mhealydds
Posted: Sun Apr 10, 2016 9:36 am Post subject: Bleeding Brakes |
Any thoughts.....I have trying to bleed my brakes as per instructions in Grove brake instructions (pumping up with oil can) to test for leaks and such. I have done it twice and seem to get same result. I get a great hard pedal on pilot (left) side for both right and left brakes but cannot get seem to get same result on co-pilot (right) side for either pedal. What am I doing wrong here?
Posted: Sun Apr 10, 2016 9:53 am Post subject: Bleeding Brakes |
Are you sure you have the lines routed correctly?
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
| Quote: | On Apr 10, 2016, at 1:36 PM, mhealydds <mhealydds(at)gmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=454797#454797
Lew Gallagher
Posted: Sun Apr 10, 2016 10:00 am Post subject: Bleeding Brakes |
We had similar issues when first activating the system, and again when
replaced "O" rings. Finally got tired of fiddling with it and while
applying pressure on the right wheel cylinder input nipple, cracked the line
at the co-pilot foot pedal to get the air out and it solved the problem.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
kearney
Posted: Sun Apr 10, 2016 10:07 am Post subject: Re: Bleeding Brakes |
Hi
When I was first bleeding my brakes I had a b*tch of a time getting it done right. The problem was one of the pedals was ever so slightly forward so that the valve in the cylinder was closed and the cylinder was not being bled.
I suggest you check that the pedals are all fully back so that the cylinder valves are open when bleeding.
If you a park brake, be sure it is disengaged as well. Don't ask about how I know that little gem....
Cheers
Les
Dave Saylor
Posted: Sun Apr 10, 2016 10:09 am Post subject: Bleeding Brakes |
I use a pressurized brake bleeder from ATS: http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=225DX
I just use a 1/4" tube just pressed onto the bleeder instead of the rig they supply. They both leak about the same. The trick is to keep the pot pressurized and keep the flow rate high enough to grab the little bubbles that get stuck to the sides of the tube. It's probably overkill but I tapped a pressure gauge into the pot. I keep it around 15 PSI.
You'll get more bubbles out the reservoir if you slowly move each brake pedal off it's stop.
Also, you might try putting a drop of hydraulic fluid on the top of the cylinder to re-wet the seal, especially if air seems to be entering like a slow leak.
--Dave
On Sun, Apr 10, 2016 at 10:36 AM, mhealydds <mhealydds(at)gmail.com (mhealydds(at)gmail.com)> wrote:
| Quote: | --> RV10-List message posted by: "mhealydds" <mhealydds(at)gmail.com (mhealydds(at)gmail.com)>
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
_________________ --Dave
KWVI |
Posted: Sun Apr 10, 2016 10:37 am Post subject: Bleeding Brakes |
Another trick I use to get the air out. Attach a 1/4" AN fitting (1/8" pipe
thread) to the top of the brake reservoir. From this fitting attach a short
U of 1/4" aluminum tubing and end in a jar.
The problem I had was getting the air out. With this set up I can pump from
the caliper and watch the air bubbles come out of the reservoir. I had to
pump a lot of fluid to get the last air bubbles out.
Carl
