Prop Balancing
Ernie
PostPosted: Fri Mar 24, 2017 7:03 am    Post subject: Prop Balancing Reply with quote
Does anyone have any detail on balancing the Housai Prop? Let me start off saying that I have the most rudimentary understanding of how a prop is balanced. It seems that the position on the hub perpendicular to the rotation axis is pretty arbitrary. Does anyone have a written procedure of any sort?
Ernie
Ernie
PostPosted: Fri Mar 24, 2017 7:15 am    Post subject: Prop Balancing Reply with quote
Just read my own email, and it's pretty cryptic. I'm referring to where the weights get placed. I'm unsure about how one would determine where around the circumference of the blade shaft one would place the weight. When one balances a wheel theres only one dimension you're dealing with, here there are two.
Ernie
On Fri, Mar 24, 2017 at 11:00 AM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
Ernie
wlannon(at)shaw.ca
PostPosted: Fri Mar 24, 2017 9:33 am    Post subject: Prop Balancing Reply with quote
Ernie;
Static propellor balancing is done with a central arbor installed on a precision leveled set of balance ways. Level tolerance is within 0.0005” pet foot of length.
Quick summary for J9-G1 prop.-- With blades level add corrective weight to balance ring in any circumferential location.   Position blades vertical, move installed weight circumferentially to correct vertical unbalance. If, in best location, vertical unbalance still not corrected add additional weight in same circumferential location to BOTH blades.
With both horizontal and vertical unbalance corrected the prop. will balance in all positions.
Walt
Sent: Friday, March 24, 2017 8:13 AM
To: yak-list (yak-list(at)matronics.com)
Subject: Re: Prop Balancing
Ernie
Ernie
Virus-free. www.avast.com
Ernie
PostPosted: Fri Mar 24, 2017 9:42 am    Post subject: Prop Balancing Reply with quote
Walt,
I was referring to Dynamic balancing. But I never considered static balance in both planes.
Thanks.
Ernie
On Fri, Mar 24, 2017 at 1:37 PM Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
Ernie;
Walt
Ernie
Ernie
wlannon(at)shaw.ca
PostPosted: Fri Mar 24, 2017 10:29 am    Post subject: Prop Balancing Reply with quote
Ernie;
Should always be static balanced first.
Dynamic balancing is also a very good idea which can correct the aerodynamic effects of discrepancies between blades with regard to spanwise angle distribution, width, thickness and profile. For al. alloy blades if all of these factors are carefully addressed at overhaul the need for dynamic balancing is greatly reduced and for installations like the CJ there is no spinner back-plate to satisfy the 360 deg. facility for correction.
Walt
Sent: Friday, March 24, 2017 10:39 AM
Walt,
Thanks.
Ernie
Ernie;
Walt
Ernie
Ernie
Ernie
PostPosted: Fri Mar 24, 2017 10:39 am    Post subject: Prop Balancing Reply with quote
Thanks Walt,
I'll have to find someone local who can static balance my prop.
Ernie
On Fri, Mar 24, 2017 at 2:26 PM, Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
Ernie;
Walt
Walt,
Thanks.
Ernie
Ernie;
Walt
yak-list
[b]Subject:
Re: Prop Balancing
Ernie
Ernie
cjpilot710(at)AOL.COM
PostPosted: Mon Mar 27, 2017 9:53 am    Post subject: Prop Balancing Reply with quote
There is a propeller shop in Orlando.
In a message dated 3/24/2017 2:40:09 P.M. Eastern Daylight Time, erniel29(at)gmail.com writes:
Thanks Walt,
Ernie
Ernie;
Walt
Walt,
Thanks.
Ernie
Ernie;
Walt
yak-list
[b]Subject:
Re: Yak-List: Prop Balancing
Ernie
Ernie
[/b]
