brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Wed Jul 05, 2006 3:30 pm Post subject: alternator failure modes |
I have had several people write to me to tell me that they have never
seen an alternator turn into a grenade. Neither have I. I was just
listing that is a *possible* scenario, as in, "I suppose this might
happen." I think it unlikely but I do think that things like broken
brackets, having the alternator seize, and who knows what happens if
both happen at once.
The key point is that there are mechanical failure modes, not just
electrical failure modes. When the alternator stops producing power
it is not just an electrical problem. If one were to fly for a longer
period of time something bad could happen that would make the
situation much worse.
I still hold that it is a good idea to land and check things out even
if you have a backup alternator or lots of battery capacity.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
brinker(at)cox-internet.c Guest
Posted: Wed Jul 05, 2006 3:50 pm Post subject: alternator failure modes |
Yep it's not like we can coast to the side of the road when we have a
major problem. Better safe than sorry. And hey we might even make a friend
at our non scheduled destination. If there's one thing I've noticed in my
relatively short flying experiences is that airport folks are generally
friendly and willing to help.
Randy
FLYaDIVE(at)aol.com Guest
Posted: Thu Jul 06, 2006 4:41 am Post subject: alternator failure modes |
In a message dated 7/5/06 7:53:06 PM Eastern Daylight Time,
brinker(at)cox-internet.com writes:
| Quote: | If there's one thing I've noticed in my
Randy
Yup, as long as you keep away from the FBO's.
And look for the EAA types.
Barry
"Chop'd Liver"
Posted: Fri Jul 07, 2006 11:07 am Post subject: alternator failure modes |
In a message dated 7/5/06 7:32:46 PM Eastern Daylight Time,
brian-yak(at)lloyd.com writes:
| Quote: | I have had several people write to me to tell me that they have never
Brian:
When you say grenade, are you saying totally blown apart with the case
breaking into pieces?
I have done two alternators jobs that have had what I would call catastrophic
failures.
The first had the through bolts come out and the alternator bells separated.
This caused the rotor to violently wobble and destroy the stator. Basic
cause - Plane owner went to his buddy to have an annual done. Cost of Annual: One
bottle of Jonnie Walker Black. I do not know at what point the bottle was
consumed.
Second was a failure of the alternator's end bell (sheave end) where the
bearing is pressed in. The voltage output failed and the rotor just started to
wobble off center. Basic cause - The alternator was installed off center. The
sheave was not aligned with the gear tooth ring.
I would not cal lit a grenade, but close.
Barry
"Chop'd Liver"
brian
Posted: Fri Jul 07, 2006 11:53 am Post subject: alternator failure modes |
On Jul 7, 2006, at 3:04 PM, FLYaDIVE(at)aol.com wrote:
Brian:
Yes, that was the picture I had in my mind but really, any failure
where the energy in the rotor causes catastrophic failure of the
case. It could be just breaking off the mounting ears, bells
separating, etc.
catastrophic
failures.
separated.
Basic
of Annual: One
bottle was
consumed.
Usually pre-inspection. That ensures that the signature appears in
the logbook regardless of the condition of the airplane.
| Quote: | Second was a failure of the alternator's end bell (sheave end)
where the
just started to
center. The
That is pretty much what I was thinking. I could see the rotor
suddenly seizing because a bearing failed and the rotor jams with the
case or the stator. The sudden stoppage along with the additional
torque being applied by the belt could cause some or all of the
alternator to do the grand tour of the cowling. I can see that doing
damage to the carb, fuel injection servo, linkages, exhaust, airbox,
or other bits down there under the engine. I don't think it likely to
hole the case of the engine but weird stuff happens. OTOH, there is a
lot more mass in an alternator than in a piston or connecting rod. It
would not be a pretty sight.
George W Braly
Posted: Sat Jul 08, 2006 4:45 am Post subject: alternator failure modes |
I have had an alternator turn into a hunk of twisted junk due to a
failed bearing.
