		JOHN TIPTON
  Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
				 Posted: Sun May 22, 2016 2:39 am    Post subject: Fuselage #30 rivets |
				Hi Guys
 There seems to be excessive use of #30 rivets for the fuselage (-9) internals, does it really need them, example: tunnel cover 16x 1/8inch rivets listed
 John
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		ceengland7(at)gmail.com Guest
				 Posted: Sun May 22, 2016 7:06 am    Post subject: Fuselage #30 rivets |
				On 5/22/2016 5:39 AM, JOHN TIPTON wrote:
  Hi Guys
  John
 I'm building a -7 (same fuselage),  & can't figure out which area you're
 talking about.  Having said that, I'm not an aero engineer, so I try not
 to second guess the designer (who, hopefully, is) if the area is
 structural. Perhaps the cover you're talking about is required to
 complete an area that's structurally significant.
 Charlie
		gyoung
  Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
				 Posted: Sun May 22, 2016 7:18 am    Post subject: Fuselage #30 rivets |
				The short answer is yes. Van is a minimalist. His designs do not include anything he doesn't believe is needed. The RV's also use mostly -3 rivets so when they use -4's it's for a reason.
 Greg Young
		JOHN TIPTON
		dickseiders(at)gmail.com Guest
				 Posted: Sun May 22, 2016 10:57 am    Post subject: Fuselage #30 rivets |
				Read Greg young's answer again.
 Dick seiders
		halbenjamin101(at)gmail.c Guest
				 Posted: Sun May 22, 2016 11:25 am    Post subject: Fuselage #30 rivets |
				Greg is right on. Besides, if you build it per Van's instructions that is one thing less to worry about as you're about to advance the throttle on your first flight!
 Hal Benjamin
 RV-4 Flying
 Long Island, NY
 218 Hours
 Sent from my iPad
 [quote] On May 22, 2016, at 11:17 AM, "bigdog(at)bentwing.com" <bigdog(at)bentwing.com> wrote:
  Greg Young
		JOHN TIPTON
				 Posted: Sun May 22, 2016 11:41 am    Post subject: Re: Fuselage #30 rivets |
				Van is a 'minimalist' - I thought his planes were over engineered (bullet proof) - but I stand corrected
 John
		HCRV6(at)comcast.net Guest
				 Posted: Sun May 22, 2016 12:14 pm    Post subject: Fuselage #30 rivets |
				Van is not known for an excessive use of anything.  If the plans call for it, do it!
 Harry Crosby
 RV-6 N16CX, 1365 hours.
 To: "RV-List" <rv-list(at)matronics.com>
 Sent: Sunday, May 22, 2016 3:39:39 AM
 Subject: Fuselage #30 rivets
 --> RV-List message posted by: "JOHN TIPTON" <jmtipton(at)btopenworld.com>
 Hi Guys
 John
 http://forums.matronics.com/viewtopic.php?p=456436#456436
                 -Matt Dralle, List ==========
		jsflyrv(at)frontier.com Guest
				 Posted: Sun May 22, 2016 12:16 pm    Post subject: Fuselage #30 rivets |
				I think you took Greg's answer in the wrong way. Van's airplanes ARE
 over engineered.
		vanremog(at)aol.com Guest
				 Posted: Sun May 22, 2016 1:19 pm    Post subject: Fuselage #30 rivets |
				Van's designs are "well engineered".  Some things like the original spar were over engineered.  Other areas were maybe a little light and prone to cracking but they have been corrected as the designs matured.
   After all of the things we have put Van's planes thru over the years I think it is safe to say that they have stood the test of time, so I would recommend building per plans.  Small downside, large upside.
   -GV
		JOHN TIPTON
				 Posted: Sun May 22, 2016 2:09 pm    Post subject: Re: Fuselage #30 rivets |
				I agree
 John
				 Posted: Sun May 22, 2016 2:17 pm    Post subject: Fuselage #30 rivets |
				On Sun, May 22, 2016 at 12:33 PM, JOHN TIPTON <jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)> wrote:
 Thought that might be what you were talking about, but wasn't sure. (Had to go find mine; it's been a while since I built it.)
 Look at what it's built of, and what it's expected to withstand in normal use. That's pretty heavy Z channel for a 'cover,' no? Why not use .030 sheet instead of extruded Z stock, & bend it up out of one piece? But what happens when your 200 lb passenger plants their foot on it and pushes off, exiting the plane?
 Van is a minimalist, *and* the planes are over-built. I'm sure you can work out the paradox.
 Charlie
				 Posted: Sun May 22, 2016 2:31 pm    Post subject: Fuselage #30 rivets |
				On Sun, May 22, 2016 at 5:16 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
 Charlie
 Should have added (or maybe led with), My kit didn't come with any universal head 3/32 rivets. Maybe the engineer decided that 1/8 round heads (already in the kit) would be fine and avoid the need to dimple the top piece & countersink the Z channels.
