danbooker
Posted: Thu Jun 09, 2016 3:29 pm Post subject: gear handle hiss |
Sometimes, not always, I have a hiss coming from behind the gear handle. Is there something back ther that needs mx once in a while? Also, who sells the brake reducing box overhaul kit (the little box under right side of pilot seat)
_________________ Daniel Booker
"Stealth-Eagle Aviation"
2312457798
danbooker@hotmail.com |
dougsappllc(at)gmail.com Guest
Posted: Thu Jun 09, 2016 3:51 pm Post subject: gear handle hiss |
Dan,The pneumatic system (gear and flap valves in the cockpits) normally vent to the atmosphere via holes in these valves, that is the hiss you hear when the gear/flaps go up and down. You should hear it EVERY time the system cycles.
It's really hard for me to determine what you need by your description "brake reducing box overhaul kit (the little box under right side of pilot seat)" This is why god invented part numbers! Check your parts books (Vol #1) or if you don't have a set go to my web site http://cj6.com/ and you will find a set there, or give me a call (509-826-4610) so I can better understand and make sure you get the correct parts.
Doug
On Thu, Jun 9, 2016 at 4:29 PM, danbooker <danbooker(at)hotmail.com (danbooker(at)hotmail.com)> wrote:
| Quote: | --> Yak-List message posted by: "danbooker" <danbooker(at)hotmail.com (danbooker(at)hotmail.com)>
Daniel Booker
[url=tel:2312457798]2312457798[/url]
http://forums.matronics.com/viewtopic.php?p=456998#456998
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
Posted: Fri Jun 10, 2016 3:20 am Post subject: gear handle hiss |
Dan,
That's the brake differential valve under the right side of the front seat. Doug Sapp sells the overhaul kits for both the brake reducing valve (under the floor on the right side of the rear cockpit on the Yak 52) and the brake differential valve.
The hiss could be from the gear handle itself. But more likely from one of the gear actuators. Give me a call (you have my number) and we can discuss how to troubleshoot the leak.
Dennis
To: yak-list(at)matronics.com
Sent: Thursday, June 9, 2016 7:29 PM
Subject: Yak-List: gear handle hiss
Daniel Booker
2312457798
http://forums.matronics.cotp://www.matronics.com/Navigator?Yak-List" target="_blank">http://www.matnbsp; t; http
Posted: Fri Jun 10, 2016 3:24 am Post subject: gear handle hiss |
Doug,
On the 52 (which is what Dan has), the brake reducing valve is the QS1 on the CJ and the brake differential valve is the QS2 on the CJ. By Dan's description, he is asking for the QS2 or brake differential valve overhaul kit.
Dennis
Sent: Thursday, June 9, 2016 7:50 PM
Subject: Re: gear handle hiss
Doug
Daniel Booker
[url=]2312457798[/url]
FORUMS -
WIKI -
b Site -
Viperdoc
Posted: Fri Jun 10, 2016 11:58 am Post subject: gear handle hiss |
Ah come on Doug! You can't get me a Whachamadingit to fit my whatchacallit from wherethehelldidthatcomefrom after it came out of the ohhellnotagainslot?
Doc 😜
Sent from my iPad
On Jun 9, 2016, at 6:50 PM, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
| Quote: | Dan,The pneumatic system (gear and flap valves in the cockpits) normally vent to the atmosphere via holes in these valves, that is the hiss you hear when the gear/flaps go up and down. You should hear it EVERY time the system cycles.
Doug
_________________ Viperdoc |
