AW: Re: Tool kit and spares kit
Alfred Buess
PostPosted: Sat Dec 02, 2017 1:48 am    Post subject: AW: Re: Tool kit and spares kit Reply with quote
Jerry,
What type is the "much better tube nearly twice as thick" and where did you buy it?
Regards, Alfred
-----Ursprüngliche Nachricht-----
Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Jerry Rehn
Gesendet: Freitag, 1. Dezember 2017 23:42
An: europa-list(at)matronics.com
Betreff: Re: Re: Tool kit and spares kit
A good list! I carry pretty much the same, I also carry a copy of the page from the manual illustration of the wheel, handy to help see assembling. I have had two tube failures, fortunately not while landing, but the next morning flat. Both failures were at the stamp mark on the tube, weakened by that stamp. Finally found a much better tube nearly twice as thick. No more issues, but paranoid enough to carry a spare tube. I still run at 18lbs, I could see the tube wouldn’t suffer as much with more pressure but I’m not sure I wouldn’t be bouncing a lot at 26!
Jerry
h&jeuropa
PostPosted: Sat Dec 02, 2017 5:33 am    Post subject: Re: AW: Re: Tool kit and spares kit Reply with quote
Alfred,
I have purchased heavy tubes from Desser Tire. The item number is TU 700/800-6 AM, Butyl Easy Valve TR-87.
Here is the link: https://www.desser.com/Aircraft-Tires-and-Tubes/700-800-6-AERO-CLASSIC-INLEAKGUARD-IN-BUTYL-TUBE-AERO-CLASS-GL-7087.asp
Valve TR-87 is the angled valve. They cost $59.95.
I also purchase Airhawk 700-6 6 ply tires from Desser.
Jim Butcher
rehn(at)rockisland.com
PostPosted: Sat Dec 02, 2017 6:46 am    Post subject: AW: Re: Tool kit and spares kit Reply with quote
Alfred
Jim sent off email before me, that’s where I get mine too.
Jerry
On Dec 2, 2017, at 2:47 AM, A. Buess Aviatik <ykibuess(at)bluewin.ch> wrote:
Jerry,
Regards, Alfred
Jerry
