hgmckay
Posted: Sat Apr 14, 2018 11:08 am Post subject: 912 Cylinder head coolant temperature Gauge |
I have the new cylinder heads on my 912 UL engine. I am measuring the coolant temperature using the normal Rotax (VDO) gauge. During engine operation my gauge needle is quickly fluctuating (swinging) as much as 10 to 30 degrees Celsius between zero and 80 degrees C. After landing and engine ignition circuits are cut off and the engine stopped, but with current still on the instruments (i.e. key on the “on” position the VDO gauge needle is steady at 80 degrees C. As the engine cools the needle drops. The wiring and connections from the sensors to the gauge are sound and tight. Could I have a problem with the coolant pump on the engine varying the coolant flow and thereby causing the sudden temperature variation indications on the VDO gauge? Any ideas or suggestions?
Hugh G. McKay III, P.E. Fellow, L.M. ASCE
Senior Consultant
Worldwide Engineering Inc.
4090 North NC Hwy. 16
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
email hgmckay(at)bellsouth.net
http://www.wwegeo.com
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Description: |
 Download |
Filename: |
Hugh.vcf |
Filesize: |
79 Bytes |
Downloaded: |
1066 Time(s) |
Posted: Sat Apr 14, 2018 11:17 am Post subject: 912 Cylinder head coolant temperature Gauge |
Make sure all the air has been bled out of the cooling system.
How is your coolant recovery tank behaving? Normal?
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of hgmckay(at)bellsouth.net
Sent: Saturday, April 14, 2018 2:08 PM
To: Rotax Engines
Subject: 912 Cylinder head coolant temperature Gauge
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
_________________ John Hauck
Titus, Alabama |
Posted: Sat Apr 14, 2018 12:41 pm Post subject: 912 Cylinder head coolant temperature Gauge |
I am thinking the same way John is. You have an air bubble, and is has to be burped. The other option, as always, is a loose wire.
Bill Sullivan
Tarboro, NC (recently escaped from Connecticut!)
To: "Rotax Engines" <rotaxengines-list(at)matronics.com>
Date: Saturday, April 14, 2018, 3:08 PM
measuring the
10 to 30 degrees
Ph. 704-661-8271
Fax
704-483-5466
email
johnelling
Posted: Sun Apr 15, 2018 10:12 am Post subject: 912 Cylinder head coolant temperature Gauge |
I had a problem like this and finally solved it with a resistor, 1kohm I
think, in line with the probe. It is the same fix they recommend for
the tach.
Quote: | I have the new cylinder heads on my 912 UL engine. I am measuring the
=9Con=9D position the VDO gauge needle is steady at 80
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
hgmckay
Posted: Tue Apr 17, 2018 12:27 pm Post subject: 912 Cylinder head coolant temperature Gauge |
Bill,
I know how to "burp" the oil system, but I have never heard of "burping" the
coolant system. How is that done?
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
Posted: Tue Apr 17, 2018 12:47 pm Post subject: 912 Cylinder head coolant temperature Gauge |
I have to plead ignorance on Rotax, but a number of automotive engines will hide an air bubble in the cooling system. The old Jeep 4.0 liter straight 6 was always doing that. You filled it up after working on it, and had to keep filling it for a few days until all of the air worked out of it. Maybe John Hauck knows. It used to drive me nuts, thinking I had a leak and not finding it. I would just fill it, run it, fill it, and run it over a few days, cooling off in between runs.
Bill Sullivan
On Tue, 4/17/18, <hgmckay(at)bellsouth.net> wrote:
Subject: Re: 912 Cylinder head coolant temperature Gauge
To: rotaxengines-list(at)matronics.com
Date: Tuesday, April 17, 2018, 4:27 PM
Bill,
ASCE
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
Posted: Tue Apr 17, 2018 2:59 pm Post subject: 912 Cylinder head coolant temperature Gauge |
Here is how I do it. After draining and refilling, I raise the tail higher than the nose, MKIII is a tail dragger, and back down. Top it off and rock it up and back down until I can't put any more coolant into the header tank.
I bleed air the same way you describe Bill S. Until the header tank is completely full after a flight, shut down, and cool down, I check the header tank. I keep doing this procedure until all the air is gone. Do the same thing with all my other water cooled engines to bleed air.
When all air is gone the coolant recovery tank will hit its high mark with the engine hot and suck coolant out of the coolant recovery tank as it cools. This keeps air out of the system.
