vk3eka(at)bigpond.net.au Guest
Posted: Fri Oct 14, 2016 1:44 pm Post subject: O-200 Engine Tightness |
Hi Guys,
I have noticed that directly after flying my O-200 powered Zodiac 601XLB that when turning the prop over, it seems to be tight.
I recently finished an annual and found some metal filings in the oil filter. I stripped the engine and replaced the crankshaft gear cluster and added a new starter gear.
During the stripping of the engine I noticed the bearings were slightly discoloured. The engine has 180 hours since a major rebuild.
I had the engine parts inspected by the local engine shop and he found I hadn't used the two special bolts to hold the crankcase halves in alignment.
He checked all the clearances (all good) and reassembled the engine halves and the cylinders for me including the two special bolts.
I re-installed the engine and all is working well but I still find the engine stiff to turn over after flight.
The oil temp stays around 180 F and power is good. It doesn't seem to make any difference whether I fly for an hour or for 20 minutes.
After the engine has cooled the tightness disappears.
Is there anything I should be looking at?
Peter
Wonthaggi Australia
| | - The Matronics Continental-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Continental-List |
jack(at)bedfordlandings.c Guest
Posted: Sat Oct 15, 2016 5:03 am Post subject: O-200 Engine Tightness |
Peter, the A65 on my Pietenpol is the same. It is much looser when cold, and after flying for a short while is noticeably tighter. Mine has about 375 hours SMOH. I think that is just a characteristic of the small Continentals.
Jack Phillips
Smith Mountain Lake, Virginia
From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of Peter Johnson
Sent: Friday, October 14, 2016 5:41 PM
To: continental-list(at)matronics.com
Subject: O-200 Engine Tightness
Hi Guys,
Peter
Wonthaggi Australia
Posted: Sat Oct 15, 2016 3:26 pm Post subject: O-200 Engine Tightness |
Jack,
Thanks for that. A little piece of mind.
I haven’t noticed the same on my A65 powered Piet but that may have more hours on it and loosened up a bit more.
Cheers
Peter
Wonthaggi Australia
From: <owner-continental-list-server(at)matronics.com> on behalf of Jack Philips <jack(at)bedfordlandings.com>
Reply-To: <continental-list(at)matronics.com>
Date: Sunday, 16 October 2016 at 12:02 am
Subject: RE: O-200 Engine Tightness
Jack Phillips
Hi Guys,
Peter
Wonthaggi Australia
stephencliverichards(at)g Guest
Posted: Tue Oct 18, 2016 9:46 am Post subject: O-200 Engine Tightness |
Our 0200 is the same 80 hours after replacing barrels and pistons
Sent: ‎16/‎10/‎2016 00:28
To: continental-list(at)matronics.com (continental-list(at)matronics.com)
Subject: Re: O-200 Engine Tightness
Jack,
Cheers
Peter
Wonthaggi Australia
Jack Phillips
Hi Guys,
Peter
Wonthaggi Australia
Posted: Tue Oct 18, 2016 1:04 pm Post subject: O-200 Engine Tightness |
Thanks Steve
Peter
On 19 Oct. 2016, at 4:46 am, Stephen Richards <stephencliverichards(at)gmail.com (stephencliverichards(at)gmail.com)> wrote:
| Quote: | Our 0200 is the same 80 hours after replacing barrels and pistons
Subject: Re: Continental-List: O-200 Engine Tightness
Jack,
Cheers
Peter
Wonthaggi Australia
From: <owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com)> on behalf of Jack Philips <jack(at)bedfordlandings.com (jack(at)bedfordlandings.com)>
Reply-To: <continental-list(at)matronics.com (continental-list(at)matronics.com)>
Subject: RE: Continental-List: O-200 Engine Tightness
Jack Phillips
From: owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com) [mailto:owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com)] On Behalf Of Peter Johnson
Hi Guys,
Peter
Wonthaggi Australia
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
