krazydoc33(at)gmail.com Guest
				 Posted: Mon Sep 04, 2017 8:24 pm    Post subject: RotaxEngines-List Digest: 6 Msgs - 09/01/17 |
				Hi Barry,
             Thanks for your reply. I do have to clarify something though.
 The sealant that I used is CS3204  a fuel resistant sealant for use on
 integral fuel tanks and pressurized cabins as well as other areas subject
 to contact with aircraft fuels, lubricants, oils, water and/or weathering. At
 room temperature, this two-part polysulfide cures to a flexible, resilient
 rubber.
 Meets requirements of specifications AMS-S-8802 formerly MIL-S-8802,
 CMNP021, Lockheed, Gulfstream, Hughes Aircraft, Fairchild SPS 6-1 & 6-2
 This is the same sealant that has been used on over 500 Van's RV-12's as
 well as most other Van's aircraft (about 10,000 of them over the years).
 The prototype RV-12 is over 5 years old and has flown most of it's time
 with auto-gas. No problems so far. The new tank that I built also used that
 same sealant. I still do not know why the original fuel tank that I built
 failed after being in service for three years. I am not aware of any other
 similar failures.
 Clearly, not all sealants are the same.
 Henry
 On Sat, Sep 2, 2017 at 1:03 AM, RotaxEngines-List Digest Server <
 rotaxengines-list(at)matronics.com> wrote:
 [quote] *
  Today's complete RotaxEngines-List Digest can also be found in either of
  the
  two Web Links listed below.  The .html file includes the Digest formatted
  and Message Navigation.  The .txt file includes the plain ASCII version
  of the RotaxEngines-List Digest and can be viewed with a generic text
  editor
  HTML Version:
      http://www.matronics.com/digest/digestview.php?Style=
  82701&View=html&Chapter=2017-09-01&Archive=RotaxEngines
  Text Version:
  82701&View=txt&Chapter=2017-09-01&Archive=RotaxEngines
                             RotaxEngines-List Digest Archive
                       Total Messages Posted Fri 09/01/17: 6
  Today's Message Index:
       1. 07:44 AM - 912 fuel problems  (Henry Roden)
       2. 09:35 AM - Re: 912 fuel problems  (FLYaDIVE)
       3. 09:56 AM - Re: 912 fuel problems  (FLYaDIVE)
       4. 10:18 AM - Re: RotaxEngines-List Digest: 0 Msgs - 08/30/17
  (Robert Toth)
       5. 11:04 PM - Official RotaxEngines-List FAQ (Frequently Asked
  Questions)  (Matt Dralle)
       6. 11:17 PM - Official RotaxEngines-List Usage Guidelines  (Matt
  Dralle)
  ________________________________  Message 1
  _____________________________________
  Time: 07:44:47 AM PST US
  Subject: 912 fuel problems
   I have a fuel problem that I would like your advice on. I have an RV-12
  with the Rotax 912ULS that only has about 75 hours on it over the last
  three or four years. I had some severe medical problems and my RV also had
  some fuel problems. The fuel problems began with leakage from the tank. I
  built the tank as per Van's manual and it sat for about a year before I put
  any fuel into it. It was then OK for well over two years before there was a
  leak. It began as a minor leakage and I removed the tank and sealed, from
  the outside, one seam and a front corner. That did not stop the leak and it
  got worse to the point that the tank lost about three gallons of auto fuel
  over about four days. I removed the tank and could not find any sign of a
  leak with the tank on the bench even with fuel in the tank. I put the tank
  back in and filled it, again with auto fuel. It was OK for about five days
  and then began to leak again, this time it lost about ~five gallons and
  stripped the paint off the bottom of the plane, a real mess. I took a sheet
  of newspaper and slid it under the tank, before I removed the fuel, and
  found that it was leaking at the rear right corner. When I took the tank
  out that time it did not leak on the bench until it had sat there for over
  a week. The Pro-Seal softened up in places when it was wet with fuel but it
  was OK when it dried out. While it was wet I could poke a Q-tip stick
  through the corner, the Pro-Seal was quite soft.  had no ideas why the
  Pro-Seal broke down as it did but rather than risk another leak in flight I
  made a new tank, this time without the side gauge and with a Moler
  mechanical gauge on the top. There was a lot of trouble starting the engine
  and when it did start, with full choke and no throttle, it ran rough. I had
  to run the engine on full choke for at least five minutes before I could
  even crack the throttle open. I cleaned both carbs and tried again. Before
  the five minutes were up if I tried to open the throttle the engine would
  die. Once it had really warmed up it seemed OK. I did the pre-flight check
  with a run up at 4000 rpm. The ignition drop as less than 250 rpm and both
  ignitions were the same. At full throttle I could not get more than 4400
  rpm and it ran rough again. Back at the hangar I tried a few diagnostic
  things. With the electric fuel pump on I see about 2.5-2.9 psi. With the
  engine running and the electric pump off the fuel pressure drops to~0.5
  psi. I took the fuel pump off the engine and operated it by hand, it seems
  OK but needs the electric pump on to keep it primed. The throw of the pump
  plunger is ~3/8"-7/16". Checking the pump cam with a rod and measuring the
  amount of difference from high cam to low cam it is barely 3/16" which
  seems very little. There is no sign of wear on the cam when looking at it
  through the pump mounting hole. I had thought that the pump filter was
  contaminated but the pump, when off the engine, seems OK.
