jeffpoint
Posted: Sat Jul 08, 2006 10:19 am Post subject: non-swiveling tail wheel |
Does anyone know how much travel the old style non-swiveling tail wheels
had? I'm looking for degrees side to side from center.
Jeff Point
RV-6
Milwaukee
_________________ Jeff Point
RV-6
Milwaukee WI |
pbesing(at)yahoo.com Guest
Posted: Sat Jul 08, 2006 9:38 pm Post subject: non-swiveling tail wheel |
It will go 90, but not much more than that before the
chains bind up. Another words, the chains are the
limiting factor..the will swivel but the chains
inhibit the movement. Will be upgrading to swivel
tailwheel soon!
Paul Besing
--- Jeff Point <jpoint(at)mindspring.com> wrote:
center.
Jeff Point
RV-6
Milwaukee
browse
Subscriptions page,
FAQ,
Admin.
flyrv6(at)bryantechnology Guest
Posted: Sun Jul 09, 2006 7:30 pm Post subject: non-swiveling tail wheel |
How do you identify the non-swivel by looking at it and what is involved in replacing it to a swivel type? My fuse kit was purchased in 1993. I don't believe my tailwheel will swivel. Something I only recently discovered when I installed my chains. I plan to remove them this weekend to find out if I can swivel and am bound up or doesn't swivel. (Then throw the chains away and install tail lynx system)
Tim RV-6
[i]----
Posted: Mon Jul 10, 2006 10:23 am Post subject: non-swiveling tail wheel |
OK, you can disregard this question. A call to Van's answered the question. Kits earlier than about 96/97 came with a non-swivel tail wheel. I just ordered the conversion for mine. What a drag, replacing parts on mine before they are even used. I would not have been happy with a non-swivel however.
[i]----
Posted: Mon Jul 10, 2006 11:31 am Post subject: non-swiveling tail wheel |
Good move. I have the old tailwheel and it's a real
pain when pushing back into my hangar..have to use a
tow bar. Then, when I'm out somewhere away from the
airport it can be frustrating moving the airplane
around! I'll be upgrading to the Bell Tailwheel
assembly soon.
Paul Besing
--- Tim Bryan <flyrv6(at)bryantechnology.com> wrote:
[quote] OK, you can disregard this question. A call to
however.
cgreimer(at)mts.net Guest
Posted: Thu Jul 13, 2006 4:04 pm Post subject: non-swiveling tail wheel |
I think anyone upgrading to a Van's swivel tailwheel, or indeed anyone who
hasn't flown one, should be aware of it's foibles:
1) It requires regular greasing, and the only way to grease it properly is
to dissassemble it. This isn't hard but I have to do mine every 10 hours or
so.
2) The little internal key that locks/unlocks the tailwheel eventually
develops burrs and then sticks, allowing the tailwheel to stay unlocked. The
solution is to file down the burrs and then slightly chamfer the edges of
the key to prevent new burrs. You may as well do this right away instead of
waiting for it to stick unexpectedly at some distant airport. Since I fixed
mine the first time, it has been fine.
3) The design feature that allows the tailwheel to free swivel after
depressing the rudder pedal about 3/4 down works really well most of the
time. It has a spooky side though. On a couple of occasions I have been
taxiig on a slippery surface with a stiff crosswind, and order to counteract
a gust, I kicked full or nearly full rudder. This caused the tailwheel to
unlock, and without the tailwheel helping to hold it straight anymore, the
airplane immediately weathervaned into the wind and I was suddenly 90
degrees to the runway going 10 mph. Because the runway was snowy and
slippery the brakes were not effective either, so off the runway I went,
completely out of control. Luckily both times I only got stuck.
Perhaps the Bell tailwheel alleviates some or all of these problems. I'm
planning to get one myself, if only for the new/coolness factor.
Curt
RV-6 C-GACR
Posted: Thu Jul 13, 2006 5:14 pm Post subject: non-swiveling tail wheel |
Yikes Curt,
This doesn't paint a very pretty picture. Every 10 hours? That could be after every trip. My new one is supposed to be delivered tomorrow for a weekend install.
Question for all the other tail wheelers. Are any of you using something other than Van's swivel tailwheel? Why? Are you happy with it?
