davevanlanen(at)sbcglobal Guest
Posted: Mon Jan 16, 2006 7:18 pm Post subject: Proper Deburring Technique |
I have a procedural question regarding deburring. How much is enough in
terms of material removed? If I use the file technique with a light touch
to avoid scratches, or if I use the drill bit technique with minimal turns
to avoid countersinking, it will take off the noticeable burrs. However, if
I run my fingernail towards the hole, there is still a slight "ridge" right
at the edge of the hole. Do I need to get all of this material off, so that
there is absolutely no "raised" area at all? If I do that with the file, it
tends to scratch the surface. If I try to remove it with additional turns
of the drill bit, it looks like it may be starting to countersink the hole,
which I know you're not supposed to do.
Any advice for me?
Dave Van Lanen
Madison, WI
601 XL
Posted: Mon Jan 16, 2006 7:55 pm Post subject: Proper Deburring Technique |
Hi Dave,
I think it is important to take off all the raised area around the
hole so the pieces of sheet metal mate completely. As I understand
it, this is not so important where the rivets mate to the holes, but
I try to get that area flat too.
I don't think light scratches are a problem, so I don't worry about
them. I just use a smooth file and let the scratches come along with
the burrs. I intend to paint my plane anyway, so the scratches will
disappear under the paint.
Good luck,
Paul
XL wings
At 07:17 PM 1/16/2006, you wrote:
Quote: |
<davevanlanen(at)sbcglobal.net>
Any advice for me?
Dave Van Lanen
Madison, WI
601 XL
Kevin Bonds
Joined: 09 Jan 2006 Posts: 171 Location: Nashville, Tn
Posted: Mon Jan 16, 2006 10:39 pm Post subject: Proper Deburring Technique |
Dave
I have toiled over this one as well. Don't feel alone. I have come to the
conclusion that there is no perfect method. I use the drill bit and try not
to countersink, but always seems to be, as you say, "starting to
countersink" on me too. I just try not to overdo it, but still remove all
that is raised. Both methods worry me as it seems the scratches from the
file, as well as the stopping and starting of the drill bit (which can leave
tiny gouges), could lead to cracks. Also doesn't seem too many Zodie's are
falling out of the sky because of this and I figure my technique is as good
as the next guys. Reckon surely it can't be the absolute worst at least.
Anyway this is what helps me sleep at night.
Kevin Bonds
Nashville TN
601XL Corvair powered; Plans building.
Empennage done; working on wings and engine.
http://home.comcast.net/~kevinbonds
do not archive DO NOT ARCHIVE
_________________ KevinBonds
Nashville, TN
Plans-building Zenith CH601XL w/Corvair Power
http://home.comcast.net/~kevinbonds |
Kevin Bonds
Posted: Mon Jan 16, 2006 11:08 pm Post subject: Proper Deburring Technique |
Quote: | I figure my technique is as good as the next guys.
Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
BTW regarding my last post: I call that my "faster than a bear philosophy".
In case of bear attack, you don't have to be able to outrun a bear, just
need to run faster than the guy next to you.
Kevin Bonds
Nashville TN
Nashville, TN
Gbrac80(at)aol.com Guest
Posted: Tue Jan 17, 2006 3:16 am Post subject: Proper Deburring Technique |
MSC (_www.mscdirect.com_ (http://www.mscdirect.com) ) sells a large variety
of deburring tools for internal and external radii, for less than ten
dollars. These comprise a handle with a swiveling deburring blade that removes the
burr with a simple rotary motion of the wrist.
Rgfd,
Mike.
shilocom(at)mcmsys.com Guest
Posted: Tue Jan 17, 2006 5:19 am Post subject: Proper Deburring Technique |
I know zenith likes the file method, but over the years I've found that the
rotary tool that looks like a countersink tool on an offset screw driver
handle is the best. In my opinion you don't need to remove the raised area
around the hole, because this area will be reformed in the riveting process.
My way of doing is run your finger over it and if it feels smooth it's ok.
This opinion comes from buck riveting and should mostly apply to Pop
riveting. bob U.
Be a little careful, most scratches, and especially those that you can feel
don't "disappear under the paint". If you remove the ridge you will most
likely increase the size of the hole and fit up of any rivet is important to
it's strength. bob U.
Larry McFarland
Joined: 10 Jan 2006 Posts: 36 Location: East Moline, Illinois
Posted: Tue Jan 17, 2006 6:47 am Post subject: Proper Deburring Technique |
Dave,
Get yourself a deburring tool with a swiveling tip. Insert it in the
hole and pull it around the hole deburing
one side. Remove only enough to get rid of the burr. Files and drills
are seldom a complete solution to removing
edge ridges and burrs. The deburing tool will do it all with
considerably less effort and potential damage.
You only need to remove enough to be able to draw your finger across an
edge without sensing a sharp one.
Larry McFarland - 601HDS
Any advice for me?
Dave Van Lanen
Madison, WI
601 XL
_________________ Larry McFarland - 601HDS - Stratus |
lrepilot(at)yahoo.com Guest
Posted: Tue Jan 17, 2006 8:56 am Post subject: Proper Deburring Technique |
The Vargus deburring tool described by several people is great when the hole size is very large (1/2 inch or better) but is not terribly good for 1/8 rivet holes. What I have done for these is to get a sponge rubber sanding block from Home Depot or Lowes, and use it on the concrete floor to break it in (almost wear it out). It then works great for the long rows of rivets. It also is very effective for smoothing the sheared edges of the parts. It leaves a polished finish on the aluminum and the holes are as clean as they can be.
Ken
Empennage 90%
Larry McFarland <larrymc(at)qconline.com> wrote:
Dave,
Any advice for me?
Dave Van Lanen
Madison, WI
601 XL
Got holiday prints? See all the ways to get quality prints in your hands ASAP.
