Rear seat vents handle
trigo(at)mail.telepac.pt
PostPosted: Sat Aug 06, 2016 2:31 pm    Post subject: Rear seat vents handle Reply with quote
Guys
In the 2 rear seat vents, what did you use as handles?
Carlos
Enviado do meu iPhone
Bob Turner
PostPosted: Sat Aug 06, 2016 2:56 pm    Post subject: Re: Rear seat vents handle Reply with quote
I used a piece of wood dowel, about 1" long, drilled and tapped down the middle (the long way). Not elegant but works fine.
Bob Turner
RV-10 QB
carl.froehlich(at)verizon
PostPosted: Sat Aug 06, 2016 3:14 pm    Post subject: Rear seat vents handle Reply with quote
No handles other than the tabs as made. Works for me.
Carl
On Aug 6, 2016, at 6:30 PM, Carlos Trigo <trigo(at)mail.telepac.pt> wrote:
Guys
Carlos
Dave Saylor
PostPosted: Sat Aug 06, 2016 3:15 pm    Post subject: Rear seat vents handle Reply with quote
I just took the two layers that form the  aluminum tab and bent them 90* to make something to grip/push.
-Dave
On Saturday, August 6, 2016, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
[quote]--> RV10-List message posted by: Carlos Trigo <[url=javascript:;]trigo(at)mail.telepac.pt[/url]>
Guys
Carlos
--Dave
KWVI
Greg McFarlane
PostPosted: Sun Aug 07, 2016 1:15 am    Post subject: Re: Rear seat vents handle Reply with quote
Good quality key rings work a treat, drill one hole, easily fitted, good grip, light weight. Cheers from Western Australia
Greg McFarlane
Good quality key rings work a treat, drill one hole, easily fitted, good grip, light weight. Cheers from Western Australiauj
PostPosted: Tue Aug 09, 2016 1:58 am    Post subject: Rear seat vents handle Reply with quote
Thank you David
You probably remember that I flew in your RV-10, but I was in the front right seat, so I didn’t see your rear seat vents.
I miss California and those good beaches…
Carlos
De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de David Saylor
Enviada: Sunday, August 7, 2016 12:16 AM
Para: rv10-list(at)matronics.com
Assunto: Re: Rear seat vents handle
-Dave
Guys
Carlos
Enviado do meu href="http://www.matronics.com/Navigator?RV10-List" -->
PostPosted: Tue Aug 09, 2016 2:01 am    Post subject: Rear seat vents handle Reply with quote
Greg
Thank you for a really simple idea, but it seems that the key rings would
not be so good for pushing as for pulling the vents.
Cheers
Carlos
-----Mensagem original-----
[mailto:owner-rv10-list-server(at)matronics.com] Em nome de Greg McFarlane
Enviada: Sunday, August 7, 2016 10:16 AM
--> <grbcmcfarlane(at)gmail.com>
http://forums.matronics.com/viewtopic.php?p=459284#459284
