saafbusiness(at)gmail.com Guest
Posted: Wed Oct 04, 2017 11:08 am Post subject: Pulsar-List Digest: 9 Msgs - 10/03/17 |
Fyi i have had 3 fuel pump failures in 21 years. All of them allow fuel pass through. You only know its not working when on start up listen carefully for the line to fill when you turn it on prior to start
On Wed, Oct 4, 2017 at 12:12 AM Pulsar-List Digest Server <pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)> wrote:
Quote: | *
Today's complete Pulsar-List Digest can also be found in either of the
of the Pulsar-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2017-10-03&Archive=Pulsar
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2017-10-03&Archive=Pulsar
Pulsar-List Digest Archive
Total Messages Posted Tue 10/03/17: 9
Today's Message Index:
1. 07:56 AM - Canyon or Box Canyon Turn ? (Ron Koval)
2. 12:11 PM - Parallel fuel path around Facet pump (Jim Fillman)
3. 12:33 PM - Re: Parallel fuel path around Facet pump (Dennis Adams)
4. 12:42 PM - Re: Parallel fuel path around Facet pump (Ray Pulsar III/3300)
5. 01:19 PM - Re: Parallel fuel path around Facet pump (Sonja Englert)
6. 02:04 PM - Re: Parallel fuel path around Facet pump (Dennis Tubbs)
7. 02:40 PM - Re: Parallel fuel path around Facet pump (Dennis Adams)
8. 05:48 PM - Re: Parallel fuel path around Facet pump (Ray Wilhelm)
9. 08:53 PM - Re: Parallel fuel path around Facet pump (Bob Heiser)
Time: 07:56:52 AM PST US
From: Ron Koval <ronko(at)att.net (ronko(at)att.net)>
Subject: Canyon or Box Canyon Turn ?
Pulsar friends,
Has anybody performed a canyon or box canyon turn in a Pulsar?
I was taught the maneuver when I had a Grumman Cheetah which was=C2-restr
icted =C2-from acrobat maneuvers or spins but the biannual wings program
instructor indicated that the canyon turn when performed properly produces
no more stress on the aircraft than a stall would.
Note, I don't necessarily need this skill where I fly, but I do remember wh
en I learned how to do it, it was great skill to know.
Best regards,
RonkoN1037L
Time: 12:11:38 PM PST US
From: "Jim Fillman" <pilot623(at)gmail.com (pilot623(at)gmail.com)>
Subject: Parallel fuel path around Facet pump
Since the fly-in, I've been mulling the issue that caused the loss of Bob
Heiser's Pulsar since all fuel in my plane flows through the Facet auxiliary
fuel pump. In trying to visualize what a parallel path would look like, I
picture Tees on the upstream and downstream sides of the Facet with a check
valve that only allows fuel to flow towards the engine. Am I thinking this
correctly? Can anyone offer a specific recommendation for the check valve?
Is a check valve really needed? I have no fuel return to the tanks.
Jim
N623JF
Time: 12:33:06 PM PST US
From: Dennis Adams <ghf4986(at)gmail.com (ghf4986(at)gmail.com)>
Subject: Re: Parallel fuel path around Facet pump
Jim,
A couple of things, the Facet fuel pump requires a fuel filter upstream and t
hey recommend a certain micron size. Unfortunately i can not tell you what i
t is from memory.
I bypassed the pump with a couple of tees and a check valve, no special chec
k valve since it is low pressure.
I bought a manifold and jet from Spruce and re-routed the fuel lines after m
ounting the manifold in the engine compartment. =46rom the manifold and jet
i ran a line to the upside of the fuel selector switch, no need to run the r
eturn to the tank.
The return is primarily to stop vapor lock.
Dennis Adams
Sent from an IPad
On Oct 3, 2017, at 1:10 PM, Jim Fillman <pilot623(at)gmail.com (pilot623(at)gmail.com)> wrote:
Since the fly-in, I=99ve been mulling the issue that caused the loss o
f Bob Heiser=99s Pulsar since all fuel in my plane flows through the Fa
cet auxiliary fuel pump. In trying to visualize what a parallel path would l
ook like, I picture Tees on the upstream and downstream sides of the Facet w
ith a check valve that only allows fuel to flow towards the engine. Am I thi
nking this correctly? Can anyone offer a specific recommendation for the che
ck valve? Is a check valve really needed? I have no fuel return to the tanks
Jim
N623JF
________________________________ Message 4 _____________________________________
Time: 12:42:52 PM PST US
From: "Ray Pulsar III/3300" <rwilhelm(at)dc.rr.com (rwilhelm(at)dc.rr.com)>
Subject: RE: Parallel fuel path around Facet pump
That is exactly what I did when I built mine 20 years ago, Jim. At that tim
e there were some Facet pumps that could fail closed. Not so any more with
the newer ones. So they say.
I installed a very low crack pressure check valve in the circuit you descri
bed. 3/8 tube size. I had one from when I worked for a company that made th
em. I am sure you can buy one from ebay. Make sure it is aircraft and not a
uto or industrial. They don=99t make them with very low crack pressur
e (8 =9C water max) and zero leakage in the check direction.
