Rough running 912 UL
Goto page Previous  1, 2
FoesFlyDennis
PostPosted: Sat Sep 10, 2016 3:04 pm    Post subject: Rough running 912 UL Reply with quote
Thanks Hugh for letting us know what it was. I have learned a lot while
following your thread, especially now that the problem is solved.
On Sep 10, 2016 2:15 PM, "Hugh McKay" <hgmckay(at)bellsouth.net> wrote:
[quote] Gentlemen (bjones,jelling Catz631 h&amp, Jeff Wemmelring, Bick Girard,
John Hauck, Lowell Fitt, Dee LeBlanc, GHeal, et al)
Well I found what was causing my rough running engine!! I am some what
embarrassed, but it demonstrates how careful one must be when doing
anything to a Rotax 912 series engine. All this started when I began to
hear excessive engine noise in my head sets when transmitting on my radio
2012 Pulsar III - Jabiru 2200A - N852LW
DennisTubbs7@gmail.com
Mesa, Arizona
rickofudall
PostPosted: Sat Sep 10, 2016 3:10 pm    Post subject: Rough running 912 UL Reply with quote
Hugh, Wow! That's great. Always happy to learn of a successful repair,
especially one where the price is so right. Now go out there and do some
flying.
Blue skies,
Rick
On Sat, Sep 10, 2016 at 4:06 PM, Hugh McKay <hgmckay(at)bellsouth.net> wrote:
dashwoodlock(at)yahoo.ca
PostPosted: Sat Sep 10, 2016 6:16 pm    Post subject: Rough running 912 UL Reply with quote
i had a seriouse failure one day. after a short flight i landed. shut down for a couple minutes then took off again for 45min flight. this time engine would not shut down. i was too clos to obsticals so was stuck at idlel till ground personel could spin me around. i had shut off fuel but at idle she was still running 10 minutes in. turned out i had lost one od the screws that holds aft end of modules on top of engine. so modules were not grounding proper. replaced missing fastener and was all good.
To: <rotaxengines-list(at)matronics.com>;
Subject: Re: Rough running 912 UL
Sent: Sat, Sep 10, 2016 11:09:35 PM
Hugh, Wow! That's great. Always happy to learn of a successful repair, especially one where the price is so right. Now go out there and do some flying.
Blue skies,
Rick
On Sat, Sep 10, 2016 at 4:06 PM, Hugh McKay <[url=javascript:return]hgmckay(at)bellsouth.net[/url]> wrote:
Gentlemen (bjones,jelling Catz631 h&amp, Jeff Wemmelring, Bick Girard, John Hauck, Lowell Fitt, Dee LeBlanc, GHeal, et al)
Well I found what was causing my rough running engine!! I am some what embarrassed, but it demonstrates how careful one must be when doing anything to a Rotax 912 series engine. All this started when I began to hear excessive engine noise in my head sets when transmitting on my radio. Well, if you read my earlier questions regarding the engine noise you will recall that I was advised (good advice)to first check all the grounds. This I did and found no bad grounds. In the course of checking the grounds there are two grounding points on the right side of the ignition modules where two screws screw down into the engine. One of these ground points has two ground wires attached to it. The other has three ground wires attached. I removed these grounds, cleaned them and reattached them to their proper screw location; or I thought I had. Well, after looking carefully at the top of the engine at these two ground points and feeling all of the wires in that area I found two loose black wires with a common ring terminal tucked under the intake manifold on that side of the engine. Well what a surprise!! Then I began to think, how can that be?? Then I noticed that these two wires with the common ring terminal exactly fit one of the two ground points I have just described. I then realized that I had pushed the end of this double ground wire with the common ring terminal under the manifold to get better access to clean the ground point. What I did not remember when it came time to reattach all the wires was that I had tucked this ground wire out of sight. I reattached all the “visible” ground wires forgetting I had tucked one out of sight.
Lesson learned! Make sure you know how many wires you have disconnected, and reconnect the “same” number.  Anyway, I am back flying and the engine is running fine. Flew down to the big Triple Tree Fly-In just below Woodruff, SC today with out a problem except the noise in my radio which is another story. Many thanks for all of your suggestions. I value them and your willingness to share.
