Attitude indicator
Goto page 1, 2  Next
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
fougapilot
PostPosted: Mon Jun 20, 2016 10:47 am    Post subject: Attitude indicator Reply with quote
Guys,
Two fold question here;
How accurate is your attitude indicator whilst doing aerobatic?
It seems mine doesn't like it anymore. When I start the bird it works just fine (both cockpit) and after a few loops, it looses it and never recovers. I think it is simply getting towards the end of it's life.
Anyone know where the gyro is located on an R model? The manual clearly specifies where it is on the C model, but the R has a tendency to move things a bit here and there... plus I don't remember anything underneath the rear seat.
Cheers.
Dan
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
L29delfin(at)yahoo.com
PostPosted: Mon Jun 20, 2016 11:06 am    Post subject: Attitude indicator Reply with quote
Center floor back cockpit
On June 20, 2016 9:52:43 PM "fougapilot" <fougapilot(at)hotmail.com> wrote:
Guys,
the rear seat.
Cheers.
Dan
http://forums.matronics.com/viewtopic.php?p=457309#457309
fougapilot
PostPosted: Mon Jun 20, 2016 11:16 am    Post subject: Re: Attitude indicator Reply with quote
Even on the R model?
In a previous life, there was a big camera there and a big hole in the floor... This is why the Hyd accumulators and brake valves were moved to the nose section. Plus I do not remember ever seeing the Gyro there when the floor was open.
Thank for the help.
D
Dawg
PostPosted: Mon Jun 20, 2016 1:05 pm    Post subject: Attitude indicator Reply with quote
There was a big camera there and a hole in the floor in a previous life.
That is why the Hyd accumulators were moved to the nose section and I do not remember ever seeing the Gyro there when the floor was open.
Thank for the help.
D
http://forums.matronics.com/viewtopic.php?p=457311#457311
Dawg
PostPosted: Mon Jun 20, 2016 1:18 pm    Post subject: Attitude indicator Reply with quote
The original location for the attitude gyro is above the rear floor in a
dome. If rear controls have been added it's most likely moved to rear side
> Guys,
> the rear seat.
> Cheers.
> Dan
 Filesize:  2.92 MB
 Viewed:  25799 Time(s)
fougapilot
PostPosted: Mon Jun 20, 2016 1:24 pm    Post subject: Re: Attitude indicator Reply with quote
Interesting!
We do have dual controls, so it has been moved...
I guess I will simply follow the cables and see where the rabbit hole leads...
D
schwartzcompany(at)att.ne
PostPosted: Mon Jun 20, 2016 1:28 pm    Post subject: Attitude indicator Reply with quote
Most likely rear cockpit under side panels. Its a round grey gyro case. And it's bigBob
Sent from Yahoo Mail on Android
On Tue, Jun 21, 2016 at 0:24, fougapilot
--> L29-List message posted by: "fougapilot" <[url=javascript:return]fougapilot(at)hotmail.com[/url]>
Interesting!
D
http://forums.matronics"http://www.matronics.com/Navigator?L29-List" target="_blank">http://www.= &n--> =
delfin29(at)me.com
PostPosted: Mon Jun 20, 2016 1:52 pm    Post subject: Attitude indicator Reply with quote
Grey or black. I think there are two (one for attitude, other for angle)Jean
Le 20 juin 2016 à 21:28, Robert Schwartz <schwartzcompany(at)att.net (schwartzcompany(at)att.net)> a écrit :
Most likely rear cockpit under side panels. Its a round grey gyro case. And it's bigBobSent from Yahoo Mail on Android
<fougapilot(at)hotmail.com (fougapilot(at)hotmail.com)> wrote:
--> L29-List message posted by: "fougapilot" <http://forums.matronics"http://www.matronics.com/Navigator?L29-List" target="_blank">http://www.= &n--> =
PostPosted: Mon Jun 20, 2016 1:57 pm    Post subject: Attitude indicator Reply with quote
Turn and bank is between front and back seat on right side under panel.  The big attitude gyro could be anywhere. It's not a sanctioned relocation
On Tue, Jun 21, 2016 at 0:52, delfin29(at)me.com
Le 20 juin 2016 à 21:28, Robert Schwartz <[url=javascript:return]schwartzcompany(at)att.net[/url]> a écrit :
Dawg
PostPosted: Mon Jun 20, 2016 3:44 pm    Post subject: Attitude indicator Reply with quote
It has to be on the sidewall. probably the right side in the rear cockpit.
