RichWill
Joined: 24 Feb 2006 Posts: 24 Location: Southern Maine
Posted: Sun Jul 09, 2006 3:18 pm Post subject: 2 Questions : Water Temp and Interior Pieces |
List,
I have a Rotax 912UL - with Evans NPG - water temp is running 200-230F, does this sound right or too hot?? Oil temp is running 190-230 (normal).
My oil cooler is on top of the motor, probably should be out front, and I've taken out the cabin heater for the summer.. (would this have any increase in temp effect)?
Also, understand there is someone in Arizona who can make interior panels for the KF? I need the cover for behind the seats, the one that has the zippered corners.. does anyone know of the business/person?
Thank you...
pwmac(at)sisna.com Guest
Posted: Sun Jul 09, 2006 4:05 pm Post subject: 2 Questions : Water Temp and Interior Pieces |
Isn't the redline CHT 300F? 230 sounds Ok to me.
Paul
At 05:18 PM 7/9/2006, you wrote:
List,
190-230 (normal).
Thank you...
Semper Fi
15 ITT
G2 HqCo HqBn
1st MarDiv
http://forums.matronics.com/viewtopic.php?p=45949#45949
lcfitt(at)sbcglobal.net Guest
Posted: Sun Jul 09, 2006 5:14 pm Post subject: 2 Questions : Water Temp and Interior Pieces |
Rich, I don't really know what is "normal", but my temps are pretty
consistent at 180°. In the past, I put tape on the radiator during the
winter months. I do have the Kitfox radiator shroud.
Lowell
RichWill
Posted: Mon Jul 10, 2006 8:43 am Post subject: Re: 2 Questions : Water Temp and Interior Pieces |
Paul,
300F max on the CHT is right... IF the CHT and Cyl Water Temp have a direct corelation...then I am okay at 230! Just not sure if they do..
thanks
