rainbow462
Posted: Wed Dec 06, 2017 8:22 am Post subject: Radio/Intercom issue - wisdom of the group sought..... |
Hi.
We have an issue where radio transmissions mute the intercom, preventing pilot/passenger comms. Once a radio message has finished the intercom is ok again. Just wondered if anyone has had something similar or has any ideas we can explore
The radio is a Funkwerk 833 and the intercom is a flightcom 403.
Many thanks
Jeremy
Burrilla
Posted: Wed Dec 06, 2017 8:34 am Post subject: Radio/Intercom issue - wisdom of the group sought..... |
Sounds like the headset audio is being routed through the auxiliary input normally used for music. Don’t know the intercom myself but the Funk has an inbuilt two place intercom and it doesn’t exhibit that effect, I have one, so must be the Flightcom 403 and either the wiring between the two or the setup.
Is it a new setup?
Alan
Sent from my iPad
Quote: | On 6 Dec 2017, at 16:22, rainbow462 <jeremy.hoyland(at)pepsico.com> wrote:
Hi.
Many thanks
Jeremy
http://forums.matronics.com/viewtopic.php?p=476134#476134
pjeffers(at)talktalk.net Guest
Posted: Wed Dec 06, 2017 9:01 am Post subject: Radio/Intercom issue - wisdom of the group sought..... |
Hi
I am a complete amateur on radio stuff, but I do remember in the past having a similar problem. It is caused by factory default which has decided that radio transmissions should override the intercom. I fixed the problem through the setup pages on the radio where you can alter the priorities.
Just a random thought that just may help.
Pete
rampil
Posted: Wed Dec 06, 2017 2:45 pm Post subject: Re: Radio/Intercom issue - wisdom of the group sought..... |
This is a safety option incorporated in most modern radios(with built-in intercoms) and standalone audio. The marketing blather usually calls
it Radio Priority or Auto-Mute. Depending on manufacturer, it can be
disabled by a switch, by a jumper on the rear connector, or some other imaginative, inconvenient technique.
In the case of the 403, from the manual:
(http://www.angelesflying.com/documents/manuals/flightcom403mcManual.pdf)
Look at Figure 5 and 6
rainbow462
Posted: Thu Dec 21, 2017 7:02 am Post subject: Re: Radio/Intercom issue - wisdom of the group sought..... |
thank for the replies. it was indeed the intercom factory default settings and now the offending wire has been cut, it is back to radio and intercom together
regards
Jeremy
moosix Guest
Posted: Tue May 14, 2019 5:14 am Post subject: Re: Radio/Intercom issue - wisdom of the group sought..... |
Although most of the musical tracks nowadays are may be easily accessed online, anyway I am looking for paid services like https://mp3caprice.com/genre at least because I may download faster there entire album and with more quality. A necessity of downloading appears anyway quite often, as soon as while listening, for example, during a trip, sometimes Internet connection may fail and so on.
rampil
Posted: Tue May 14, 2019 10:15 am Post subject: Re: Radio/Intercom issue - wisdom of the group sought..... |
(at)Moosux is a spam garbage poster and not welcome here.