Ray
Sent from Mail for Windows 10
Sent: Tuesday, October 3, 2017 12:10 PM
of Bob Heiser=99s Pulsar since all fuel in my plane flows through the
Facet auxiliary fuel pump. In trying to visualize what a parallel path wou
ld look like, I picture Tees on the upstream and downstream sides of the Fa
cet with a check valve that only allows fuel to flow towards the engine. Am
I thinking this correctly? Can anyone offer a specific recommendation for
the check valve? Is a check valve really needed? I have no fuel return to t
he tanks.
Jim
N623JF
________________________________ Message 5 _____________________________________
Time: 01:19:22 PM PST US
From: Sonja Englert <paqs345(at)gmail.com (paqs345(at)gmail.com)>
My Facet fuel pump failed this year, but all that happened was that it did
not pump fuel anymore when turned on. Fuel would still flow through it. I
do not have a bypass.
One note on vapor return lines: they may do exactly what they are called,
return vapor. It would be stupid to return vapor to anywhere but the top of
the tank.
Sonja
On Tue, Oct 3, 2017 at 12:10 PM, Jim Fillman <pilot623(at)gmail.com (pilot623(at)gmail.com)> wrote:
s of Bob
> Heiser=99s Pulsar since all fuel in my plane flows through the Face
t
> auxiliary fuel pump. In trying to visualize what a parallel path would lo
ok
> like, I picture Tees on the upstream and downstream sides of the Facet wi
th
> thinking this correctly? Can anyone offer a specific recommendation for t
he
> check valve? Is a check valve really needed? I have no fuel return to the
> tanks.
> Jim
> N623JF
________________________________ Message 6 _____________________________________
Time: 02:04:43 PM PST US
From: Dennis Tubbs <dennistubbs7(at)gmail.com (dennistubbs7(at)gmail.com)>
Thanks Sonja, for sharing your experience here. Other comments had be
concerned what might happen if my Facet pump failed.
On Tue, Oct 3, 2017 at 1:18 PM, Sonja Englert <paqs345(at)gmail.com (paqs345(at)gmail.com)> wrote:
d
of
> the tank.
> Sonja
ss of Bob
et
ook
ith
the
e
>> tanks.
>> Jim
>> N623JF
________________________________ Message 7 _____________________________________
Time: 02:40:44 PM PST US
Its vapor pressure, no pressure, no vapor!
Sent from an IPad
On Oct 3, 2017, at 3:03 PM, Dennis Tubbs <dennistubbs7(at)gmail.com (dennistubbs7(at)gmail.com)> wrote:
Thanks Sonja, for sharing your experience here. Other comments had be concer
not pump fuel anymore when turned on. Fuel would still flow through it. I d
> One note on vapor return lines: they may do exactly what they are called, r
eturn vapor. It would be stupid to return vapor to anywhere but the top of t
he tank.
> Sonja
s of Bob Heiser=99s Pulsar since all fuel in my plane flows through th
e Facet auxiliary fuel pump. In trying to visualize what a parallel path wou
ld look like, I picture Tees on the upstream and downstream sides of the Fac
et with a check valve that only allows fuel to flow towards the engine. Am I
thinking this correctly? Can anyone offer a specific recommendation for the
check valve? Is a check valve really needed? I have no fuel return to the t
anks.
>> Jim
>> N623JF
________________________________ Message 8 _____________________________________
Time: 05:48:12 PM PST US
From: Ray Wilhelm <rwilhelm25(at)gmail.com (rwilhelm25(at)gmail.com)>
Please be advised that the crack pressure of the ASP check valve is not lis
ted. If it is not less then 8 inches of water, do not use it. The high crac
k pressure of typical Check Valve will cause the engine driven pump to vapo
r lock the first time it is needed at high temps and altitude. Especially w
ith auto gas. You do not want the pump to have to suck against the typical
2 psi crack pressure. Neither do you want it to leak at all in normal opera
tion. It is like your heart with a very bad murmur. The Facet pump will jus
t be putting the fuel back to its own inlet.
Ray
Sent: Tuesday, October 3, 2017 12:36 PM
Jim,
they recommend a certain micron size. =C2-Unfortunately i can not tell y
ou what it is from memory. =C2-
ck valve since it is low pressure.
mounting the manifold in the engine compartment. =C2-From the manifold an
d jet i ran a line to the upside of the fuel selector switch, no need to ru
n the return =C2-to the tank.
Dennis Adams=C2-
Sent from an IPad=C2-
he tanks.
=C2-
Jim
N623JF
________________________________ Message 9 _____________________________________
Time: 08:53:32 PM PST US
From: Bob Heiser <w7ikt(at)fly-web.us (w7ikt(at)fly-web.us)>
I have seen diagrams just like you describe. That is the way I would do
it if i built or owned another low wing.
