				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| ceengland7(at)gmail.com Guest
				|  Posted: Thu Jun 07, 2018 6:22 pm    Post subject: Placement options for CHT probe |   |
				| On 6/7/2018 8:35 PM, John Fitt wrote:
 From the Lycoming world: Washer-based cht probes on the plugs always     indicate significantly higher than probes screwed into the heads.     The plug is the hottest spot in the cylinder. 	  | Quote: |  	  | Greetings from Sebastopol, CA Has           anybody used a cylinder head bolt ( immediately next to a           spark plug) instead of the probe ring
 under           the plug? I am currently using the cylinder head bolts,           wanting to eliminate the wear and tear
 on the           probe ring when checking/changing plugs. Seems that the temp.           readings are lower- maybe due to the heat lost near a fin?
 FSII           503 dcdi
 EIS           monitor
 CHT           runs around 100-120 deg
 John           Fitt
  Virus-free. www.avast.com 		 	 [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
 | |  |  | - The Matronics Kolb-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Kolb-List
		| Back to top |  |
		| rascaljohn
				|  Posted: Thu Jun 07, 2018 8:23 pm    Post subject: Placement options for CHT probe |   |
				| Thanks for the reply. Any way to save on the wear and tear?
 On Jun 7, 2018, at 7:22 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
 FSII           503 dcdi
 EIS           monitor
 John           Fitt
		| Back to top |  |
		| gdhelton(at)gmail.com Guest
				|  Posted: Fri Jun 08, 2018 7:32 am    Post subject: Placement options for CHT probe |   |
				| Your CHT seems very low. Do you have your EIS set for centigrade or Fahrenheit?The most common cause for the disfigurement of spark-plug base rings is over- torque of spark plugs. I was surprised to find out that my engine ( 40hp Hirth 2702 ) only requires 108 inch pounds ( yes, inch pounds) of torque and with the spark-plugs seal ring installed with no anti- sieze compound.
George H.
 Mesick, Michigan
 On Jun 8, 2018, at 12:23 AM, John Fitt <jpfitt(at)sbcglobal.net (jpfitt(at)sbcglobal.net)> wrote:
  	  | Quote: |  	  | Thanks for the reply. Any way to save on the wear and tear?
 FSII           503 dcdi
 EIS           monitor
 John           Fitt
		| Back to top |  |
		| racerjerry
				|  Posted: Sat Jun 09, 2018 3:18 am    Post subject: Re: Placement options for CHT probe |   |
				| Why don't you do a side-by-side test / comparison with the CHT probes in both locations on the same cylinder?   A double throw  switch temporarily wired in would give you an immediate comparison.
 Jerry King
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
