algate(at)attglobal.net Guest
Posted: Tue Jul 11, 2006 12:23 pm Post subject: Low Fuel Warning |
Sorry to rehash old subjects but I know that a lot of the Kitfoxes with wing
tanks only use a low fuel warning device mounted on the small header tank.
Can I get info/ pricing and contact for this device.
Gary Algate
pwmac(at)sisna.com Guest
Posted: Tue Jul 11, 2006 2:20 pm Post subject: Low Fuel Warning |
I bought mine from either Wicks or ACS. It screws in place of the
brass fitting. Compatible with alcohol and gasoline.
Very inexpensive float switch to turn on a red light on your panel.
Paul
At 02:25 PM 7/11/2006, you wrote:
Gary Algate
shericom(at)rogers.com Guest
Posted: Tue Jul 11, 2006 4:40 pm Post subject: Low Fuel Warning |
Gary, You will find one by going to www.murlewilliamsaviation.com in his online catalog for $95.00 US, I am thinking of ordering one my self, let me know if you find anything better, Don
Don Stevenson, Caledon, Ontario
M4/1200 Speedster-912UL
Posted: Wed Jul 12, 2006 5:14 am Post subject: Low Fuel Warning |
Thanks Don
Gary
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Donald STEVENSON
Sent: Tuesday, July 11, 2006 8:37 PM
Subject: Re: Low Fuel Warning
----- Original Message ----
w:st="on">kitfox-list(at)matronics.com
Sent: Tuesday, July 11, 2006 4:25:41 PM
--> Kitfox-List message posted by: "Algate" <algate(at)attglobal.net>
msm_9949(at)yahoo.com Guest
Posted: Wed Jul 12, 2006 8:12 am Post subject: Low Fuel Warning |
Hi Gary.
I got mine (float type) from ACS. I think it cost about $25. An orange LED indicator light for the panel was $2-3 from Radio Shack. Easy to install and works great! Indicator lights up with about 15 min of fuel left. I'm thinking of adding an audio waring as well.
Donald STEVENSON <shericom(at)rogers.com> wrote:
[quote] Gary, You will find one by going to www.murlewilliamsaviation.com in his online catalog for $95.00 US, I am thinking of ordering one my self, let me know if you find anything better, Don
dave(at)cfisher.com Guest
Posted: Wed Jul 12, 2006 8:49 am Post subject: Low Fuel Warning |
Marco the Navman has a alarm setting as well.
You punch in total fuel and set the alarm at where you want it to go off and it goes off after that amount of fuel has gone through.
I set mine at 14 litres and total fuel at 70 litres and when the fuel flow hits 14.5 the audible alarm goes off and with a 582 running and headset on I can clearly hear it .
Now it is not by actual fuel but by virtual fuel calculated by the Navman which does seem very accurate.
I also have windows in both fuel tanks and the dash tank to be able to see the fuel level at all times.
I also use a calibrated dip stick for wing tanks that I dip to confirm the fuel level. But this will do you no good if you leave a gas cap loose and all of your fuel gets siphoned out.
Dave
lcfitt(at)sbcglobal.net Guest
Posted: Wed Jul 12, 2006 10:56 am Post subject: Low Fuel Warning |
Sitting here doing something else, I thought of this system and remembered a
recent report from the Lancair list.
First, I like the translucent fuel tanks that show fuel remaining as you
note or the sight gauges or even looking at the transparent vent line. This
would have helped the Lancair pilot avoid his surprise.
The Lancair list story goes like this:
A guy with a fuel monitor reports that he had been using his fuel burn and
hours left for his fuel management. After his last flight - bringing his
airpland home from servicing where it had been for about two weeks. The
long cross country flight was uneventful, and upon arrival at his home field
he refuels. I don't remember his reported fuel capacity, but he loaded fuel
to within a few gallons of that capacity. This amount didn't correspond
with the fuel monitor and after some thinking he realized that the
difference was exactly five gallons. He strongly suspects that during his
airplane's stay at the repair shop, someone short of cash, integrety, and
brains simply drained five gallons of his gas into a can for use elsewhere.
Another list member then reported on an airplane readying for flight that
was discovered during the preflight to be bone dry. Apparently the high
price of fuel has brought out the "Midnight Entrepreneurs".
