clouduster(at)austin.rr.c Guest
Posted: Mon Jul 10, 2006 2:25 pm Post subject: External voltage regulator Connections |
I converted my RX-8 computer controlled alternator (100 amp) to
externally regulated. I purchased an Auto Zone VR 749 external
regulator for a 100 amp alternator. I have a question on how to connect
the regulator to the system.
This is my best guess for the four pins - I, A, S , and F- on the regulator.
1). F on regulator goes to ungrounded brush in alternator.
2) A and S pins on regulator tie together and get fed from 5 amp breaker
and switch.
3). I have no clue about the I pin on the regulator - I'm guessing it
is either an indicator light feed or connects to the ignition switch.
4). The B terminal on the alternator connects to the + at the contactor.
Anyone have better information?
Dennis H.
nuckollsr(at)cox.net Guest
Posted: Mon Jul 10, 2006 6:51 pm Post subject: External voltage regulator Connections |
At 05:22 PM 7/10/2006 -0500, you wrote:
<clouduster(at)austin.rr.com>
externally regulated. I purchased an Auto Zone VR 749 external regulator
for a 100 amp alternator. I have a question on how to connect the
and switch.
3). I have no clue about the I pin on the regulator - I'm guessing it is
Leave "I" unconnected.
The VR-749 is one of several versions of the generic "Ford"
regulator described in Note 21 and Figure Z-23 of
http://aeroelectric.com/articles/Rev11/AppZ_R11H.pdf
| Quote: | 4). The B terminal on the alternator connects to the + at the contactor.
yes.
< with experiment. >
< --Lawrence M. Krauss >
FLYaDIVE(at)aol.com Guest
Posted: Tue Jul 11, 2006 3:42 am Post subject: External voltage regulator Connections |
In a message dated 7/10/06 6:27:51 PM Eastern Daylight Time,
clouduster(at)austin.rr.com writes:
| Quote: | Anyone have better information?
Dennis H.
Dennis:
I = INDICATOR
A = ALTERNATOR
S = SWITCH
F = FIELD
BULB/LED GOES TO I AND TO +12 VDC ALT FIELD
Go to the ZIFTRONICS website and download their instruction sheet.
Barry
"Chop'd Liver"
Posted: Tue Jul 11, 2006 5:29 am Post subject: External voltage regulator Connections |
and switch.
yes.
Posted: Wed Jul 12, 2006 5:03 am Post subject: External voltage regulator Connections |
Thanks for the advice on connecting the external regulator. I wound up
using Bob's Z-23 regulator connection diagram. The alternator is
working great!.
Thanks Again!
Dennis H.
