Posted: Sat Mar 11, 2017 5:43 pm Post subject: Aileron balancing |
Dear all
I drilled a 1/4 hole in each aileron weight with very little effect. The hinges are free amd i dont think im doing anything wrong.
Is this normal? What next? 1/2" hole?
Help please.
Will
MJKTuck(at)cs.com Guest
Posted: Sat Mar 11, 2017 7:19 pm Post subject: Aileron balancing |
Hi Will,
Sounds like you are balancing the ailerons. You will find you have to drill out lots of 1/4 in holes in both weights. Ideally you need to do it after you have painted the surfaces to save having to add weight back in to balance the weight of the paint.
Martin Tuck
N152MT
Sent from my iPad
| Quote: | On Mar 11, 2017, at 7:39 PM, William Daniell <wdaniell.longport(at)gmail.com> wrote:
Dear all
Help please.
Will
Posted: Sun Mar 12, 2017 12:59 am Post subject: Aileron balancing |
Hi! William .
Have you painted them yet ?
Bob H G-PTAG
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of William Daniell
Sent: 12 March 2017 01:39
Subject: Aileron balancing
Dear all
Help please.
Will
Checked by AVG - www.avg.com
Version: 03/12/17
Posted: Sun Mar 12, 2017 4:49 am Post subject: Aileron balancing |
Yes i haveWill
On Mar 12, 2017 04:02, "Bob Harrison" <ptag.dev(at)tiscali.co.uk (ptag.dev(at)tiscali.co.uk)> wrote: | Quote: |
Hi! William .
Bob H G-PTAG
From: owner-europa-list-server(at)owner-europa-list- ([email]owner-europa-list-[/email])server(at)matronics.com (server(at)matronics.com)] On Behalf Of William Daniell
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Subject: Europa-List: Aileron balancing
Dear all
Help please.
Will
Version: 03/12/17
ptag.dev(at)talktalk.net Guest
Posted: Sun Mar 12, 2017 6:23 am Post subject: Aileron balancing |
William. If you were to compare the volume /weight removed between ¼” hole to a ½” hole the difference would be huge. So small bits but often is the order of the plan. Then you have to fill the holes with some foam and glass it over and repaint . Quite a lot of patience needed to complete it !
Bob Harrison G-PTAG
Sent: 12 March 2017 12:49
Subject: RE: Aileron balancing
Yes i have
Will
Hi! William .
Bob H G-PTAG
Dear all
Help please.
Will
Version: 03/12/17
Version: 03/12/17
Posted: Sun Mar 12, 2017 6:41 am Post subject: Aileron balancing |
Ok thanks...so from the pic in the manual we are talking level suspended from the hinge underside uppermost....right?Will
On Mar 12, 2017 09:26, "Bob Harrison" <ptag.dev(at)talktalk.net (ptag.dev(at)talktalk.net)> wrote: | Quote: |
Bob Harrison G-PTAG
Yes i have
Will
On Mar 12, 2017 04:02, "Bob Harrison" <ptag.dev(at)tiscali.co.uk> wrote:
Hi! William .
Bob H G-PTAG
Dear all
Help please.
Will
Version: 03/12/17
Version: 03/12/17
Posted: Sun Mar 12, 2017 9:34 am Post subject: Aileron balancing |
Hi! William,
I haven’t a manual handy but that sounds about right .
Bob H
Sent: 12 March 2017 14:39
Will
Bob Harrison G-PTAG
Yes i have
Will
Hi! William .
Bob H G-PTAG
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of William Daniell
Dear all
Help please.
Will
Version: 03/12/17
Version: 03/12/17
Version: 03/12/17
