Plug Cleaning and Gapping...
jeff(at)westcottpress.com
PostPosted: Thu Jul 07, 2016 2:35 pm    Post subject: Plug Cleaning and Gapping... Reply with quote
Spruce sells a couple of different kits and has a big "a la carte" selection... what am I after here?
Jeff Carpenter
4N10CF
Westcott Press
1121 Isabel Street
Burbank, CA 91506
jeff(at)westcottpress.com (jeff(at)westcottpress.com)
818-861-7300
Mauledriver(at)nc.rr.com
PostPosted: Fri Jul 08, 2016 7:02 am    Post subject: Plug Cleaning and Gapping... Reply with quote
I was new to plug maintenance but went with the following.  It has worked well thru 700 hours.  Applies to standard large electrode plugs (not fine wire stuff):
Cleaner - compressed air powered:
Spark Plug Cleaner
Gapper and Gap Guage
Gapper
ATS Guage
You definitely need a tray - I built my own.  Build or buy a decent one.  Mark you rotation scheme on it.  Holes drilled in wood will work but not ideal for an important tool.
This kit has everything you need including the  above stuff
The Kit
Jeff Carpenter
4N10CF
www.avast.com
Albert Gardner
PostPosted: Sat Jul 09, 2016 4:19 am    Post subject: Plug Cleaning and Gapping... Reply with quote
I find the little pry bar that opens up the gap useful also. Not that I ever over use the other tool that make the gap smaller.
http://www.aircraftspruce.com/catalog/topages/electrodespreader.php
Albert Gardner
RV-10 N991RV
Yuma, AZ
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson
Sent: Friday, July 08, 2016 10:02 AM
Subject: Re: Plug Cleaning and Gapping...
Spark Plug Cleaner
Gapper
ATS Guage
The Kit
Jeff Carpenter
4N10CF
[img]cid:~WRD000.jpg[/img]
www.avast.com
 Filesize:  823 Bytes
 Viewed:  2585 Time(s)
RV-9A N872RV
RV-10 N991RV
