whodja
Joined: 27 Jan 2014 Posts: 50 Location: Apex NC (near Raleigh)
Posted: Tue Jan 24, 2017 4:28 am Post subject: Hartzell 2 blade or 3 blade |
The difference through Van's is $10k. I would like to buy the 3 blade but I'm having a hard time with the $10k difference. Any feedback between these 2 for the IO-540 on the 10 would be appreciated.
flying-nut(at)cfl.rr.com Guest
Posted: Tue Jan 24, 2017 4:35 am Post subject: Hartzell 2 blade or 3 blade |
From what I've read here, the 3-blade is not as efficient as the two
blade. And there is the $10K.
However, on the plus side it's damn sexy looking sitting on the ramp. I
went with the two blade ...... hope to fly this fall.
Linn
On 1/24/2017 7:28 AM, whodja wrote:
http://forums.matronics.com/viewtopic.php?p=465388#465388
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Tue Jan 24, 2017 5:04 am Post subject: Hartzell 2 blade or 3 blade |
I have the MT 3 blade and have been flying for 8 1/2 years. I just paid big bucks for a prop overhaul. Ivan Kristensen flew me back to Mississippi to reinstall the prop and then we returned home in loose formation. Same power settings and fuel flow he had about 8 knots on me. Save the $10K would be my advice. It does look sexy sitting on the ramp and it might climb a bit better, but pretty sure not $10K worth!
PM me if you're interested in talking more about my experience.
David Maib
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Posted: Tue Jan 24, 2017 5:52 am Post subject: Hartzell 2 blade or 3 blade |
I agree. They both look just about the same at 200mph. Use the $10k for fuel so your plane doesn't sit. I've seen way too many planes that sit most of the year. I don't think the hangar cares whether your prop is sexy or not. Do yourself a favor and go 2-blade and make the cowl easier to take off too.
Just my $.02!
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
Sent from my iPad
David Maib
> Thanks
civengpe
Posted: Tue Jan 24, 2017 6:01 am Post subject: Hartzell 2 blade or 3 blade |
I have the MT 3-blade prop and love how smooth the ride is, but would save the money and go 2-blade if I had to do it all over again. Plus, the lower cowl is a PIA to remove with the 3-blade prop.
Shannon
On Tue, Jan 24, 2017 at 7:51 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
| Quote: | --> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
Just my $.02!
Jesse Saint
[url=tel:352-427-0285]352-427-0285[/url]
Sent from my iPad
> On Jan 24, 2017, at 8:04 AM, David Maib <dmaib(at)me.com (dmaib(at)me.com)> wrote:
> --> RV10-List message posted by: David Maib <dmaib(at)me.com (dmaib(at)me.com)>
> David Maib
>> On Jan 24, 2017, at 7:28 AM, whodja <whodja(at)gmail.com (whodja(at)gmail.com)> wrote:
>> --> RV10-List message posted by: "whodja" <whodja(at)gmail.com (whodja(at)gmail.com)>
>> Thanks
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
flysrv10(at)gmail.com Guest
Posted: Tue Jan 24, 2017 6:02 am Post subject: Hartzell 2 blade or 3 blade |
Three blade good for climb. Two blade good for cruise. RV10 climbs just fine with two blade. Spend the $10k on gadgets.
Do not archive.
David Maib
> Thanks
Kelly McMullen
Posted: Tue Jan 24, 2017 6:12 am Post subject: Hartzell 2 blade or 3 blade |
Are you saying Ivan had 8kts indicated or 8 kts true over your speed? Am I reading you correctly that Ivan has the 2 blade Hartzell, in comparison to your MT? I don't know anyone with the Hartzell carbon fiber 3 blade. Would be very interested in comparison between the Hartzell 3 blade and the MT. The MT is about $6-7K cheaper than the CF Hartzell, and I very much like the smoothness, as well as the lighter wt over the 2 blade aluminum. I have time in behind both the 2 blade Hartzell and more behind the MT. Nothing wrong with the 2 blade, but my CFO wanted 3 blade, so I went along. The price delta for the MT vs 2 blade aluminum isn't nearly as great as the delta for the composite Hartzell. Allegedly the composite props are less likely to cause internal engine damage if there is a prop strike, but I've not seen any evidence one way or the other.
No question the 3 bladed props make it significantly more difficult to remove the lower cowl.
-sent from the I-droid implanted in my forearm
On Tue, Jan 24, 2017 at 6:04 AM, David Maib <dmaib(at)me.com (dmaib(at)me.com)> wrote:
| Quote: | --> RV10-List message posted by: David Maib <dmaib(at)me.com (dmaib(at)me.com)>
David Maib
> Thanks
FORUMS -
WIKI -
b Site -
A&P/IA, EAA Tech Counselor
KCHD |
dmaib@me.com
Posted: Wed Jan 25, 2017 1:48 pm Post subject: Re: Hartzell 2 blade or 3 blade |
| Kelly McMullen wrote: | Are you saying Ivan had 8kts indicated or 8 kts true over your speed? Am I reading you correctly that Ivan has the 2 blade Hartzell, in comparison to your MT? I don't know anyone with the Hartzell carbon fiber 3 blade. Would be very interested in comparison between the Hartzell 3 blade and the MT. The MT is about $6-7K cheaper than the CF Hartzell, and I very much like the smoothness, as well as the lighter wt over the 2 blade aluminum. I have time in behind both the 2 blade Hartzell and more behind the MT. Nothing wrong with the 2 blade, but my CFO wanted 3 blade, so I went along. The price delta for the MT vs 2 blade aluminum isn't nearly as great as the delta for the composite Hartzell. Allegedly the composite props are less likely to cause internal engine damage if there is a prop strike, but I've not seen any evidence one way or the other.
| [/quote]
Sorry for the delayed response. Ivan had 6 to 8 knots TAS on me as I recall. He does have the 2 blade Hartzell and I have the 3 blade MT.
RV-10 #40559
