Rocketman1988
Posted: Tue Jul 03, 2018 6:48 pm Post subject: Battery cables |
For those who are making their own battery cables, what is the recommended crimp?
Is the indent crimp preferred of a hex crimp?
art(at)zemon.name Guest
Posted: Tue Jul 03, 2018 8:01 pm Post subject: Battery cables |
I soldered mine according to the instructions here:Â http://www.aeroelectric.com/articles/big_term.pdf
Easy and seems like I got physically sound, low resistance connections.
  -- Art Z.
On Tue, Jul 3, 2018 at 10:03 PM Rocketman1988 <Rocketman(at)etczone.com (Rocketman(at)etczone.com)> wrote:
Quote: | --> AeroElectric-List message posted by: "Rocketman1988" <Rocketman(at)etczone.com (Rocketman(at)etczone.com)>
https://CheerfulCurmudgeon.com/"We do not see the world as it is. We see the world as we are."
ronburnett(at)charter.net Guest
Posted: Wed Jul 04, 2018 2:25 am Post subject: Battery cables |
Art,I have a Harbor Freight set of hydraulic squeezers that work great for that. It has a big set of fittings for every size.
Ron Burnett
May you have the Lord's blessings today!Sent from my iPad
On Jul 3, 2018, at 11:00 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
Posted: Wed Jul 04, 2018 7:18 am Post subject: Battery cables |
At 05:24 AM 7/4/2018, you wrote:
Ron Burnett
Take a proposed 4 or 2 awg terminal with
you when you go crimp-tool shopping at HF.
I purchased one a few years ago where
the numbers stamped on the die-sets had
no practical relationship to reality.
The actual hex-holes were way to small for
the numbers in evidence.
Don't know if that's changed/improved
but it's worth checking.
When the HF hydraulic tool proved
inadequate to the job, I soldered the
terminals on . . .
Works good, lasts a long time . . .
Rocketman1988
Posted: Wed Jul 04, 2018 7:53 am Post subject: Re: Battery cables |
Bob,
That is exactly why I asked the question.
It seems as if the HF dies are the WIRE size, not the wire+connector. This makes the dies FAR too small. I have had good luck with the HF crimper on 8 and 4 AWG wire by using dies that are two sizes larger, i.e. us the #4 die on #8 wire and a #2 die on #4 wire. The crimps look as they should according to the Temco website. I did a pull test on one of the #4 cables...I clamped it in a vise an hung 270 lb from it with no movement...
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Wed Jul 04, 2018 8:30 am Post subject: Battery cables |
Agreed that the HF dies were not as indicated, especially if using welding cables but ignored the indicated numbers and used the die that gave the crimped connection that I needed.
Bob Reed
On Jul 4, 2018, at 10:17 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Quote: | At 05:24 AM 7/4/2018, you wrote:
Ron Burnett
terminals on . . .
ceengland7(at)gmail.com Guest
Posted: Wed Jul 04, 2018 8:48 am Post subject: Battery cables |
On Wed, Jul 4, 2018 at 10:17 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Ron Burnett
 terminals on . . .
I recently bought a similar (might be the same) hydraulic crimper from Jet (not the Jet Tools people; this is just a reseller of far-East stuff).
https://jet.com/product/10-Ton-Hydraulic-Wire-Battery-Cable-Lug-Terminal-Crimper-Crimping-Tool-9-Dies/044de210e0e54490b3104f2933a8c4e9
I'd suggest trying this:
https://www.andersonpower.com/_global-assets/downloads/pdf/conversion.pdf
or do a search for 'metric to AWG conversion table'.
Mine makes not perfect looking, but quite serviceable crimps using this type of conversion for the numbers stamped on the dies.
CharlieÂ
JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Wed Jul 04, 2018 9:27 am Post subject: Battery cables |
Not so much as 'no practical relationship to reality' more of 'no practical relationship to AWG', I think the numbers relate to square mm or something like that, there is a conversion guide somewhere, I'm sure it was put on here a couple of years ago
John
Sent from my iPad
----x--O--x----
On 4 Jul 2018, at 5:30 pm, Robert Reed <robertr237(at)att.net (robertr237(at)att.net)> wrote:
Quote: | Agreed that the HF dies were not as indicated, especially if using welding cables but ignored the indicated numbers and used the die that gave the crimped connection that I needed.
Bob Reed
Ron Burnett
terminals on . . .
Eric M. Jones
Posted: Fri Jul 06, 2018 9:44 am Post subject: Re: Battery cables |
Don't forget the Perihelion Design Copper-Clad Aluminum cables. They save 1/2 the weight of a copper cable.
Description: |
 Download |
Filename: |
Copper Cables.pdf |
Filesize: |
286.71 KB |
Downloaded: |
623 Time(s) |
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Fri Jul 06, 2018 11:03 am Post subject: Battery cables |
At 10:53 AM 7/4/2018, you wrote:
Quote: | --> AeroElectric-List message posted by: "Rocketman1988" <Rocketman(at)etczone.com>
Bob,
It seems as if the HF dies are the WIRE size, not the wire+connector. This makes the dies FAR too small. |
Yup . . . They've not fixed it and they've
had 10 years to do it!
Quote: | I have had good luck with the HF crimper on 8 and 4 AWG wire by using dies that are two sizes larger, i.e. us the #4 die on #8 wire and a #2 die on #4 wire. The crimps look as they should according to the Temco website. I did a pull test on one of the #4 cables...I clamped it in a vise an hung 270 lb from it with no movement... |
I've got access to CNC production . . . I've
pondered the notion of offering properly sized
dies for that tool. The hydraulics seem to be
fine . . . only the die designers are suffering
a short between the headphones.
Posted: Fri Jul 06, 2018 11:48 am Post subject: Battery cables |
On 7/6/2018 2:02 PM, Robert L. Nuckolls, III wrote:
Quote: | At 10:53 AM 7/4/2018, you wrote:
Quote: | --> AeroElectric-List message posted by: "Rocketman1988" <Rocketman(at)etczone.com> (Rocketman(at)etczone.com)
Bob,
Bob . . . | The dies are stamped for metric wire sizes. I sent a message on 7-4-18 detailing it, with a link to metric>AWG conversions. Perhaps it didn't make it through, but it's in the archives at:
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=143869992?KEYS=battery_cables?LISTNAME=AeroElectric?HITNUMBER=2?SERIAL=12445510791?SHOWBUTTONS=YES
Charlie
