Battery/Regulator
p-a.austin(at)xnet.co.nz
PostPosted: Sun Sep 10, 2017 3:29 pm    Post subject: Battery/Regulator Reply with quote
Hello all,
Following on the theme of Battery replacement I have cut and paste the following from a builders website namely “Dog Aviation”.
The “Silent Hektik” F-4118 Regulator is what we want as a direct replacement for the Ducati regulator. The F-4118 regulator also has an added built-in feature of a four stepped voltage output …
so it can be used not only on lead acid batteries, but also on AGM and Ion batteries as well … both of which benefit from the voltage stepping.
The voltage stepping ranges from 13 to approximately 14.3 volts in four steps spaced at approximately 9 minute intervals.
[img]cid:FA3BD131-8EFF-47E9-A8AB-05A4F5BB9B69[/img]
Photo of a charging graph obtained from the Silent Hektik site showing the charging steps for the F-4118 regulator.
[/url]
[url=https://1.bp.blogspot.com/-OKKKQ2k0FY4/WT7BHPBfwiI/AAAAAAAAMrk/bCR1emGn5-4zoQcsIZzglUn86KBYYGawgCLcB/s1600/Silent_Hektik_4Step_Regler.jpg]
Peter ZK-ZEB
 Filesize:  6.82 KB
 Viewed:  2725 Time(s)