Titus, Alabama |
Roger Lee
Posted: Tue Apr 17, 2018 5:22 pm Post subject: Re: 912 Cylinder head coolant temperature Gauge |
The coolant system in the 912 is an open system. The fluid seeks its own level and rarely ever needs more after filling. Because it is an open system it is also very easy to evacuate the entire tire system.
Fill and go. With all the hoses changes I do every year I never have trapped air that made a difference.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Tue Apr 17, 2018 6:28 pm Post subject: 912 Cylinder head coolant temperature Gauge |
I thought I was flying with a closed cooling system all these years. If it
has a pressure cap and coolant recovery system, I call that a closed system.
An open system would be like my old antique tractors, unpressurised and open
to the atmosphere.
I really don't know of an open system on a modern water cooled engine.
Set me straight if I am wrong. Not trying to be argumentative.
I do know the three 912 engines I have owned since 1993, all required
bleeding air and fill/top off through the header tank. There are places in
the engine that do trap air. Maybe the newer engines have different
castings.
Titus, Alabama |
Posted: Tue Apr 17, 2018 6:51 pm Post subject: 912 Cylinder head coolant temperature Gauge |
Roger Lee:
Took a quick look in the Rotax 912 Installation Manual. It describes the
cooling system as closed.
Titus, Alabama |
daberti(at)sbcglobal.net Guest
Posted: Tue Apr 17, 2018 6:54 pm Post subject: 912 Cylinder head coolant temperature Gauge |
You’re right on. And without the overflow tank with a hose submerged in coolant you will never get rid of the air.
Dave Alberti
[quote] On Apr 17, 2018, at 9:28 PM, John Hauck <jhauck(at)elmore.rr.com> wrote:
to the atmosphere.
castings.
dougsnash
Posted: Wed Apr 18, 2018 3:16 am Post subject: 912 Cylinder head coolant temperature Gauge |
Another source of temperature spikes I have found is with the absolute junk VDO gauges that tend to develop erratic needle swings as they age. I spent one summer changing out well over 1000 dollars worth of electrical components chasing "voltage spikes" on my CH-701 only to find out the problem was a bad VDO gauge. I had even tried another (albeit used) VDO voltage gauge and still had the same "spikes". Turned out it was the crap VDO volt meters and there was actually nothing wrong with my electrical system. Since then, I have been slowly converting my panel over to Stewart Warner gauges and have been happy with the results. I have an erratic oil temperature gauge right now that will be getting replaced at annual.
While I won't claim to be an expert and know very little of the OP's problem, he did mention he has a VDO gauge and I would replace that before getting to carried away chasing a potentially phantom engine problem.
Doug M
CH-701/ 912-UL
Posted: Wed Apr 18, 2018 4:31 am Post subject: 912 Cylinder head coolant temperature Gauge |
Since the early days, ultralight pilots have freaked out over instrument indications. They spent hours and lots of money, and probably destroyed lots of engines and airplanes chasing engine instruments, trying to get that two stroke engine dialed in perfectly. I think of all the other two stroke engines in my life back then that had no instrumentation. Never worried about EGT and other temps. They seemed to run forever with good fuel and oil, and a new spark plug every once in a while. Usual the problem was improper prop loading. Rotax did a good job of setting up the engines at the factory, but if the Westach instrument told them their EGT was a little high or low, they'd start chasing their tail, changing jets, needles, spark plugs, and anything else they could find to change. I was one of them.
I have a situation with my 9121ULS that irritates me. I randomly get low oil pressure and high engine oil temp indications. I was on a flight to Oregon many years ago when this first started happening. Was irritating, but proved to be harmless. It is still happening, but the temps are always reading the same, even though they are incorrect. Annoying, but not critical. BTW, they are VDO marine gauges. I can shut down the battery and the indications return to normal. Must be wiring, probably poor grounding, or the gauges.
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of MacDonald Doug
Sent: Wednesday, April 18, 2018 6:16 AM
To: RotaxEngines-List Digest Server
Doug M
CH-701/ 912-UL
Titus, Alabama |
rampil
Posted: Wed Apr 18, 2018 11:52 am Post subject: Re: 912 Cylinder head coolant temperature Gauge |
My 2 cents as an EE:
There are NO rapid temperature changes. Not physically possible.
How much energy do you think is available to heat and COOL the coolant
through wide swings.
VDO are cheap crappy mechanical gauges, emphasis on cheap crap.
Automotive or snowmobile quality, no better. I like Rotax hardware, but the
VDO garbage should be thrown away on delivery and replaced with
airworthy meters.
The temp. swings are most likely vibration induced mechanical resonances
in the needle/coil/spring system in the indicator.
