coop85(at)bellsouth.net Guest
Posted: Sat Jul 15, 2006 6:22 pm Post subject: Relative Value for Complete RV-10's? |
I can't help with questions 2 or 3, but when I spoke to the insurance folks
while at Sun-n-Fun Avemco said the highest they could go was $125K. The
AOPA folks leaned toward $125K but said they might be able to find an
underwriter that would support $150K. The numbers may have changed since
April since there are more -10s flying and a few have sold for well over
that. The big thing with Avemco is they will over cover an amount you have
receipts for.
Marcus
40286
Inspection set for 22 Jul - optimistic but hopeful
Tim(at)MyRV10.com Guest
Posted: Sat Jul 15, 2006 6:51 pm Post subject: Relative Value for Complete RV-10's? |
I know with AIG that coverage can be had to $165K. Don't know
if there's a max that they'll go to.
receipts for.
Marcus
40286
dmasys(at)cox.net Guest
Posted: Sat Jul 15, 2006 7:29 pm Post subject: Relative Value for Complete RV-10's? |
---- Tim Olson <Tim(at)MyRV10.com> wrote:
| Quote: | To combine replies to another, I agree, if anyone can
build an RV-10 to the point of finishing, in less
than 1500 hours, I'd be pretty surprised, even if
completely QB. My estimates would be more like:
QB Complete: 1500-1700
1/2 QB Options: 1700-2000
100% Standard: 1900-2500
Not sure, but I think my QB may come in under 1000 hrs total since I am fitting the canopy cover now, all wing construction including lighting, wiring, antennas and servos are done, have the electrical & lighting systems in the fuse and tested, and some avionics done. The engine is sitting a few feet away from the firewall, and the KitLog program tells me total shop hours are currently at 487 (started the project last August 26th). At the same point on my slow build -7A I had about 1000 shop hours in the project.
I think the difference is knowing exactly what you want to do and how to get it done on your second RV.
But then, I might be underestimating the cabin completion issues. Will see...
-Dan Masys
#40448
wayne.e(at)grandecom.net Guest
Posted: Sun Jul 16, 2006 5:10 am Post subject: Relative Value for Complete RV-10's? |
I checked at one point and had a quote at $190K.
Wayne Edgerton #403336
