Dave Saylor
Posted: Tue Nov 07, 2017 4:29 pm Post subject: Cleveland Wheel Bearings |
Does anyone have a good source for wheel bearings? I found Timken nose bearings for about $40 but the my shopping cart at Vans is running about $650 for all 8 pcs for the mains. I'm pretty sure it doesn't have to be this way. But my search for LM274949-2-629 is coming up short.
Has someone had success with an alternate number? Besides the Cleveland number?
--Dave
_________________ --Dave
KWVI |
Don Orrick
Posted: Tue Nov 07, 2017 5:19 pm Post subject: Cleveland Wheel Bearings |
Local auto parts store can order them or a local bearing supply co can get them
| Quote: | On Nov 7, 2017, at 6:26 PM, David Saylor <saylor.dave(at)gmail.com> wrote:
--Dave
toaster73(at)embarqmail.c Guest
Posted: Tue Nov 07, 2017 6:01 pm Post subject: Cleveland Wheel Bearings |
I'll second the possible auto parts angle the following is my order from a few years ago after hurricane high water got on my wheels and I couldn't get them apart in time to prevent corrosion.
These aren't the FAA/PMA flavor but they have been running fine for 300 hours and 4 conditional inspections. Double check the numbers and my research.
-Chris
N919AR
| Quote: | Motion Industries
Release No: Date: 10/13/2011
F.O.B: FOB ORG,FRT PP&ADD
Terms: . CASH
Delivery: STOCK UNLESS NOTED
Qty Description Requested Date
4.0 TIMKEN LM29749 CONE 10/19/2011
Item No..........: 00658750
Cust Stk No .....:
Price............: 15.120 60.48
4.0 TIMKEN LM29710 CUP 10/19/2011
Item No..........: 00658736
Cust Stk No .....:
Price............: 9.360 37.44
SUBTOTAL 97.92
FREIGHT* 9.89
TAX 7.28
TOTAL** 115.09
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Saylor
Sent: Tuesday, November 07, 2017 7:27 PM
Subject: Cleveland Wheel Bearings
--Dave
Tim Olson
Posted: Tue Nov 07, 2017 6:09 pm Post subject: Cleveland Wheel Bearings |
Yeah I've taken them in to a local place in town before
called "Bearing Headquarters" and they can get just
about anything.
On 11/7/2017 7:17 PM, Don Orrick wrote:
> Thanks,
> --Dave
Kellym
Posted: Tue Nov 07, 2017 7:11 pm Post subject: Cleveland Wheel Bearings |
Once you get replacements, be aware that Cleveland has changed their
grease recommendations. Aeroshell #5 is no longer 1st choice.
First choice is Mobil SHC 100, which is a red synthetic grease.
Skygeek carries an appropriate sized tube. The rest of suppliers, last I
looked only carry 5 lbs and up.
I do not know reason Cleveland changed their recommendation.
Kelly
On 11/7/2017 7:07 PM, Tim Olson wrote:
about anything.
> get them
> Sent from my iPhone
>> coming up short.
>> Cleveland number?
>> Thanks,
>> --Dave
KCHD |
Dave Saylor
Posted: Tue Nov 07, 2017 8:02 pm Post subject: Cleveland Wheel Bearings |
Thank you Chris, that's just what I needed. --Dave
On Tue, Nov 7, 2017 at 6:00 PM, Chris <toaster73(at)embarqmail.com (toaster73(at)embarqmail.com)> wrote:
-Chris
N919AR
Terms: . CASH
Cust Stk No .....:
Cust Stk No .....:
SUBTOTAL 97.92
FREIGHT* 9.89
TAX 7.28
TOTAL** 115.09
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of David Saylor
Subject: RV10-List: Cleveland Wheel Bearings
--Dave
KWVI |
Posted: Wed Nov 08, 2017 7:01 am Post subject: Cleveland Wheel Bearings |
Request for background: What kind off experience have people had with
failing/damaged/rusting wheel bearings vis-a-vis maintenance of wheel
bearing?
I operate off a sometimes wet and mushy field where my wheels get quite
a dousing. Each condition inspection, I've been repacking the
bearings. So far I have seen any signs of rusting - is there something
else I should be looking for?
Bill "6 years and 900+ hours on same bearings, color me curious" Watson
On 11/7/2017 7:26 PM, David Saylor wrote:
| Quote: | Does anyone have a good source for wheel bearings? I found Timken nose
short.
Cleveland number?
--Dave
Dave Saylor
Posted: Wed Nov 08, 2017 7:51 am Post subject: Cleveland Wheel Bearings |
Right, SHC 100 looks a lot like Mobil 28 but it's lighter red IIRC. I used it last year.
--Dave
On Tue, Nov 7, 2017 at 7:09 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
| Quote: | --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Once you get replacements, be aware that Cleveland has changed their grease recommendations. Aeroshell #5 is no longer 1st choice.
Skygeek carries an appropriate sized tube. The rest of suppliers, last I looked only carry 5 lbs and up.
Kelly
| Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
about anything.
| Quote: | --> RV10-List message posted by: Don Orrick <don.orrick(at)yahoo.com (don.orrick(at)yahoo.com)>
| Quote: | On Nov 7, 2017, at 6:26 PM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
--Dave
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
KWVI |
Dave Saylor
Posted: Thu Nov 09, 2017 7:48 am Post subject: Cleveland Wheel Bearings |
Bill,
I'll send some pictures of the bearings I'm replacing. The rollers and cones are pitted.
If what you're doing is keeping the bearings in good shape, just keep doing it. It's pretty obvious when they fail. In my experience, once the cup or a roller shows even the tiniest pit/mark/dent/chip, it only takes a few hours of operation to go from "I could probably live with that" to "get that thing off my plane".
--Dave
On Wed, Nov 8, 2017 at 6:59 AM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
| Quote: | --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
Request for background: What kind off experience have people had with failing/damaged/rusting wheel bearings vis-a-vis maintenance of wheel bearing?
I operate off a sometimes wet and mushy field where my wheels get quite a dousing. Each condition inspection, I've been repacking the bearings. So far I have seen any signs of rusting - is there something else I should be looking for?
| Quote: | Does anyone have a good source for wheel bearings? I found Timken nose bearings for about $40 but the my shopping cart at Vans is running about $650 for all 8 pcs for the mains. I'm pretty sure it doesn't have to be this way. But my search for LM274949-2-629 is coming up short.
--Dave
FORUMS -
WIKI -
b Site -
KWVI |
