daberti(at)sbcglobal.net Guest
Posted: Mon Jul 30, 2018 6:51 pm Post subject: 912 ULS sudden rough running on mag check |
My engine ran fine on a local flight to a neighboring airport last week. When leaving, I had some vibration, rough running that is not characteristic to my engine. I powered up the boost pump and it seemed a little better so I continued to taxi. Just prior to the run up area I got a few more shakes so I pulled off to check under the cowling. I found nothing amiss so I continued to checklist and mag check. My A side ran fine but B dropped 150 or so then ran fine. I flew the 30 min flight home without incident and arriving at the hanger did my usual shutdown mag check. The B side shook like crazy and I could not power through the rough running. Here’s what I found.
Grounds all normal. Checking the trigger coils resistance all was normal. I took the connectors apart and established continuity to the triggers. Checked the coil primary side and one had no resistance, meaning two cylinders got no spark. I used a pin and checked the white wire near the coil and got good readings. Moved the pin 1 inch past the connector and still good. Now I removed the pin from the connector and the wire felt limp about 1/8” below the pin at the base of the connector boot. I dissected the wire with an exacto and sure enough the wire was completely broken.
I was able to repair the connection as the wire was long enough. Put it all back together and it purrs like a kitten. It actually may be smoother than it was on more recent flights so I’ll bet it was going for some time and finally gave up the ghost.
Perhaps this will help someone else if they experience similar issues.
Dave Alberti
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
FoesFlyDennis
Joined: 21 Jan 2016 Posts: 12 Location: Mesa, Arizona, USA
Posted: Tue Jul 31, 2018 8:58 am Post subject: 912 ULS sudden rough running on mag check |
Dave, Thanks for sharing your experience and trouble shooting methods.Dennis
On Mon, Jul 30, 2018, 7:55 PM Dave <daberti(at)sbcglobal.net (daberti(at)sbcglobal.net)> wrote:
Quote: | --> RotaxEngines-List message posted by: Dave <daberti(at)sbcglobal.net (daberti(at)sbcglobal.net)>
Dave Alberti
xEngines-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
FORUMS -
eferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer" target="_blank">http://wiki.matronics.com
b Site -
-Matt Dralle, List Admin.
rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution
_________________ 2012 Pulsar III - Jabiru 2200A - N852LW
DennisTubbs7@gmail.com
Mesa, Arizona |
vernon11
Posted: Tue Jul 31, 2018 11:59 pm Post subject: 912 ULS sudden rough running on mag check |
Thanks Dave.
Sent: Tuesday, July 31, 2018 6:58 PM
To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
Subject: Re: 912 ULS sudden rough running on mag check
Dave, Thanks for sharing your experience and trouble shooting methods. Dennis
Dave Alberti
FORUMS -
WIKI -
b Site -
