Throttle, mixture, prop cable lengths?
digidocs
PostPosted: Wed May 11, 2016 10:12 pm    Post subject: Throttle, mixture, prop cable lengths? Reply with quote
Hey list,
Are Van's stock control cables the correct length or are custom lengths required?
The FF setup is C4B5, Airflow FM-150A, PCU5000X, and firewall penetrations in the factory locations.
David
jesse(at)saintaviation.co
PostPosted: Thu May 12, 2016 3:42 am    Post subject: Throttle, mixture, prop cable lengths? Reply with quote
I have used both the stock push/pull and quadrant cables in at least 15-20 FWF installs and they work. Some argue that some could stand to be a little longer, especially for the quadrant, I think mainly the prop cable, but I don't remember the details. Stock will work, though.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On May 12, 2016, at 2:10 AM, David Carr <junk(at)dcarr.org> wrote:
Hey list,
David
Kellym
PostPosted: Thu May 12, 2016 5:35 am    Post subject: Throttle, mixture, prop cable lengths? Reply with quote
Cable length will depend on whether you stick strictly to the plans,
whether you use a custom instrument panel, and whether you use stock
Lycoming ignition and fuel injection or carburetor. Since you are using
non stock fuel injection and prop governor, you will need to verify
whether those items change the cable hook ups in any way. Items such as
air conditioning compressor or different routing of the cables can
affect length.
I don't know if it makes a difference or not, but the prototype Vans
built used a narrow deck engine, and any new engine as well as a
majority of overhauled engines you can buy will be wide deck.
Some have had difficulty in use with stock cables because of
engine/exhaust heat. Several vendors offer cables with higher heat
resistance with teflon lining.
Jesse Saint
> Hey list,
> Thanks,
> David
Kelly McMullen
KCHD
carl.froehlich(at)verizon
PostPosted: Thu May 12, 2016 6:00 am    Post subject: Throttle, mixture, prop cable lengths? Reply with quote
For push/pull controls the mixture and prop cables work.  The Van’s recommended 47.5” throttle cable will, if pulled tight against the bottom of the engine, just fit.
A better option for the throttle cable is to get the 50.5” cable Van’s sells for the RV-7.  That is what I’m using.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Carr
Sent: Thursday, May 12, 2016 2:11 AM
Subject: Throttle, mixture, prop cable lengths?
Hey list,
David
philperry9
PostPosted: Thu May 12, 2016 8:10 am    Post subject: Throttle, mixture, prop cable lengths? Reply with quote
I'll add that if you get custom cables made for your chosen routes, only order 1 first and make all your learning curve advancements on the 1st cable and not all 3 (or more) at the same time.
You'll save so much money in the long term it's not even funny. I've bought about 5 cables now and had 3 of those modified. I've wasted more than a grand trying to get the cables right.
Just order one and learn your lessons on it. Then order the other 2.
On May 12, 2016, at 1:10 AM, David Carr <junk(at)dcarr.org> wrote:
Hey list,
David
Bob Turner
PostPosted: Thu May 12, 2016 8:33 am    Post subject: Re: Throttle, mixture, prop cable lengths? Reply with quote
Strictly a stock build. Mine fit but were tight, I needed to go as direct as possible, not exactly per plans.
Bob Turner
RV-10 QB
Tim Olson
PostPosted: Thu May 12, 2016 8:37 am    Post subject: Throttle, mixture, prop cable lengths? Reply with quote
That sounds pretty expensive...
My cables for the -14 are slightly shorter but they only cost me $70 each.
What I did find was very helpful was that I used my old RV-14
cables that had gotten stiff and ruined from heat and time,
and used one of those to mock up the lengths.
If there is another RV-10 builder who has an old cable around,
maybe they can be talked into sending it to you if you get
custom cables. I'd offer mine, but I already have the
offer open to other RV-14 builders who may need them to
get a quadrant installed. Van's in their lack of
execution on the RV-14, hasn't yet even begun offer
a quadrant on the RV-14, or even assistance in getting
one installed. So mine is a D-I-Y install and I'm trying
to help others who want the same thing.
All in all, I do think Phil gave great advice...order one
cable, the longest one, first, if you're going to try
anything custom. But if you can borrow an old cable
from someone, that would save you the headache.
> Hey list,
> Thanks,
> David
bdgillespie215(at)gmail.c
PostPosted: Thu May 12, 2016 9:12 am    Post subject: Throttle, mixture, prop cable lengths? Reply with quote
As it turns out it I have a complete set of what I think are the "original cables" here at the house. They turned out to be short for me and I ordered new custom cables. If you want to check them out, e-mail me off line and I can ship them out to you. If they work out length wise, I can make you a real good deal...
The cables are marked ACS Products Co. Inc:
Mixture(Red)  A-1760-20-0515-V & Van's tag CT RED VMIXTURE 51.5
Prop (Blue)  A-1760-30-0725-V
Throttle (Black)  A-800BL0475-V
Byron
N253RV
On Thu, May 12, 2016 at 12:35 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
--> RV10-List message posted by: Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)>
On May 12, 2016, at 1:10 AM, David Carr <junk(at)dcarr.org (junk(at)dcarr.org)> wrote:
Hey list,
David
-List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?RV10-List
FORUMS -
_blank" rel="noreferrer">http://forums.matronics.com
WIKI -
lank" rel="noreferrer">http://wiki.matronics.com
b Site -
          -Matt Dralle, List Admin.
