billhuntersemail(at)gmail Guest
Posted: Sat Jul 23, 2016 10:04 am Post subject: Firewall Wire Pass Through |
Hi all,
On my airplane there are two rectangular/square holes that wire bundles pass through. One hole is 1 inch by 2 inches and the other is a square 1 inch by 1 inch hole.
What is a best practice and also cost effective way to Fire block these rather large holes?
Aircraft Spruce has a contraption for this purpose however it is only a 1 inch by 1 inch so it would not be applicable to my larger whole and there product is a bit pricey.
The previous installation simply had red RTV silicone squirted in between the wires
Thanks for your help!
Bill Hunter
ceengland7(at)gmail.com Guest
Posted: Sat Jul 23, 2016 10:29 am Post subject: Firewall Wire Pass Through |
On 7/23/2016 1:02 PM, William Hunter wrote:
Hi all,
between the wires
Bill Hunter
The 1x2 is a bit big; do you need that much area?
FWIW, you can duplicate the pricey Spruce kit by buying a stainless grab
bar & cutting it about 1-2" out from the flanges (a 2fer). Various
diameters typically available from big box stores, or ebay/amazon. I've
also seen 1" stainless flanges on ebay for a reasonable price. Instead
of RTV, use intumescent caulk.
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=intumescent%20caulk
You can get the latex based stuff at big box stores, or the better stuff
at ACS. (either is probably good enough, and a lot better than RTV.)
Instead of squirting it in the hole (messy if you need to add/remove
wires), squirt 'strings' of it on a non-stick surface & let them cure.
Then stuff the empty space with the strings.
You'll still need the firesleeve & stainless clamps to finish the job.
Charlie
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Sun Jul 24, 2016 1:54 am Post subject: Re: Firewall Wire Pass Through |
Remember that the purpose of a firewall is ..................to keep FIRE out of the cockpit to give you a minute or two to try to get your airplane on the ground and you to a safe place should an engine fire occur. Any firewall penetrations should be minimized. You might consider plugging your rather large openings with sheet metal similar to the firewall material - hopefully stainless steel. Use stainless pop rivets. RTV won't do the job.
_________________ Jerry King |
Jim Baker
Posted: Sun Jul 24, 2016 8:27 am Post subject: Firewall Wire Pass Through |
| Quote: | FWIW, you can duplicate the pricey Spruce kit by buying a stainless grab
!!!WHOA!!! I certainly came to the right place for advice!!!
I just cyber bought a 2fer of stainless steel firewall fire block flanges
for $11.72 !!!DELIVERED!!! (cleverly disguised as Moen exposed flange mount
stainless steel grab rail)
https://www.amazon.com/gp/product/B001U6EI92/ref=ox_sc_act_title_1?ie=UTF8&p
sc=1&smid=ATVPDKIKX0DER
Santa Amazon will show up on Tuesday with my gifts...according to my
smartphone calculator app...that is $5.82 each for the stainless steel
flanges (ok...plus the cost of the wear and tear and electricity to use my
cutoff wheel and a ride on the belt sander).
The creativity and "resourcefulness" (read Cheap-Ass-Full-Ness) of the
people on this forum is really astounding...I feel right at home!!!
Oh...BTW...the stainless steel clamps used to attach the red fire block
sleeves are also called "CV Joint Boot Clamps" and four can be purchased
DELIVERED for less than 7 bucks
https://www.amazon.com/gp/product/B00D4NB4VE/ref=oh_aui_detailpage_o09_s00?i
e=UTF8&psc=1
The 1.25 ID Aeroquip fire sleeve (I bought 6 inches for each of my DIY
"Firewall Penetration Kits" can be purchased from Pegasus Racing delivered
for $15.00 (dang...shipping was 8 bucks)....
So the grand total for TWO Firewall Penetration Kits is less than 30 BUCKS
($11.72 + $0.18 + $15.00 =$26.92)!!!
Still...a bit pricey for my standards but well within the threshold of
credit card pain. Well worth the price of admission to this forum!!!
THANKS AGAIN FOR YOUR HElP!!!
Cheers!!!
Bill Hunter
ashleysc(at)broadstripe.n Guest
Posted: Sun Jul 24, 2016 9:42 am Post subject: Firewall Wire Pass Through |
Hi All;
I have used these flanges (for grab rails, not firewalls). They are not too heavy and should do the job nicely.
Cheers! Stu.
Posted: Sun Jul 24, 2016 12:14 pm Post subject: Firewall Wire Pass Through |
Thanks Stu!!!
Bill Hunter
On Jul 24, 2016 11:48 AM, <ashleysc(at)broadstripe.net (ashleysc(at)broadstripe.net)> wrote:[quote]--> AeroElectric-List message posted by: ashleysc(at)broadstripe.net (ashleysc(at)broadstripe.net)
Hi All;
Cheers! Stu.
Posted: Sun Jul 24, 2016 12:36 pm Post subject: Firewall Wire Pass Through |
Bill,
Stainless worm drive hose clamps are a lot cheaper, and much easier to remove/replace when you make wiring changes.
https://www.amazon.com/Worm-Gear-Hose-Clamps/b?ie=UTF8&node=979130011
On Sun, Jul 24, 2016 at 3:11 PM, William Hunter <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote:
Thanks Stu!!!
Bill Hunter
Hi All;
Cheers! Stu.
Posted: Sun Jul 24, 2016 2:13 pm Post subject: Firewall Wire Pass Through |
Thanks Charlie... good call!!!
Bill Hunter
On Jul 24, 2016 2:43 PM, "Charlie England" <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:[quote]Bill,
Thanks Stu!!!
Bill Hunter
Hi All;
Cheers! Stu.
