Low-cost ADS-B In Kit
michaelgibbs(at)cox.net
PostPosted: Sun Feb 12, 2017 7:56 am    Post subject: Low-cost ADS-B In Kit Reply with quote
For those of you concerned about the cost of installing ADS-B In, AOPA Live did a segment on a receiver kit you can build yourself for around $200 that's based on a Raspberry Pi computer and works with most iPad aviation apps.
[img]cid:C0C9D65F-2247-45E1-98B4-18B23E4AEB35[/img]
Check it out at https://www.aopa.org/news-and-media/aopa-live?watch=55cc6ae3bc4130399ac812e01f0dcbc6
Mike G.
Kitfox Series 7
Phoenix, AZ
 Filesize:  80.21 KB
 Viewed:  8170 Time(s)
mike>bentley
PostPosted: Sun Feb 12, 2017 8:41 am    Post subject: Re: Low-cost ADS-B In Kit Reply with quote
The homebuilt ADS-B in projects have been great. You can build them even cheaper if you want. Here's the link to the original project. http://stratux.me/
I've built a couple and they work really great.
Mike Bentley
Joplin, MO
N5498B
Kitfox Model 4-1200
Jabiru 2200 #438
Rotec Aerosport LCH Heads
Prince Prop (64 x 34)
Ellison EFS-2 Throttle Body