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
philperry9
PostPosted: Thu May 12, 2016 9:31 am    Post subject: Throttle, mixture, prop cable lengths? Reply with quote
I went with the McFarlane cables using the hi-temp sleeves. $250/each.
And if they need to be modified its between $100-$150 depending on the modification requested.
Painful to experience.
> Sent from my iPhone
>> Hey list,
>> Thanks,
>> David
digidocs
PostPosted: Thu May 12, 2016 9:42 am    Post subject: Throttle, mixture, prop cable lengths? Reply with quote
Byron,
That sounds great!  I'll send you a note off-list shortly.
Thanks also to everyone for the advice thus far---wish I had signed up for the Matronics list sooner.
David
On Thu, May 12, 2016 at 12:12 PM, Byron Gillespie <bdgillespie215(at)gmail.com (bdgillespie215(at)gmail.com)> wrote:
Byron
N253RV
Hey list,
David
FORUMS -
WIKI -
b Site -
Lenny Iszak
PostPosted: Thu May 12, 2016 12:07 pm    Post subject: Re: Throttle, mixture, prop cable lengths? Reply with quote
David,
My quadrant cables are coming out this week for replacement for higher temp versions. If you want one or all for measurement purposes you're welcome to have them. They are longer than the standard lengths Van's gives you, because I have my quadrant on the center console behind the fuel selector.
Lenny
digidocs
PostPosted: Thu May 12, 2016 1:13 pm    Post subject: Throttle, mixture, prop cable lengths? Reply with quote
Lenny,
Thanks for the kind offer.  For now, I'm going the push-pull route, but I do appreciate it.
David
On Thu, May 12, 2016 at 3:07 PM, Lenny Iszak <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)> wrote:
--> RV10-List message posted by: "Lenny Iszak" <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)>
David,
Lenny
http://forums.matronics.com/viewtopic.php?p=456164#456164
FORUMS -
WIKI -
b Site -
rv10free2fly(at)yahoo.com
PostPosted: Thu May 12, 2016 1:41 pm    Post subject: Throttle, mixture, prop cable lengths? Reply with quote
HI Lenny
I need to get some longer cables made, where can you recommend to get this done please?
Warm regards
Patrick Pulis
Adelaide
South Australia
On 13 May 2016, at 05:37, Lenny Iszak <lenard(at)rapiddecision.com> wrote:
David,
Lenny
partner14
PostPosted: Thu May 12, 2016 3:51 pm    Post subject: Throttle, mixture, prop cable lengths? Reply with quote
Check out
California Push-Pull, Inc.
philperry9(at)gmail.com (philperry9(at)gmail.com)> I'll add that if you get custom cables made for your chosen routes, only order 1 first and make all your learning curve advancements on the 1st cable and not all 3 (or more) at the same time. You'll save so much money in the long term it's not even funny.  I've bought about 5 cables now and had 3 of those modified. I've wasted more than a grand trying to get the cables right. Just order one and learn your lessons on it. Then order the other 2. Sent from my iPhone
On May 12, 2016, at 1:10 AM, David Carr <junk(at)dcarr.org (junk(at)dcarr.org)> wrote: Hey list, Are Van's stock control cables the correct length or are custom lengths required? The FF setup is C4B5, Airflow FM-150A, PCU5000X, and firewall penetrations in the factory locations. Thanks, David
[/quote]
=========== -List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?RV10-List =========== FORUMS - _blank" rel="noreferrer">http://forums.matronics.com =========== WIKI - lank" rel="noreferrer">http://wiki.matronics.com =========== b Site - -Matt Dralle, List Admin. target="_blank" rel="noreferrer">http://www.matronics.com/contribution =========== [/quote]
[/quote]
Don A. McDonald
40636
Lenny Iszak
PostPosted: Thu May 12, 2016 4:43 pm    Post subject: Re: Throttle, mixture, prop cable lengths? Reply with quote
I'm getting them from www.push-pull.com but local CableCraft suppliers should be able to do it. If you have one of those in Australia it might make it easier for you.
The model number is 176-VTT-2-57, where 2 is the throw, 57 is the length.
Lenny
Lenny Iszak
PostPosted: Wed May 18, 2016 12:20 pm    Post subject: Re: Throttle, mixture, prop cable lengths? Reply with quote
Woah, www.push-pull.com is awesome! Ordered custom cables on Monday morning, today it's Wednesday and they just arrived!
Lenny
Tim Olson
PostPosted: Wed May 18, 2016 3:40 pm    Post subject: Throttle, mixture, prop cable lengths? Reply with quote
On my cables too they quoted me 2-3 days in house to make them
and then the shipping time. In reality they shipped either
the same day I called the order in, or the next morning.
But it was much ahead of schedule.
Good to work with.
Lenny
Mauledriver(at)nc.rr.com
PostPosted: Sun May 22, 2016 2:27 am    Post subject: Throttle, mixture, prop cable lengths? Reply with quote
I had the same experience - awesome.
My Vans stock cables were installed and flown successfully but chafed over 350 hours.  Replaced with higher temp, slightly longer cables from these guys and all is fine so far at 700 hours.
See this log entry and next for details.  Price = $225 shipped in 2013.
Bill "happily returning from Europe where I saw <6 light aircraft flying in 3 weeks" Watson
--> RV10-List message posted by: "Lenny Iszak" <lenard(at)rapiddecision.com> (lenard(at)rapiddecision.com)
Lenny
http://forums.matronics.com/viewtopic.php?p=456360#456360