Hugh G. McKay III, P.E. Fellow, L.M. ASCESenior ConsultantWorldwide Engineering Inc.4090 North NC Hwy. 16Denver, NC 28037Ph. [url=javascript:return]hgmckay(at)bellsouth.net[/url]http://www.wwegeo.com
Sent: Thursday, September 08, 2016 6:05 PM
To: [url=javascript:return]rotaxengines-list(at)matronics. com[/url]
Subject: RE: Rough running 912 UL
Might be a good time to replace the connectors.  Those have been rapid wear parts on my three 912s.  They can be bought from Sparkplugs.com by getting the part number off of a connector.  Price is a quarter what Rotax wants for them.
Burns Junction, Oregon
From: owner-rotaxengines- list-server(at)matronics.com (owner-rotaxengines-list-server(at)matronics.com)] On Behalf Of Richard GirardSent: Thursday, September 08, 2016 3:25 PMTo: [url=javascript:return]rotaxengines-list(at)matronics. com[/url]Subject: Re: RotaxEngines-List: Rough running 912 UL
Hugh, Old mechanics proverb, "90% of carburetor problems are solved in the ignition system". That being said, have you checked the resistance of your spark plug wires? Since you'll have to re-seat the wires anyway, take the time to trim each end about 1/4" so that the screw connector has a chance to seat into fresh, un-corroded wire. Also check the screws themselves for signs of corrosion. Unless the wires are too short afterward this check won't cost you anything but your time. Almost all the information you need is available in the Heavy Maintenance Manual section 74-00-00.
Rick
-- “Blessed are the cracked, for they shall let in the light.”   Groucho Marx
vernon11
PostPosted: Sun Sep 11, 2016 2:39 am    Post subject: Rough running 912 UL Reply with quote
Fantastic you found the problem Hugh. When I do work like that, I always take a picture. It has helped many times.
Vernon.
Sent: Saturday, September 10, 2016 11:06 PM
To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
email hgmckay(at)bellsouth.net
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Richard Girard
Rick
Dick Maddux
PostPosted: Sun Sep 11, 2016 5:31 am    Post subject: Rough running 912 UL Reply with quote
Dashwoodlock,
I too had a similar problem. I pulled up to the airport ,people came out to look at my plane and the engine wouldn't shut down with the"mag" switch so I waved taxied out ,took off and flew back to my grass strip . I shut the fuel off and like you it took forever for the engine to quit. In my case it turned out that the "p" lead wire had pulled loose from the connector at the module.
Stuff always happens !
Dick Maddux
912 UL
PS: Hugh ,thank you for your story as it will be filled in the "what to look for" part of my brain(the little that is left !)
rascaljohn
PostPosted: Sun Sep 11, 2016 10:04 am    Post subject: Rough running 912 UL Reply with quote
Hello, I have watching the conversation about the rough running 912 and noticed that a "Lowell Fitt" was listed as part of the contributors. My name is John Fitt- wondering if we are related, as our name is not that common. We live in northern calif., relations originally from Canada. Just wondering...
John Fitt
707.823.2860
Sent from my iPad
On Sep 10, 2016, at 2:06 PM, Hugh McKay <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)> wrote:
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
email hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
From: owner-rotaxengines-list-server(at)matronics.com (owner-rotaxengines-list-server(at)matronics.com) [mailto:owner-rotaxengines-list-server(at)matronics.com (owner-rotaxengines-list-server(at)matronics.com)] On Behalf Of Richard Girard
Rick
lcfitt3(at)gmail.com
PostPosted: Sun Sep 11, 2016 4:17 pm    Post subject: Rough running 912 UL Reply with quote
Private email sent
On Sun, Sep 11, 2016 at 11:03 AM, jpfitt <jpfitt(at)sbcglobal.net> wrote:
[quote] Hello, I have watching the conversation about the rough running 912 and
wondering...
John Fitt
707.823.2860
Sent from my iPad
Page 2 of 2
