NebraskaYak
Posted: Thu Sep 15, 2016 8:04 am Post subject: Housai CHT on shutdown |
Hi Guys,
Looking for advice on lowering CHT for shutdown on my Housai engine. It easily cools to 160C but takes forever to get below 150C. Any recommendations of what to adjust or change?
Andrew
draftsjust417(at)gmail.co Guest
Posted: Thu Sep 15, 2016 8:42 am Post subject: Housai CHT on shutdown |
Hello Andrew -
I thought I was the only one with cool-down issues!
My engine is a stock Housai, and I've found it helpful on these stubborn-CHT occasions (after I've run it at 1500 rpm for 15+ seconds) to open the oil cooler door and gill shutters wide, and keep the rpm at 1100-1200. It seems counterintuitive to run the engine at a higher rpm to cool it, but I figure its both circulating oil and forcing air over the cylinders, but on many occasions I've watched the CHT noticeably drop by doing this. Making sure your oil level is on the high end will help as well; for me this means at or above 13 on the stick.
Occasionally, on a very warm day, my CHT just will NOT come below 155/160-deg C, no matter what I've done. On these occasions I just shut down, and close the gill shutters to force the engine temp to drop more slowly to ambient, hopefully reducing the thermal stress.
Hopefully this is helpful-
Justin Drafts
N280NC
On Thu, Sep 15, 2016 at 12:04 PM, NebraskaYak <andrew.malousek(at)comcast.net (andrew.malousek(at)comcast.net)> wrote:
Quote: | --> Yak-List message posted by: "NebraskaYak" <andrew.malousek(at)comcast.net (andrew.malousek(at)comcast.net)>
Hi Guys,
Andrew
http://forums.matronics.com/viewtopic.php?p=460481#460481
wlannon(at)shaw.ca Guest
Posted: Thu Sep 15, 2016 9:09 am Post subject: Housai CHT on shutdown |
Try oil scavenge run 1 min at 1400 RPM with gills full open or some
variation thereof.
In summer I usually shut down at 150C or just under. Probably run out of
gas waiting for 140C.
Walt
Ernie
Posted: Thu Sep 15, 2016 9:10 am Post subject: Housai CHT on shutdown |
I find when I turn off the mag switch it cools off considerably
On Thursday, September 15, 2016, NebraskaYak <andrew.malousek(at)comcast.net (andrew.malousek(at)comcast.net)> wrote:
Quote: | --> Yak-List message posted by: "NebraskaYak" <[url=javascript:;]andrew.malousek(at)comcast.net[/url]>
Hi Guys,
Andrew
List" target="_blank">http://www.matronics.com/Navigator?Yak-List
lank">http://wiki.matronics.com
Clouddog
Posted: Thu Sep 15, 2016 10:24 am Post subject: Housai CHT on shutdown |
If OAT is 25C or above temp can VFR at 165C. Below 25C then 150C. Part of my before landing checklist besides gear mixture and prop is to open my shutters to get the engine cooled down.
On Sep 15, 2016 11:09 AM, "NebraskaYak" <andrew.malousek(at)comcast.net (andrew.malousek(at)comcast.net)> wrote: Quote: | --> Yak-List message posted by: "NebraskaYak" <andrew.malousek(at)comcast.net (andrew.malousek(at)comcast.net)>
Hi Guys,
Andrew
Viperdoc
Posted: Fri Sep 16, 2016 3:22 pm Post subject: Housai CHT on shutdown |
ROFLMAO!!
Doc
On Sep 15, 2016, at 12:09 PM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
Quote: | I find when I turn off the mag switch it cools off considerably
Hi Guys,
Andrew
_________________ Viperdoc |
Viperdoc
Posted: Fri Sep 16, 2016 3:25 pm Post subject: Housai CHT on shutdown |
Don't know about the CJ but the YAK M14 sitting I idling is not going below 150 unless it is raining.
That is in mine that is.
Doc
[quote] On Sep 15, 2016, at 12:09 PM, Walter Lannon <wlannon(at)shaw.ca> wrote:
Try oil scavenge run 1 min at 1400 RPM with gills full open or some variation thereof.
In summer I usually shut down at 150C or just under. Probably run out of gas waiting for 140C.
Walt
Harv
Posted: Fri Dec 23, 2016 1:13 pm Post subject: Re: Housai CHT on shutdown |
Out of interest what CHT are you guys shooting for during cruise flight, anywhere in the green???
Regardless I have my shutters fully open on takeoff and landing.
hess737(at)aol.com Guest
Posted: Fri Dec 23, 2016 1:18 pm Post subject: Housai CHT on shutdown |
I try to cruise at 175C and shutdown at 150C
Richard Hess
C 404-964-4885
http://forums.matronics.com/viewtopic.php?p=464279#464279
markdavis(at)wbsnet.org Guest
Posted: Fri Dec 23, 2016 1:37 pm Post subject: Housai CHT on shutdown |
High end of green in the winter for better cabin heat (in a YAK). Mid to
lower green to help keep oil temp down in summer.
Mark Davis
N44YK
Clouddog
Posted: Sun Dec 25, 2016 8:48 am Post subject: Housai CHT on shutdown |
170 is a good temp. Chinese even say 190. Wait till at least 150 before takeoff otherwise the engine can cough and sputter. Don't let it get too cool on landing in case of a go-around but definitely full open after landing assured so it will cool down before shutdown. 165 above 25C and 150 below 25C on shutdown.
On Dec 23, 2016 4:19 PM, "Harv" <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)> wrote: Quote: | --> Yak-List message posted by: "Harv" <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)>
br> fts!)
r> > com" rel="noreferrer" target="_blank">www.aeroelectric.com
w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com
e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
" rel="noreferrer" target="_blank">www.mrrace.com
Posted: Mon Dec 26, 2016 6:25 am Post subject: Housai CHT on shutdown |
'Morning,
In my CJ in cool temps of Seattle, I keep my gills open fully on T/O, then I let throttle position determine gill position on approach and landing. Dragging in low w/ power means gills open, while throttle to idle means gills (typ) closed to prevent rapid / shock cooling cylinders.
In cruise I like to let my Housai settle between 185 (lowest) to 195-deg C, running 590 mm MAP at about 2050 rpm. Seems to keep me running about 12.5 gal/hr.
I use 20W50 X/C oil, btw.
Hope this helps...
Justin Drafts
N280NC
On Friday, December 23, 2016, Harv <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)> wrote:
>      (And Get Some AWESOME FREE Gifts!) Builder's Bookstore www.build   * My Pilot Store ht                 -Matt Dralle, List Admin.
Clouddog
Posted: Tue Dec 27, 2016 5:39 am Post subject: Housai CHT on shutdown |
Harv, on a side note. If you live in a place where you experience lower OAT's, you will be using your engine temps to help control your oil temp. In the winter after you have closed your oil cooler door and restricted the air coming into the cooler at the intake on the wing, you may be find you will need to run your engine temp in the high green just to keep the oil temp in the green. It works in reverse on very hot summer days. A lot of money motions going on sometimes to keep oil and engine temps where they need to be.Â
On Dec 23, 2016 3:19 PM, "Harv" <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)> wrote: Quote: | --> Yak-List message posted by: "Harv" <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)>
br> fts!)