(WAG)
On Jun 20, 2016, at 15:24, fougapilot <fougapilot(at)hotmail.com> wrote:
Interesting!
D
http://forums.matronics.com/viewtopic.php?p=457317#457317
Dawg
Dawg
PostPosted: Mon Jun 20, 2016 3:45 pm    Post subject: Attitude indicator Reply with quote
one. gray.
Dawg
fougapilot
PostPosted: Mon Jun 20, 2016 5:16 pm    Post subject: Re: Attitude indicator Reply with quote
There is a gray vertical cylinder on the RH side between both cockpit, I would think that this is the gyro for the DG.
I will Open the back cockpit next time I am at the airport and look for the Attitude gyro.
D
Dawg
PostPosted: Mon Jun 20, 2016 5:31 pm    Post subject: Attitude indicator Reply with quote
It's about the size of a watermelon. It has a glass bubble site on top. U could Jack it up and level the airplane, then center the bubble. However, 35 years of Acro may be taking its toll. The "R" models didn't do much maneuvering, but they are still aging. Sometimes I walk with a 5 degree crab. I'm old.
Sent from my Samsung Galaxy smartphone.
-------- Original message --------
Date:06/20/2016 19:16 (GMT-07:00)
To: l29-list(at)matronics.com
Cc:
Subject: L29-List: Re: Attitude indicator
Dawg
fougapilot
PostPosted: Tue Jun 21, 2016 2:15 am    Post subject: Re: Attitude indicator Reply with quote
Roger that!
Are you sure it is only 5 degrees of crab? It looked more like ten last time I saw you Wink But then again we had just landed, so it might have been my flying...
Dawg
PostPosted: Tue Jun 21, 2016 6:50 am    Post subject: Attitude indicator Reply with quote
Somedays…
On Jun 21, 2016, at 04:15, fougapilot <fougapilot(at)hotmail.com> wrote:
Roger that!
http://forums.matronics.com/viewtopic.php?p=457347#457347
Dawg
jorgen.nielsen(at)mweb.co
PostPosted: Tue Jun 21, 2016 7:08 am    Post subject: Attitude indicator Reply with quote
For what its worth, i replaced mine with an MGL voyager EFIS. Took a bunch of stuff out. Works well, but also tumbles after extended aerobatics.
D
http://forums.matronics.com/viewtopic.php?p=457332#457332
fougapilot
PostPosted: Mon Jan 02, 2017 2:35 pm    Post subject: Re: Attitude indicator Reply with quote
So, I finally have time to look into this, here is what I found;
Is this the gyro for the Attitude indicator?
 Filesize:  189.15 KB
 Viewed:  25223 Time(s)
Dawg
PostPosted: Mon Jan 02, 2017 2:37 pm    Post subject: Attitude indicator Reply with quote
yes
http://forums.matronics.com/viewtopic.php?p=464623#464623
http://forums.matronics.com//files/p3080205_125.jpg
Dawg
fougapilot
PostPosted: Mon Jan 02, 2017 3:52 pm    Post subject: Re: Attitude indicator Reply with quote
The picture is not from my airplane, but from a guy who has one for sale. I would like to test mine before I go out and change it.
It there a specific method to remove it?
Any particulars to pay attention to?
Any specific Voo-Doo dance I must do to not jinks it?
D
Dawg
PostPosted: Tue Jan 03, 2017 12:51 am    Post subject: Attitude indicator Reply with quote
Since u r a small guy just getting it out will be fun.
Remove rear seat, which requires removing rear canopy....
D
http://forums.matronics.com/viewtopic.php?p=464630#464630
Dawg
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
