RichWill
Joined: 24 Feb 2006 Posts: 24 Location: Southern Maine
Posted: Mon Jul 17, 2006 4:22 pm Post subject: Fuse Holder - Panel Mount 250v 30A ??? |
Does anyone know where I can buy a "bussmann" fuse holder as above.. Aircraft Spruce, Wicks, Leading Edge, ect ect... all have 10a or 15a , but I have not found an aircraft parts dealer or other that has the 30a for a main fuse holder...
tks
Rich
bmwebb(at)cox.net Guest
Posted: Mon Jul 17, 2006 6:30 pm Post subject: Fuse Holder - Panel Mount 250v 30A ??? |
Are you looking for a single fuse holder, or a distribution block?
Either way, try www.littelfuse.com, go to Product Type Search, go to bottom
at Automotive Aftermarket Products, and then fuse blocks, and Maxi-fuse. Pep
Boys carried these when I was looking.
Try this:
http://www.littelfuse.com/cgi-bin/r.cgi/en/prod_type_series.html?TechnologyI
D=2&Family=650&LFSESSION=ExazE8rjD3, select MAB1.
I've used these, and they're great. If not what you want, search the site,
there's tons of options.
Bradley
RichWill
Posted: Tue Jul 18, 2006 4:57 am Post subject: Re: Fuse Holder - Panel Mount 250v 30A ??? |
Bradley,
thanks good site... found just the ones..
Rich
kitfox(at)itsys3.com Guest
Posted: Tue Jul 18, 2006 6:15 am Post subject: Fuse Holder - Panel Mount 250v 30A ??? |
I used two of the bussman holders for the main and essential bus
distributions. I chose to use a single 30 amp circuit breaker to
protect the main feed.
Bill Hammond
Parker, CO
RichWill wrote:
tks
Rich
Semper Fi
15 ITT
G2 HqCo HqBn
1st MarDiv
http://forums.matronics.com/viewtopic.php?p=48062#48062
