N345JS(at)verizon.net Guest
Posted: Sun Oct 09, 2016 11:55 am Post subject: nose wheel fork issues |
Need help with 2 issues with my nose wheel fork. The 9/16 threads on the right side of the nose wheel fork are worn out so the axle attach bolt just passes thru the nose fork and threads into the axle. Result is some play on the axle and uneven nose tire wear. Can a machine shop install new metal insert and tap the threads to 9/16th? Is there some other repair? Or should I try to replace the nose wheel fork which is otherwise OK?? Where find replacement?
The 2nd issue is the 2 aluminum spacers that slide over the axle has worn down on the ends, become shorter, so when the nose wheel tire is fully inflated, the tire scrapes on the inside of the nose wheel fork. Where can I get new (bit longer) aluminum spacers on the axle?? What would be the specs of those spacers if shopping for them?? I am stumped and grounded, appreciate any helpful information.
John Schussler
Pulsar XP N345JS
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Pulsar-List |
esalehto(at)yahoo.com Guest
Posted: Sun Oct 09, 2016 3:05 pm Post subject: nose wheel fork issues |
John, share some photos so we can see your issues.
Esa,
Pulsar XP
From: John Schussler Pulsar XP N345JS (N345JS(at)verizon.net)
Sent: ‎10/‎9/‎2016 15:42
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Subject: nose wheel fork issues
John Schussler
Pulsar XP N345JS
