted: Tue Jul 18, 2006 6:16 pm Post subject: Oshkosh Subaru Engine Specials |
Dan Masys wrote:
| Quote: | | Quote: | --> RV10-List message posted by: Dan Masys <dmasys(at)cox.net> (dmasys(at)cox.net)
---- "bob.kaufmann" <bob.kaufmann(at)cox.net> (bob.kaufmann(at)cox.net) wrote:
| Quote: | Actually the real truth is I have been known to fly with the shiny side down
Spent my most recent BFR in the -7A with a CFI who is also a pro airshow pilot. Since I was IFR current, he said 'let's just do some stick and rudder flying' and we spent most of the hour aloft polishing the fine technique for aileron rolls. I already know I'm gonna miss that a little when the -10 eventually takes the place of the -7. Shiny side down for a bit is way fun. Are we sure you can't roll a -10? Aileron and barrel rolls are both 1G manuvers...
Just kidding (I think )
-Dan Masys
40448 | | Actually Dan ...... just about anything can be rolled. Â In a -10 all you need is sufficient airspeed, sufficient up angle on the nose before you start the roll, and maybe a little rudder to get the tail around. Â You're correct about a barrel roll. Â It can (and should be) a 1 G maneuver, but a good aileron roll will force you to push when inverted ....... and push a lot without a symmetrical airfoil wing ...... which puts you in negative G territory. Â I'm sure someone will roll a -10 and maybe even loop it. Â But that's an experiment that I'll leave to others. Â I'm a little older and a little wiser now.
Linn
stein(at)steinair.com Guest
Posted: Tue Jul 18, 2006 8:43 pm Post subject: Oshkosh Subaru Engine Specials |
Oh....I can say the -10 rolls just beautifully......
Cheers,
Stein.
Do Not Archive (the -10's are stricly NON aerobatic....right:)
Vern(at)teclabsinc.com Guest
Posted: Wed Jul 19, 2006 6:33 am Post subject: Oshkosh Subaru Engine Specials |
Brian,
When I was following the Subie group this question came up and it was suggested (I think by Jan) that a lead scavenger be used when burning 100LL.
Vern
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Brian Douglas
Sent: Tuesday, July 18, 2006 1:20 PM
-Brian
#40497
N211BD
Iowa City, IA
jdalton77(at)comcast.net Guest
Posted: Tue Jul 25, 2006 6:52 am Post subject: Oshkosh Subaru Engine Specials |
Innodyn's web site says they won't have a booth of their own.
Boy oh boy I WISH their engine was real . . .
Posted: Tue Jul 25, 2006 7:37 am Post subject: Oshkosh Subaru Engine Specials |
If it was and it ran on bio-diesel made from hamburger joints then you would have a ”fast food flyer!”
For those of us stuck at home; Garmin has info on their website for the G600, G900 and yes the new handheld 496.
Vern (#04324 fuel tanks)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jdalton77
Sent: Tuesday, July 25, 2006 7:48 AM
Tim(at)MyRV10.com Guest
Posted: Sat Jul 29, 2006 3:57 pm Post subject: Oshkosh Subaru Engine Specials |
I just got back from Van's booth and Innodyne today.
I've decided to build another RV-10 and this time do it
right, so I paid in full for a quickbuild -10, and paid
in full for an Innodyne system. I'm sending it to our
favorite Oklahoma -10 building professional so I should
have my completed RV-10 to fly within a few months.
(now how serious do you think I'm being?)
jdalton77 wrote:
[quote] Innodyn's web site says they won't have a booth of their own.