The Lancair List then had the expected long semi flaming session about what
constitutes a proper fuel assessment during the preflight and the relative
distribution of brains in that group.
Another reason to be careful with too much reliance on fuel totalizers has
to do with the last homeward flight from the Desert Fox fly-in when the line
boy didn't get my fuel cap on squarely and I had almost a full tank of fuel
sucked out before I noticed anything amis.
Be careful with too much reliance on these devices that calculate fuel
remaining based on only what it knows - fuel added and fuel flow - there may
be other factors that may come into play.
Also be careful with to much reliance on others that are servicing our
airplanes. I sure learned from my experience. The cap was on and pointed
in the right direction, but only one tang was engaged.
Lowell
Posted: Wed Jul 12, 2006 12:22 pm Post subject: Low Fuel Warning |
Lowell,
I learned many years ago as part of my walkaround that when at tail of plane
to look forward and check gas caps and make sure they are there in in right
position visually. After a refueling -same thing walkaround look at tail,
make sure tailwheel still there etc and look forward to gas caps. The low
pressure on top of wings will drain your tanks very quickly if the cap comes
off. I would only gues that a poor sealing cap "might " do the same.
Dave
mike Guest
Posted: Wed Jul 12, 2006 12:41 pm Post subject: Re: Low Fuel Warning |
I do one better, I put my hand on each fuel cap and wiggle it to make sure not only is it on, but that is on proper before climbing into the cockpit. I grab the vent on the fox and gentley tug on them. It's turned into a habit that I don't forget. So far I've left the cap off once. Glad I do this.
mike Guest
Posted: Wed Jul 12, 2006 12:43 pm Post subject: Re: Low Fuel Warning |
Oh, and for the reply for the nighttime theifs, I always pull the caps and look inside for the fuel level, big habit also.
Lynn Matteson
Posted: Wed Jul 12, 2006 3:53 pm Post subject: Low Fuel Warning |
Anybody else blow through the vent to be sure no critters are setting
up housekeeping?
Lynn
p.s. yes, I use fuel vent covers, and a pitot cover, but now and then I
forget to put 'em on...and no, I don't blow into the pitot tube. : )
On Wednesday, July 12, 2006, at 04:41 PM, kitfoxmike wrote:
kitfoxmike
kitfox4 1200 912ul speedster
http://www.frappr.com/kitfoxmike
http://forums.matronics.com/viewtopic.php?p=46740#46740
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
noelloveys(at)yahoo.ca Guest
Posted: Wed Jul 12, 2006 7:16 pm Post subject: Low Fuel Warning |
Due to reasons of transporting my plane on floats I defuel the plane after
every flight. On one occasion I forgot to replace the fuel cap on the right
wing. Now I check the caps before flying and before towing.
I have made mention of the next point on other lists. That is the value of
the post flight inspection. As soon after flying as is practical I do a
post flight inspection. That way if there is anything that I noticed not to
be 100% in flight I can fix it before the next flight. This post-flight
inspection is done in addition to, not instead of a pre-flight inspection.
I do the post-flight inspection not as a time saver but as an extra edge on
the side of safety. Some times I have felt a rush to get a pre-flight done.
At that point I usually make a decision to spend a specific period of time
on my pre-flight so nothing will be overlooked.
In Canada, the Department of Transportation publishes the twelve deadly sins
for AMEs (Aircraft Maintenance Engineers) One of those Deadly sins is
pressure to rush a job. When I was doing my flight lessons on just about
every lesson I would find something that required attention before the next
flight. The CFI complimented me on the thoroughness of my inspections.
After several weeks I think the maintenance staff started paying more
attention to the aircraft because it became increasingly difficult to find
faults.
Noel
[quote] --
bnn(at)nethere.com Guest
Posted: Thu Jul 13, 2006 8:22 am Post subject: Low Fuel Warning |
At 11:55 AM 7/12/2006, you wrote:
| Quote: | The Lancair List then had the expected long semi flaming session about what
ROFLOL!
I see you enjoy the Lancair list in much the same way I do. I'm very glad
the Kitfox list has less, ahem, "capable" pilots. (They're certainly more
civil.)
Guy Buchanan