  The questions:
  1) Is this a normal throw for this cam?
  2) Why does it need so much choke when it did not do so before all the fuel
  problems.
  3) Is there something else I am missing that would cause these symptoms?
  Since pulling off the fuel pump off another mechanic remarked that the
  engine seemed very stiff to pull over with the prop, it had always been
  that way since new and I had attributed it to the engine gearbox
  combination. I removed the top plugs and the gearbox and the engine and the
  gearbox are each quite smooth but not when the gearbox is mounted back on
  the engine. It feels like the plugs are still in and there is compression
  pressure causing resistance?
  I apologize for the long description.
  Henry
  ________________________________  Message 2
  Time: 09:35:52 AM PST US
  Subject: Re: 912 fuel problems
  Henry:
  I have been working with gas tank sealants for over 20 years.  I do not
  know what form of PRO SEAL you used, what type did you use, the 890 or the
  1440?  But, I can tell you that ALL the gas tank sealants available in the
  USA will NOT work with AutoGas (MoGas) that contains ethanol.  The gas will
  soften and cause leaks to the sealant.  They are good, not great, with
  MoGas that does NOT contain ethanol.  YET!  The 'Aromatics' in gas will
  also attack tank sealants.  Just not as fast as ethanol!
  Also - Many, Many people put one layer of tank sealant over the top of the
  old sealant...  Ya CAN'T do that! The sealants DO NOT stick to them selves
  once cured and especially after gas has been in the tank.  You MUST remove
  all the old sealant - Get down to bare metal - And start again.
  As for your rotax running rough...  Don't know...  Maybe a broken part of
  the sealant has blocked some orifice.  I would fix one problem at a time.
  Gas tank sure sounds like it should be first.
  Barry
  On Fri, Sep 1, 2017 at 10:37 AM, Henry Roden <krazydoc33(at)gmail.com> wrote:
  had
  put
  was a
  it
  fuel
  tank
  days
  sheet
  over
  it
  flight I
  engine
  had
  Before
  check
  both
  seems
  pump
  the
  > The questions:
  > fuel problems.
  the
  > Henry
  ________________________________  Message 3
  Time: 09:56:52 AM PST US
  Henry:
  Barry
  had
  put
  was a
  it
  fuel
  tank
  days
  sheet
  over
  it
  flight I
  engine
  had
  Before
  check
  both
  seems
  pump
  the
  > The questions:
  > fuel problems.
  the
  > Henry
  ________________________________  Message 4
  Time: 10:18:55 AM PST US
  Subject: Re: RotaxEngines-List Digest: 0 Msgs - 08/30/17
  Please change my e-mail to *rtoth4310(at)gmail.com* Thanks Robert Toth
  the
  editor
  > HTML Version:
  82701&View=html&Chapter 17-08-30&Archive=RotaxEngines
  > Text Version:
  82701&View=txt&Chapter 17-08-30&Archive=RotaxEngines
  >                       Total Messages Posted Wed 08/30/17: 0
  ________________________________  Message 5
  Time: 11:04:54 PM PST US
  Subject: Official RotaxEngines-List FAQ (Frequently
  Asked Questions)
  Dear Listers,
  Please read over the RotaxEngines-List Frequently Asked Questions (FAQ)
  below.
  The
  complete RotaxEngines-List FAQ including the Usage Guidelines can be found
  at the
  following URL:
     http://www.matronics.com/FAQs/RotaxEngines-List.FAQ.html
  Thank you,
  [ Note: This FAQ was designed to be displayed with a fixed width font such
  as
           Courier.  Proportional fonts will cause display formatting
  errors. ]
     This FAQ can also be viewed in HTML online at the following address:
                   http://www.matronics.com/FAQ/RotaxEngines-List.htm
          ******* LIST POLICIES AND FREQUENTLY ASKED QUESTIONS *******
  PLEASE READ.  This document contains RotaxEngines-List policies and
  information
  for new and old subscribers.  Understanding the RotaxEngines-List policies
  will
  minimize problems for the Administrator, and will help keep the
  RotaxEngines-List
  running smoothly for all of us.
  *** Quick Start Guide to List Features ***
     There are many features available on the Matronics Email Lists and each
     one is described in detailed below.  However, using the List Navigator
     you can quickly access the complete set of features available for this
     List.  The List Navigator can be found at the following URL:
  *** How to Subscribe and Unsubscribe ***
     Simply go to the Web Page shown below and enter your email address and
     select the List(s) that you wish to subscribe or unsubscribed from.  You
     may also use the handy "Find" function to determine the exact syntax of
     your email address as it is subscribed to the List.  Please see the
     complete instructions at the top of the Web Page for more information.
     The Subscribe/Unsubscribe web page is:
                   http://www.matronics.com/subscribe
     Note that you will receive TWO conformation emails regarding your
  subsciption
     process.  The first verifies that your subscription/unsubsciption
  request
     was received, and the second confirms that the process has been
  completed.
     You should receive the first email within a few minutes of your request.
     The second conformation will arrive in less than 24 hours.  You cannot
  post
     until you receive the second conformation email message.
  *** How to Post a Message ***
     Send an email message to:
     Your message will be redistributed to everyone currently subscribed
     to the List.
  *** SPAM Fighter - You Must be Subscribed to Post ***
     When a new post is received by the system, the From: line of the message
     is checked and compared against the current subscription list.  If the
     email address is found, the message is passed on to the List Processor
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
