Cheap chinese landing light
wdaniell.longport(at)gmai
PostPosted: Mon Jun 12, 2017 6:04 am    Post subject: Cheap chinese landing light Reply with quote
I installed a bike riding light in hj460.
It completely cuts out any radio within 5 yards with strong static...teach me to be cheap.
Ill giess ill have to pony up for a proper suppressed landing light unless anyone has a suggestion.
Will
rampil
PostPosted: Mon Jun 12, 2017 7:46 am    Post subject: Re: Cheap chinese landing light Reply with quote
You can try filter caps and maybe even an inductor in the supply line
but the odds are against you. Cheap LEDs use cheap, noisy
Chopping current limiters. Hard to fix correctly from the outside.
Ira N224XS
PostPosted: Mon Jun 12, 2017 8:20 am    Post subject: Cheap chinese landing light Reply with quote
Sounds like the cure will be more expensive than the disease.  Anyway the radiation sounds strong enough to give you cancer so I think Ill change it.
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
On Mon, Jun 12, 2017 at 10:46 AM, rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote:
--> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=469998#469998
Burrilla
PostPosted: Mon Jun 12, 2017 10:24 am    Post subject: Cheap chinese landing light Reply with quote
I found that problem and replaced with a better quality version, full European CE marked. I also put a ferrite ring in the power lead with a turn of cable though it and stopped the problem.
Alan
On 12 Jun 2017, at 15:03, William Daniell <wdaniell.longport(at)gmail.com> wrote:
Will
PostPosted: Mon Jun 12, 2017 11:18 am    Post subject: Cheap chinese landing light Reply with quote
Thanks...
Its amazing how much noise this thing generatesand throughout the spectrum..really loud...i could use it for the "cone of silence".
On Jun 12, 2017 13:29, "Alan Burrill" <alanb(at)dpy01.co.uk (alanb(at)dpy01.co.uk)> wrote:
--> Europa-List message posted by: Alan Burrill <alanb(at)dpy01.co.uk (alanb(at)dpy01.co.uk)>
Alan
> On 12 Jun 2017, at 15:03, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
> Will
graeme bird
PostPosted: Tue Jun 13, 2017 10:41 am    Post subject: Re: Cheap chinese landing light Reply with quote
I have a cheap Chinese landing light for mine which has a switcher voltage converter to allow up to 32v to be supplied. I haven't noticed any noise from it or impact on anything, however the led matrix 3 x 3 needs about 9 v so a nice quiet resistor would also do the job.
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
PostPosted: Tue Jun 13, 2017 12:40 pm    Post subject: Cheap chinese landing light Reply with quote
Graeme
where would I put it?  Across the power and neutral?​
This light is for a bike and uses 12v.
Its pretty bright and uses little current so its fine apart from cutting out all comms.  I will try a couple of ferrite chokes to see what happens
Will
William Daniell
LONGPORT
+57 310 295 0744
On Tue, Jun 13, 2017 at 1:41 PM, graeme bird <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)> wrote:
--> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
Graeme Bird
G-UMPY -  Mono Classic/XS FFW 912S, Woodcomp 3000/3W CS, trutrak Gemini 2 axis AP, PAW, PFLARM core, ads-b out, 8.33khz, mode S, FP-5, Aera500, SD on Nexus, SmartA3
290 hours &amp; 5 years on the Mono, 930 total
g(at)gdbmk.co.uk
http://forums.matronics.com/viewtopic.php?p=470055#470055
carlp101
PostPosted: Thu Jun 29, 2017 3:23 am    Post subject: Re: Cheap chinese landing light Reply with quote
I use 3480 lumen LED light from Jaycar. See https://www.jaycar.co.uk/3486-lumen-ip68-solid-led-spot-light/p/SL3919. It's as quite as a mouse and cheap too.
Carl
PostPosted: Thu Jun 29, 2017 4:21 am    Post subject: Cheap chinese landing light Reply with quote
ThanksWill
On Jun 29, 2017 07:26, "carlp101" <cparkinson(at)cisc-uk.com (cparkinson(at)cisc-uk.com)> wrote:
--> Europa-List message posted by: "carlp101" <cparkinson(at)cisc-uk.com (cparkinson(at)cisc-uk.com)>
Carl
http://forums.matronics.com/viewtopic.php?p=470574#470574
