LarryRosen
Posted: Wed Aug 01, 2018 5:35 pm Post subject: Baffle Tension Rod - Outboard |
Does the outboard baffle tension rod go below the oil return lines (tubing) or between the engine and the oil return lines?
Larry
Still Building
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Wed Aug 01, 2018 5:49 pm Post subject: Baffle Tension Rod - Outboard |
I think the intention is for it to go under the oil lines, but if you can get it between the oil lines and the engine without the possibility of chaffing either, then I think you’re fine.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
Sent from my iPad
Larry
Still Building
Larry Rosen
#40356
N205EN (reserved)
<http>
http://forums.matronics.com/viewtopic.php?p=482005#482005
LarryRosen
Posted: Wed Aug 01, 2018 6:02 pm Post subject: Baffle Tension Rod - Outboard |
I am struggling to get it to work either way lol.
Sent from my mobile phone
Sent: Wednesday, August 1, 2018 9:52 PM
Subject: Re: Baffle Tension Rod - Outboard
--> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com>
Jesse Saint
352-427-0285
Sent from my iPad
> --> RV10-List message posted by: "LarryRosen" <N205EN(at)gmail.com>
> Larry
> Still Building
> Larry Rosen
> #40356
> N205EN (reserved)
> <http>
#40356
N205EN (reserved)
<http> |
Kellym
Joined: 10 Jan 2006 Posts: 1705 Location: Sun Lakes AZ
Posted: Wed Aug 01, 2018 6:11 pm Post subject: Baffle Tension Rod - Outboard |
Keep in mind that there are necessary bends in the rods. BTW, if you
have trouble threading the supplied rod, #6 threads-all rod works
equally as well, providing you place some heat shrink or rubber tubing
over the threads in areas that could rub oil tubes.
*Sent:* Wednesday, August 1, 2018 9:52 PM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Baffle Tension Rod - Outboard
Jesse Saint
352-427-0285
Sent from my iPad
> Larry
> Still Building
> Larry Rosen
> #40356
> N205EN (reserved)
> <http>
KCHD |
