Harv
Posted: Mon May 15, 2017 4:54 am Post subject: CJ6 Wheel bearing removal |
Has anyone got some good tips on how to remove the wheel bearing races from the wheel hubs on a CJ6?
I noticed the the inside of the hubs don't have any relief cuts in them to allow a drift to sit nicely up against the back of the race.
There's a trick on the web which involves running a bead of weld round face of the race which once cooled contracts and it will simply fall out. (Not sure about trying it though).
The inner main wheel bearings simply pulled off the axles so no issues there.
TIA
Rgs
Harv
jay-dub
Posted: Mon May 15, 2017 7:47 am Post subject: Re: CJ6 Wheel bearing removal |
Can't help with that, Harv.
Further to your question earlier on in the year about a suitable licenced engineer, we ended up taking JSA to North Weald Flying Services. In theory, it should be ready by Friday so a three week turnround. Their Chief Engineer put a couple of Changs on the UK reg many years ago so he's familiar.
_________________ CJ owner |
Posted: Mon May 15, 2017 8:58 am Post subject: CJ6 Wheel bearing removal |
Harv,Actually running a pair of 1 inch beads on the race works very well. I have done it many times. I do not know of any other way to get the job done.
Doug
On Mon, May 15, 2017 at 5:54 AM, Harv <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)> wrote:
| Quote: | --> Yak-List message posted by: "Harv" <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)>
I noticed the the inside of the hubs don't have and relief cuts in them to allow a drift to sit nicely up against the back of the race.
The inner main wheel bearings simply pulled of the axles so no issues there.
TIA
Rgs
Harv
http://forums.matronics.com/viewtopic.php?p=469320#469320
Harv
Posted: Mon May 15, 2017 9:16 am Post subject: Re: CJ6 Wheel bearing removal |
Gents thanks for the replies.
Jay-Dub, thanks for that lead and hope to see you flying soon.
I've found a way forwards and hope to be flying in June.
Doug, thanks for confirmation on the welding trick, that's how I will proceed.
Cheers
Harv
Vic
Joined: 12 Aug 2008 Posts: 117 Location: Southern Bavaria
Posted: Mon May 15, 2017 11:14 am Post subject: Re: CJ6 Wheel bearing removal |
Heat the hub to max. 200 Deg C and I am sure the races drop out.
Vic
pfstelwagon(at)earthlink. Guest
Posted: Mon May 15, 2017 6:03 pm Post subject: CJ6 Wheel bearing removal |
One other thing that worked was to put the wheel (no tire or tube) in a
large pot of boiling water, one of mine dropped out and the other required
light taps.
frank
KingCJ6(at)aol.com Guest
Posted: Mon May 15, 2017 8:22 pm Post subject: CJ6 Wheel bearing removal |
God, I love this list! Would a turkey deep fryer hasten the process? Nanchang giblets?
Dave
In a message dated 5/15/2017 7:03:37 P.M. Pacific Daylight Time, pfstelwagon(at)earthlink.net writes:
[quote]--> Yak-List message posted by: "Frank Stelwagon" <pfstelwagon(at)earthlink.net>
light taps.
frank
jay-dub
Posted: Tue May 16, 2017 1:16 pm Post subject: Re: CJ6 Wheel bearing removal |
... only if it comes with rice.
Viperdoc
Posted: Tue May 16, 2017 6:19 pm Post subject: CJ6 Wheel bearing removal |
If boiled in peanut oil.
BAHAHAHA
Doc
On May 15, 2017, at 11:19 PM, KingCJ6(at)aol.com (KingCJ6(at)aol.com) wrote:
[quote] God, I love this list! Would a turkey deep fryer hasten the process? Nanchang giblets?
Dave
In a message dated 5/15/2017 7:03:37 P.M. Pacific Daylight Time, pfstelwagon(at)earthlink.net (pfstelwagon(at)earthlink.net) writes:
[quote]--> Yak-List message posted by: "Frank Stelwagon" <pfstelwagon(at)earthlink.net (pfstelwagon(at)earthlink.net)>
light taps.
frank
_________________ Viperdoc |
Harv