[i]----
dcw(at)mnwing.org Guest
Posted: Thu Jul 13, 2006 5:38 pm Post subject: non-swiveling tail wheel |
Gee, folks.. I have 300 hours on my Van’s tailwheel and have had no significant problem. I grease it about every 6 months or so and have replaced the bearings once and the actual tire once. Other than that, it works perfect.
Doug Weiler
N722DW, RV-4, 300 hours
On 7/13/06 8:04 PM, "Tim Bryan" <flyrv6(at)bryantechnology.com> wrote:
[quote]Yikes Curt,
[i]----
flyby41(at)earthlink.net Guest
Posted: Thu Jul 13, 2006 5:39 pm Post subject: non-swiveling tail wheel |
Been using the "Homebuilders Special Tailwheel" as depicted in Aircraft Spruce catalogue but available from the manufacturer as well as other dealers. I have the single fork 6" model on my 4. It has worked flawlessly for approx. 1000 hours with no unusual maintenance and even perhaps some neglect.
n5lp(at)warpdriveonline.c Guest
Posted: Thu Jul 13, 2006 6:48 pm Post subject: non-swiveling tail wheel |
On Jul 13, 2006, at 7:04 PM, Tim Bryan wrote:
| Quote: | Yikes Curt,
with it?
I have the standard Van's full swivel tailwheel. Once or maybe
twice, in 800 hours, it has failed to lock into the steering detent.
I think it was a bit of grit fouling it up, in my case.
Every 75 or 100 hours the steering gets a bit stiff and I have to
regrease it.
I admire the simplicity and economy of the device compared to what
Scotts puts out.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
http://n5lp.net
bicyclop(at)pacbell.net Guest
Posted: Thu Jul 13, 2006 7:58 pm Post subject: non-swiveling tail wheel |
So who is the manufacturer?
Pax,
Ed Holyoke
Posted: Thu Jul 13, 2006 10:51 pm Post subject: non-swiveling tail wheel |
Aviation Products Inc.
114 Bryant St.
Ojai, CA 93023
ph/fax 805-646-6042
rv8_flyer(at)yahoo.com Guest
Posted: Fri Jul 14, 2006 4:14 am Post subject: non-swiveling tail wheel |
I has a couple issues with the tail wheel not locking in the first 50 hours on my plane. When I called and talked to Van's about it they said don't use grease use oil. So I took it apart, cleaned and polished the burrs and drilled a small hole in the top washer. I now shoot a little LPS 2 into the hole every 10 hours or so and disassemble it at annual to clean and inspect for burrs. For the last 300 hours it has been trouble free.
Alan Kritzman
RV-8 N8EM
Larry Pardue <n5lp(at)warpdriveonline.com> wrote:
[quote]--> RV-List message posted by: Larry Pardue
[quote] Yikes Curt,
could be after every trip. My Yahoo! Music Unlimited - Access over 1 million songs. [url=http://pa.yahoo.com/*http://us.rd.yahoo.com/evt=36035/*http://music.yahoo.com/unlimited/ ]Try it free.[/url]
Steve Glasgow
Posted: Fri Jul 14, 2006 7:03 am Post subject: non-swiveling tail wheel |
I agree Curt. I grease mine with every oil change. I have the Bell tailwheel and love it, but in regards to swivel, it works the same way as the Van's. Don't know if you are using the one arm device or not, but I believe the one I was using was exacerbating the problem and have removed it for the new stainless Van's two arm device. I feel the one arm seems to bur the pin more than the two arm type. No suppresses in the last 50 hours.
Steve Glasgow-Cappy
N123SG RV-8
Cappy's Toy
_________________ Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG |
Alan,
This sounds like a reasonable solution. Grease can tend to collect dust and become sticky. Oil would do the same thing but doesn't last as long. Great idea.
[i]----
Posted: Wed Jul 19, 2006 5:46 pm Post subject: non-swiveling tail wheel |
To clarify my post, I find the main pivot itself sticks unless I grease it every 10 hours. I can still move it, but it's very stiff, and when I remove it to grease it, it's dry as a bone.
The locking key on the other hand has been fine since the first de-burring repair hundreds of hours ago.
Perhaps my problems come from flying off grass almost exclusively. It's been pretty wet here the past couple of summers and I thought the water was washing the grease away. I went though a set of front wheel bearings (rusted) after only 140 hours my first year. But this summer has been dry and I still have to grease the tailwheel.
I should give the design it's due: it is an elegant, simple and lightweight mechanism for what it does and seems to give trouble-free use for a lot of people.
Curt
