Batteries
BobbyPaulk(at)comcast.net
PostPosted: Mon Jul 25, 2016 11:45 am    Post subject: Batteries Reply with quote
Getting back to the Odessy PC680 for a moment.
My first one was purchased in late 2006, removed in 2011 on general principal ( over 4 yrs old. ).
I removed it and installed it in my lawn mower and it is still going strong ( 10 years ).
I just removed my second one over 5 years old because it was too weak to crank after years of cranking a very hard starting engine. Many times I ran it down and had to re-charge it in cooler weather. I fixed the hard starting so I do not anticipate any similar problems.
Odyssey says 3 ~ 10 years service life so we will see.
Bobby ( age 77 )
Zodiac 601 XL "B"
Jabiru 3300 S/N 1141
Sensenich 64" x 51" Prop
Status - Flying 268 hrs.
markdonahue
PostPosted: Mon Jul 25, 2016 4:08 pm    Post subject: Batteries Reply with quote
My Odyssey PC 680 battery in my RV-9A failed to start the engine after two years in service.  I removed to the dealer and after bench testing the CCA were down to 70 amp.  A new battery solved the problem, but I was disappointed in the short life.  I did not have it on a charger and never ran it down.  It was just past the 24 month warranty.
Hopefully the new one will last longer.
Mark Donahue
RV 9A
300 hours.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of BobbyPaulk(at)comcast.net
Sent: Monday, July 25, 2016 12:43 PM
To: aeroelectric-list
Subject: Batteries
Bobby ( age 77 )
Zodiac 601 XL "B"
Mark Donahue
jmjones2000(at)mindspring
PostPosted: Mon Jul 25, 2016 11:55 pm    Post subject: Batteries Reply with quote
Mark,
Make sure you verify battery charging voltage. Low charging voltage (in the 13s) can cause premature battery failure on the AGM batteries.
Justin
On Jul 25, 2016, at 16:06, Mark Donahue <marktdonahue(at)comcast.net (marktdonahue(at)comcast.net)> wrote:
<![endif]--> <![endif]-->
Mark Donahue
RV 9A
300 hours.
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)
Subject: Batteries
Bobby ( age 77 )
Zodiac 601 XL "B"
Mauledriver(at)nc.rr.com
PostPosted: Tue Jul 26, 2016 4:06 am    Post subject: Batteries Reply with quote
I would 2nd that suggestion having had a lot of experience ruining multiple Odyssey 680s.
 My RV10 carries 2 of them.  I had one operating on a bus that ran at 13.4 volts and one on a buss that  runs at 14.5+.  The batteries on the 13.4 volt circuit lived less than 2 years - an early but slow death.
You can also slowly kill discharged 680s by putting them on a low amp (2 amp charger) but that's well documented in the spec sheets and the AeroE archives.
They are great batteries (light, powerful, long lasting) but the charging requirements are a bit different than plain lead acid batts.
Bill "looking for more 680s to kill" Watson
On 7/26/2016 3:54 AM, Justin Jones wrote:
Mark,
Justin
Mark Donahue
RV 9A
300 hours.
Subject: Batteries
Bobby  ( age 77 )
Zodiac 601 XL "B"
www.avast.com
markdonahue
PostPosted: Tue Jul 26, 2016 9:28 am    Post subject: Batteries Reply with quote
My voltage gauge indicates over 14 volts when the engine is running.  I will put my multimeter on it to confirm.
Thanks for the feedback.
Mark
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Watson
Sent: Tuesday, July 26, 2016 5:05 AM
Subject: Re: Batteries
Mark,
Justin
Mark Donahue
RV 9A
300 hours.
Subject: Batteries
Bobby ( age 77 )
Zodiac 601 XL "B"
[img]cid:~WRD000.jpg[/img]
www.avast.com
 Filesize:  823 Bytes
 Viewed:  7438 Time(s)
Mark Donahue
PostPosted: Tue Jul 26, 2016 9:50 am    Post subject: Batteries Reply with quote
Maybe someone will correct me if I am wrong but it needs to be somewhere very close to 14.4.
Justin
On Jul 26, 2016, at 09:26, Mark Donahue <marktdonahue(at)comcast.net (marktdonahue(at)comcast.net)> wrote:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Mark
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Bill Watson
Subject: Re: AeroElectric-List: Batteries
Mark,
Justin
Mark Donahue
RV 9A
300 hours.
Subject: Batteries
Bobby ( age 77 )
Zodiac 601 XL "B"
<~WRD000.jpg>
www.avast.com
PostPosted: Tue Jul 26, 2016 2:22 pm    Post subject: Batteries Reply with quote
Enersys is 'happy' with anything between
14.1 and 14.7 volts. See:
http://tinyurl.com/hb4s7c4
. . . in particular Figure 6 and first
paragraph on page 13.