On 10/03/2017 02:10 PM, Jim Fillman wrote:
> I picture Tees on the upstream and downstream sides of the Facet with
God Bless,
Bob W7IKT & Carol N5CBQ HeiserI
ar-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Pulsar-List
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
| - The Matronics Pulsar-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Posted: Wed Oct 04, 2017 11:17 am Post subject: Pulsar-List Digest: 9 Msgs - 10/03/17 |
And 1 mechnical pump leakage replace and 1 complete failure of the mechnical before they changed that horibble design. Fortunetly they only both failed once on run up. That time i am sure the electric one failed before the mechanical because the odds of both at the same time is very low. That is why i listen very close for the fill sound of the electric before turning the motor
On Wed, Oct 4, 2017 at 12:07 PM Mark Fox <saafbusiness(at)gmail.com (saafbusiness(at)gmail.com)> wrote:
Quote: | Fyi i have had 3 fuel pump failures in 21 years. All of them allow fuel pass through. You only know its not working when on start up listen carefully for the line to fill when you turn it on prior to start
HTML Version:
Text Version:
Pulsar friends,
Best regards,
RonkoN1037L
Jim
N623JF
Jim,
t is from memory.
eturn to the tank.
Dennis Adams
Sent from an IPad
Jim
N623JF
Ray
he tanks.
Jim
N623JF
the tank.
Sonja
s of Bob
t
ok
th
he
> tanks.
> Jim
> N623JF
d
of
> the tank.
> Sonja
ss of Bob
et
ook
ith
the
e
>> tanks.
>> Jim
>> N623JF
Sent from an IPad
he tank.
> Sonja
anks.
>> Jim
>> N623JF
Ray
Jim,
Dennis Adams=C2-
he tanks.
=C2-
Jim
N623JF
God Bless,
FORUMS -
WIKI -
b Site -
bernard.wilder2(at)gmail. Guest
Posted: Wed Oct 04, 2017 12:10 pm Post subject: Pulsar-List Digest: 9 Msgs - 10/03/17 |
In the 17 years I flew 390XP not one fuel pump failure. But then, I seldom used it. For me it was an emergence pump in case the engine fuel pump failed. It never did. Had a fuel pressure gauge to monitor performance of the pumps.
Had a fuel feedback line after the engine pump direct back to the fuel cells,,,as per the Rotax engine installation instructions.
In the early 1990s Ford pickups had two fuel tanks. There was an electric pump to transfer fuel from one to the other. Aero Designs furnished these with the kit in 1995 . It had a built in check valve. The instructions furnished for installation in the truck noted that it should be installed so there was an incline of 20 some degrees up between the input up to the outlet. I obeyed.
390XP is resting peacefully in my garage. Waiting for a home that swill restore her.
Bernie Wilder
On Wed, Oct 4, 2017 at 3:07 PM, Mark Fox <saafbusiness(at)gmail.com (saafbusiness(at)gmail.com)> wrote:
HTML Version:
Text Version:
Pulsar friends,
Best regards,
RonkoN1037L
Jim
N623JF
Jim,
t is from memory.
eturn to the tank.
Dennis Adams
Sent from an IPad
Jim
N623JF
Ray
he tanks.
Jim
N623JF
the tank.
Sonja
s of Bob
t
ok
th
he
> tanks.
> Jim
> N623JF
d
of
> the tank.
> Sonja
ss of Bob
et
ook
ith
the
e
>> tanks.
>> Jim
>> N623JF
Sent from an IPad
he tank.
> Sonja
anks.
>> Jim
>> N623JF
Ray
Jim,
Dennis Adams=C2-
he tanks.
=C2-
Jim
N623JF
God Bless,
FORUMS -
WIKI -
b Site -
FoesFlyDennis
Joined: 21 Jan 2016 Posts: 12 Location: Mesa, Arizona, USA
Posted: Thu Oct 05, 2017 5:37 am Post subject: Pulsar-List Digest: 9 Msgs - 10/03/17 |
Mark, this is useful information. Thanks for sharing your experience. Dennis Tubbs - Pulsar III - N852LW
On Oct 4, 2017 12:16 PM, "Mark Fox" <saafbusiness(at)gmail.com (saafbusiness(at)gmail.com)> wrote: Quote: | Fyi i have had 3 fuel pump failures in 21 years. All of them allow fuel pass through. You only know its not working when on start up listen carefully for the line to fill when you turn it on prior to start
HTML Version:
Text Version:
Pulsar friends,
Best regards,
RonkoN1037L
Jim
N623JF
Jim,
t is from memory.
eturn to the tank.
Dennis Adams
Sent from an IPad
Jim
N623JF
Ray
he tanks.
Jim
N623JF
the tank.
Sonja
s of Bob
t
ok
th
he
> tanks.
> Jim
> N623JF
d
of
> the tank.
> Sonja
ss of Bob
et
ook
ith
the
e
>> tanks.
>> Jim
>> N623JF
Sent from an IPad
he tank.
> Sonja
anks.
>> Jim
>> N623JF
Ray
Jim,
Dennis Adams=C2-
he tanks.
=C2-
Jim
N623JF
God Bless,
FORUMS -
WIKI -
b Site -
_________________ 2012 Pulsar III - Jabiru 2200A - N852LW
DennisTubbs7@gmail.com
Mesa, Arizona |
