TR-1 Nose Gear
bakerocb
PostPosted: Thu Apr 14, 2016 11:18 am    Post subject: TR-1 Nose Gear Reply with quote
4/14/2016
Hello Mark, Thanks for weighing in on this subject. You wrote:
1) “I am sorry to say the secrets of the nose gear spring were only known by Vance.”
The KIS family lost a true friend when he passed. I wonder if any one in his family could help. I’ll try an email address from his web site. http://www.oocities.org/vjaqua/
2) “I do have an engineer who has access to test equipment that can determine the parameters of the spring.”
That is one approach. Another is to assume that: a) the spring was a standard catalog item (maybe from McMaster Carr?); b) that same catalog item is still available; and c) by just using the spring dimensions Lyle would be able to identify and order a duplicate spring. A picture of the top of the spring which is installed in my plane is attached.
3) “If I can get somebody to take their TR-1 nose gear apart and send me the spring I can send it to the engineer and he will test it.”
Or, if somebody could just remove their KIS TR-1 nose gear coil spring (hopefully from a non flying airplane) and provide some accurate dimensions we could identify it that way. See my related and redacted April 09, 2016 9:55 AM email copied below.
OC
Sent: Thursday, April 14, 2016 8:51 AM
To: Owen Baker (bakerocb(at)cox.net)
Cc: HENDRICKS LYLE (lyle(at)hendricksmfg.com) ; ERSTAD HANS CHRISTIAN (hans.erstad(at)gmail.com) ; MILLER KEITH (Keith.Miller(at)esa.int) ; Kettering Mark (mantafs(at)earthlink.net) ; Melyon Solly (sollymelyon(at)yahoo.com)
Subject: Re: Fw: TR-1 Nose Gear
KIS TR-1 nose gear spring
I am sorry to say the secrets of the nose gear spring were only known by Vance. I do have an engineer who has access to test equipment that can determine the parameters of the spring. He has already do so for the TR-4 spring set (this gear uses two different springs one heavy duty and one medium duty. If I can get somebody to take their TR-1 nose gear apart and send me the spring I can send it to the engineer and he will test it. I have sent an email to him to make sure he will do this for us.
Mark Trickel
Sent: Saturday, April 09, 2016 9:55 AM
To: HENDRICKS LYLE
Subject: UK TR-1 Nose Gear
4/9/2016
Hello Lyle, I went out to the hangar yesterday, partially disassembled my
airplane and took some
nose gear related photos and measurements. I'd like to take another stab at
answering your original
April 06, 2016 12:49 PM email (copied below). You wrote:
1) "My question to you is re: the upper spring."
Selecting the McMaster Carr coil spring that matches the one in my airplane
is not as explicit as I would like.
First off, my previous estimate of the uncompressed spring length of 12
inches, based on appearance in the
attached 429 KB photo, was wrong. The measured length on my nose gear coil
spring (as installed) is
very near 8 inches.
The measured outside diameter of my coil spring (using a C clamp as a
micrometer) is very close to 2 inches. There
are two 8 inch long coil springs in the McM C catalog that nearly fit that 2
inch OD dimension: 96485K164 at 2.187 inches OD
and 96485K386 at 1.917 inches OD. So I can not discriminate between those
two P/N solely on OD. See here:
http://www.mcmaster.com/#compression-springs/=11wlo5u
Wire diameter does not appear to be a good discriminator for two reasons: a)
the wire in my spring is not round, but
is flattened on the top and bottom; and b) accurate wire diameter
measurement access to my spring is difficult. For both of those
reasons an accurate wire diameter measurement is difficult. In the catalog
P/N 164 has a wire diameter of 0.25 and P/N 386 has
a wire diameter of 0.312. My estimate favors P/N 164.
Regarding max load: P/N 164 has a max load of 274 pounds and P/N 386 has a
max load of 597 pounds. My plane has an
empty weight of 242 pounds on the nose gear so a max load rating of 274
seems a bit marginal to me, but then I don't know
what the criteria for max load is (fully compress the spring or ???). 597
pounds seems very stiff to me.
Maybe you can discriminate between the two P/N's by which spring will best
fit over the compression rod. P/N 164 should have a
calculated inner diameter of 1.687 inches and P/N 386 should have an inner
diameter of 1.293 inches.
My choice between the two McM C springs would be P/N 164.
xxxxxxxxxxxxxxxxxxx BIG SKIP xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
OC
Sent: Wednesday, April 06, 2016 12:49 PM
To: bakerocb(at)cox.net (bakerocb(at)cox.net)
Subject: TR-1 Nose Gear
Hello OC, How have you been? I'm currently working on a TR-1 nose gear project for a gentleman who has suffered a failure of the original design. With approval from the UK LAA, we hope to get him and his plane back in the air. My question to you is re: the upper spring. I know Rich used McMaster Carr as a supplier for the spring, however, I am unable to identify the part number of the spring. As I recall, you may have had to purchase one of these springs when we made a new nose gear assy for you a while back. Any info about the spring and the rubber washers/bushings which surround it would be greatly appreciated as I am attempting to supply a complete, ready to install unit to his mechanic. I’d also like to confirm the length of the upper tube (7.875”) and the overall length of the compression rod including threaded portion (18.093”) if you have the means to do so without too much trouble. Do you recall having any adjustment or modification issues while installing your nose gear?
Thank you for your help,
Lyle Hendricks
Hendricks Mfg., Inc.
