rocknpilot(at)hotmail.com Guest
Posted: Mon Jun 04, 2018 7:41 am Post subject: Air Bottle Seal |
Does anyone have the hot tip for sealing air bottles? In pulling 3 apart, I've found nylon seals, neoprene o-rings, gasket sealer, etc. The parts manual shows a nut, a washer and a "sealnig" (sic) ring. Is the washer a crush washer? My emergency bottle fills to about half capacity - then hisses until empty. I've been through the whole system and just replaced the bottle, but now am having redundant issues trying to seal it.
HELP!
Thanks!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
1969 Cessna 150J ^/---//-X
N61333 // Hangar #35 / AUW
1992 Yakovlev Yak 52 ^/---//-X
N21YK //
Hangar #21 / AUW
pennington.construction.i Guest
Posted: Mon Jun 04, 2018 8:49 am Post subject: Air Bottle Seal |
Rico
I just went through this with my CJ. Replaced the main and emergency air tanks with new stainless steel tanks. The seals I got from Doug were stainless steel threaded plugs / fittings with copper crush washers.
After three attempts to seal the inlet and outlet fittings I call Doug and he told me to use use the black gooey thread sealant sparingly on the threads.
Once I did that and let the tanks sit over night I was successful in sealing the tanks on both the inlet fittings and the drain plug. 20 hours later still holding tight.
The sealant I used was obtained from O'Reilys Auto Parts and is for aviation use. The product used is
VersaChem Prime Seal Type 3 for aviation VersaChem Part Number is 34000
Hope this helps
Mark
N621CJ
Richmond VA
On Mon, Jun 4, 2018 at 11:40 AM, Rico Jaeger <rocknpilot(at)hotmail.com (rocknpilot(at)hotmail.com)> wrote:
HELP!
Thanks!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N21YK //
Hangar #21 / AUW
jblake207(at)comcast.net Guest
Posted: Mon Jun 04, 2018 9:07 am Post subject: Air Bottle Seal |
Doug Sapp sells the brass crush washer needed. JB
| Quote: | On June 4, 2018 at 10:40 AM Rico Jaeger <rocknpilot(at)hotmail.com> wrote:
HELP!
Thanks!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N21YK //
Hangar #21 / AUW
draftsjust417(at)gmail.co Guest
Posted: Mon Jun 04, 2018 10:30 am Post subject: Air Bottle Seal |
Hey hey, so I JUST encountered the identical issue on my CJ6's emergency and main air bottles during cond insp.
I pulled the drain plugs to clean the bottles, removing non-standard lead crush washers from in the process. (They'd been there since purchase, perhaps installed by Chinese?)
After cleaning/rinsing bottles I reinstalled the plugs with PLAAF-specified copper washers.
The main bottle holds air perfectly on first try.
The emergency bottle flatly refused to hold air despite several attempts with new Cu washers... very slow leaks remained.
I finally cleaned everything with compressed air & Isopropyl alcohol, applied a high-pressure (5000 psi) PermaTex thread sealer to the drain plug threads, reinstalled w/ new Cu washer otherwise per Chinese parts manual. Once the sealant had fully set (24 hrs), it holds air 100%.
Worked for me!
Justin Drafts
N280NC
On 11:46, Mon, Jun 4, 2018 Rico Jaeger <rocknpilot(at)hotmail.com (rocknpilot(at)hotmail.com)> wrote:
HELP!
Thanks!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N21YK //
Hangar #21 / AUW
Posted: Mon Jun 04, 2018 11:54 am Post subject: Air Bottle Seal |
Thanks, Justin!! I will give it a try...
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N21YK //
Hangar #21 / AUW
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> on behalf of Justin Drafts <draftsjust417(at)gmail.com>
Sent: Monday, June 4, 2018 1:25:17 PM
To: yak-list(at)matronics.com
Subject: Re: Air Bottle Seal
Worked for me!
Justin Drafts
N280NC
HELP!
Thanks!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N21YK //
Hangar #21 / AUW
