mojavjoe
Posted: Sat Jun 10, 2017 12:46 pm Post subject: fuel fittings |
I'd like to put fuel outlets in the bottom of my fuel tank. Had considered gluing a 1/4" block of plastic to the tank and tapping a hole for a !/4"mpt to compression fitting, but I could not find any glue that would stick to the plastic tank. Dose anyone have a supply house that has rubber sealed fittings that would meat my needs.
Joe
gdhelton(at)gmail.com Guest
Posted: Sat Jun 10, 2017 1:43 pm Post subject: fuel fittings |
Try Leading Edge Airfoils
They rubber/ plastic tank inserts and the appropriate valves and/or fittings
Posted: Sat Jun 10, 2017 1:45 pm Post subject: fuel fittings |
You also might try Aircraft Spruce , their large catalog.
George H.
Have a great day!
On Jun 10, 2017, at 4:43 PM, mojavjoe(at)comcast.net (mojavjoe(at)comcast.net) wrote:
| Quote: | I'd like to put fuel outlets in the bottom of my fuel tank. Had considered gluing a 1/4" block of plastic to the tank and tapping a hole for a !/4"mpt to compression fitting, but I could not find any glue that would stick to the plastic tank. Dose anyone have a supply house that has rubber sealed fittings that would meat my needs.
Joe
rickofudall
Posted: Sat Jun 10, 2017 4:21 pm Post subject: fuel fittings |
Guys, you don't need to look any further than Kolb. Give them a call on Monday morning and tell them what you want to do. They have the parts and the tanks, too.
Rick Girard
On Sat, Jun 10, 2017 at 4:44 PM, George Helton <gdhelton(at)gmail.com (gdhelton(at)gmail.com)> wrote:
| Quote: | You also might try Aircraft Spruce , their large catalog.
George H.
Have a great day!
Joe
“Blessed are the cracked, for they shall let in the light.” Groucho Marx
Richard Pike
Posted: Sat Jun 10, 2017 5:17 pm Post subject: Re: fuel fittings |
What Rick said - Call Kolb
But for future reference:
http://www.cps-parts.com/catalog/appages/ffelbow.php?clickkey=32633
http://www.cps-parts.com/catalog/appages/fueltankvalve.php?clickkey=75834
http://www.cps-parts.com/catalog/appages/ftb01.php?clickkey=8505
Replace the rubber bushing frequently
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