[url=tel:208-476-7740]208-476-7740[/url]
http://www.HendricksMfg.com
 Filesize:  747 KB
 Viewed:  4789 Time(s)
aeromomentum(at)yahoo.com
PostPosted: Thu Apr 14, 2016 11:59 am    Post subject: TR-1 Nose Gear Reply with quote
These are standard die springs from McMaster and follow the Raymond die springs color code.
http://www.mcmaster.com/#standard-die-springs/=11zcvvg but check the size!
On Thu, 4/14/16, Owen Baker <bakerocb(at)cox.net> wrote:
Subject: Re: TR-1 Nose Gear
To: "Mark Trickel" <marktrickel(at)gmail.com>, "KIS-LIST MATRONICS" <kis-list(at)matronics.com>, hagerson(at)pacbell.net
Date: Thursday, April 14, 2016, 3:17 PM
4/14/2016
by Vance.”
equipment that can
spring was a
Lyle would be able
top of the spring
it.”
gear coil spring
email copied below.
OC
Trickel
To: Owen
Baker
Cc: HENDRICKS
LYLE ; ERSTAD HANS
CHRISTIAN ; MILLER
KEITH ; Kettering
Mark ; Melyon
Solly
Gear
were only known by
him to make sure he
Mark Trickel
To: HENDRICKS LYLE
4/9/2016
spring."
spring length of 12
very near 8 inches.
a C clamp as a
a)
wire diameter
of those
has
164.
load rating of 274
know
spring or ???). 597
a
164.
OC
Hendricks
Subject:
TR-1 Nose Gear
failure of the
I know Rich used
purchase one of
ready to install
of the upper tube
including threaded
nose gear?
Lyle
Hendricks
208-476-7740
jerzy_krasinski(at)sbcglo
PostPosted: Thu Apr 14, 2016 1:15 pm    Post subject: TR-1 Nose Gear Reply with quote
Hello,
I have in my barn the old style steerable front gear for KIS Cruiser with the springs.
I hope its not rusted, I have to check it.
If anybody has an interest in that gear or just the springs please let me know.
Jerzy Krasinski jerzy_krasinski(at)sbcglobal.net
On Thursday, April 14, 2016 2:17 PM, Owen Baker <bakerocb(at)cox.net> wrote:
4/14/2016
OC
Mark Trickel
To: HENDRICKS LYLE
4/9/2016
very near 8 inches.
OC
Lyle Hendricks
[url=]208-476-7740[/url]
gbrighton(at)skymesh.com.
PostPosted: Thu Apr 14, 2016 1:56 pm    Post subject: TR-1 Nose Gear Reply with quote
Hi Guys,
My TR1 Nose gear Leg is disassembled and is at the Hanger .... I'll try to get there tomorrow and check physical Dimensions and report back ..,
Cheers
Graham .
PostPosted: Thu Apr 14, 2016 6:56 pm    Post subject: TR-1 Nose Gear Reply with quote
From my old calculations for the TR-1 nose gear it looks like the desired spring rate is 329.7 lbs/in. The McMaster part number 9584K99,
http://www.mcmaster.com/#9584k99/=11zi7a8 looks like it meets this number nicely, the size OC provided and the color in the picture OC provided. It also meets the color and size on my TR-1 nose gear.
Mark K
On Thu, 4/14/16, jerzy krasinski <jerzy_krasinski(at)sbcglobal.net> wrote:
Subject: Re: Re: TR-1 Nose Gear
To: "kis-list(at)matronics.com" <kis-list(at)matronics.com>
Date: Thursday, April 14, 2016, 5:15 PM
Hello,
I
Cruiser with the springs.I
hope its not rusted, I have to check it.If
please let me know.
Jerzy
On Thursday, April
wrote:
4/14/2016
by Vance.”
equipment that can
spring was a
Lyle would be able
top of the spring
it.”
gear coil spring
email copied below.
OC
Trickel
To: Owen
Baker
Cc: HENDRICKS
LYLE ; ERSTAD HANS
CHRISTIAN ; MILLER
KEITH ; Kettering
Mark ; Melyon
Solly
Gear
were only known by
him to make sure he
Mark Trickel
To: HENDRICKS LYLE
4/9/2016
spring."
spring length of 12
very near 8 inches.
a C clamp as a
a)
wire diameter
of those
has
164.
load rating of 274
know
spring or ???). 597
a
164.
OC
Hendricks
12:49 PM
Subject:
TR-1 Nose Gear
Hello OC,
failure of the
I know Rich used
purchase one of
ready to install
of the upper tube
including threaded
nose gear?
Thank you for
your help,
Lyle
Hendricks
Hendricks Mfg.,
Inc.
208-476-7740
bakerocb
PostPosted: Thu Apr 14, 2016 7:06 pm    Post subject: TR-1 Nose Gear Reply with quote
4/14/2016
Hello Graham, Thanks for the quick response. A picture or two would be great also.
OC
PS: We are also very curious as to how long the threaded portion at the bottom of the lower vertical stub is and how the threaded portion is attached to the larger diameter stub material immediately above the threaded portion. Please see the attached picture.
bakerocb at cox.net
From: Graham Brighton (gbrighton(at)skymesh.com.au)
Sent: Thursday, April 14, 2016 5:55 PM
Hi Guys,
  My TR1 Nose gear Leg is disassembled and is at the Hanger .... I'll try to get there tomorrow and check physical Dimensions and report back .,
Cheers
Graham .
Sent: Friday, April 15, 2016 5:17 AM
To: Mark Trickel (marktrickel(at)gmail.com) ; KIS-LIST MATRONICS (kis-list(at)matronics.com) ; hagerson(at)pacbell.net (hagerson(at)pacbell.net)
4/14/2016
OC
 Filesize:  638.4 KB
 Viewed:  4783 Time(s)
