victorbravo(at)sbcglobal. Guest
Posted: Mon Mar 21, 2016 9:55 am Post subject: Elevator/Stabilizer hinge ass'y |
Are there any Kolb people on this list who are qualified mechanical or aero-structure engineers? I want to ask a question about the tail attachment mechanism.
Before I even mention the question, I want to assure everyone that I AM COMPLETELY AWARE that there are X thousand Kolbs flying around safely with this stabilizer attachment. I understand that there have not been many (or perhaps any) failures of this mechanism. What I am asking about is the theoretical "correctness" of the design, and whether any other "old-school" airplane people think that this system is a little wonky.
It took a few moments to finally understand how the mechanism works, and after looking at everything several times it was clear that there is no direct structural attachment between the main spar tube of the stabilizer to the fuselage tube (tailboom). The primary structural load path between the root end of the main stabilizer spar tube and the fuselage is transmitted through the elevator hinge... and this hinge isn't even the aircraft style extruded hinge.
So if the air loads try to lift up or push down on the root end of the stabilizer, it puts all that load through the hinge, into the elevator pivot, and then finally into the steel ring at the back of the fuselage.
But that's not even the biggest issue in my head. The larger issue is that (according to plan) the flat hinge is riveted to the tubes along one thin "point of contact" line tangent to the tube. So the root stabilizer load is all acting on a hinge, which itself is cantilevered off of one tangent point on the tube.
Now I'm not a degreed engineer, and I'm not a mathematician. So I called a friend of mine who is a retired aerospace structural engineer, with 50+ years of experience. I showed him the plans and explained my concern, and I was informed that my concerns about this system were valid. My Kolb will be built with a more stable attachment.
My question for any real, degreed, qualified, aircraft-experience engineers is... has anyone looked at the stabilizer root attachment load path and had these same concerns?
ONCE AGAIN, this is not an attack on Mr. Kolb or his design, and it is not intended to cause any panic or concern at this point. What I want to know is why this load path - through two tangent mounted hinge halves, into a movable elevator, and then into the fuselage - is good enough, and why it was not appropriate to install an attachment bracket onto the fuselage at the rear stabilizer spar.
Bill Berle
www.ezflaphandle.com - safety & performance upgrade for light aircraft
www.grantstar.net      - winning proposals for non-profit and for-profit entities
rickofudall
Posted: Mon Mar 21, 2016 1:40 pm Post subject: Elevator/Stabilizer hinge ass'y |
The rear attachment of the horizontal stabilizer is NOT through the hinge. It is through the rear folding weldments that also act as the inner hinge. When it is set up correctly the hinge line is on the same center as the swivel bolt in the weldment, however there is some allowance for misalignment. In that case the weldment in the elevator spar (forward tube of the elevator), can slide on the bolt in the swivel weldment.I've seen folding mechanisms on the Kit Fox and repaired the mechanism on the Highlander and in my HO Homer's is the most clever. All you have to do to fold the HS on a Kolb is to take out a single bolt that attaches the lower wires to the rudder post. I'm not sure how you would make it any simpler.
Rick Girard
On Mon, Mar 21, 2016 at 12:55 PM, Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)> wrote:
| Quote: | --> Kolb-List message posted by: Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)>
Bill Berle
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
     -Matt Dralle, List Admin.
FORUMS -
b Site -
“Blessed are the cracked, for they shall let in the light.�   Groucho Marx
Eugene Zimmerman
zeprep251(at)aol.com Guest
Posted: Mon Mar 21, 2016 2:28 pm Post subject: Elevator/Stabilizer hinge ass'y |
Have to realize Bill,we are talking sub sonic here.A Kolb may not be what you’re looking for if you don’t care what it weighs.A TBM may be down your ally.I hear they’re pretty stout .Good luck finding a kit. | Quote: | On Mar 21, 2016, at 6:13 PM, Eugene Zimmerman <etzimm(at)gmail.com (etzimm(at)gmail.com)> wrote:
| Quote: | So I called a friend of mine who is a retired aerospace structural engineer, with 50+ years of experience.
LOL
The cognitive acuity of anyone with 50+ years of experience should probably be suspect.
Trust me, I have 50+ years of experience.
Posted: Mon Mar 21, 2016 2:30 pm Post subject: Elevator/Stabilizer hinge ass'y |
I hope I'm wrong, but my review of the plans indicated that there is no traditional DIRECT structural connection between the rear spar tube and the fuselage tube. All the load paths have to take a serpentine route and go rearward through the elevator hinges first, and only then into the U-joint and pivot bolt in the steel ring. If you removed the elevator hinges (from either the elevator or the stabilizer), or if you took the pin out of the hinges, you could move the stabilizer up and down freely while the elevator remained bolted to the fuselage.
Even WITH all the hinges in place, all up and down movement of the stabilizer is transmitted through the rivets that hold the hinge onto the tubes, and there is no significant stiffness or bracing against this movement. Essentially you could move the root end of the stabilizer up and down by hand and this movement would bend the (un-supported section of) the hinge material. This would attempt to pry the rivets out of the tube and/or bend the thin metal back and forth.
Also, because of this design the forward stabilizer attach bolt must be a loose fit, and the stabilizer has to be able to slide back and forth a little.
The only thing that is gained by this unusual structural load path is that 4 ounces of weight for a pair of fittings (at the rear stabilizer spar) is saved. Can any one explain to me why this was a good bargain?
Bill Berle
On Mon, 3/21/16, Richard Girard <aslsa.rng(at)gmail.com> wrote:
Subject: Re: Elevator/Stabilizer hinge ass'y
To: "kolb-list(at)matronics.com" <kolb-list(at)matronics.com>
Date: Monday, March 21, 2016, 2:40 PM
The rear attachment
Rick Girard
at 12:55 PM, Bill Berle <victorbravo(at)sbcglobal.net>
extruded hinge.
concerns?
Bill Berle
www.ezflaphandle.comÂ
www.grantstar.net  Â
entities
br>
fts!)
r>
rel="noreferrer"
-List" rel="noreferrer"
target="_blank">http://www.matronics.com/Navigator?Kolb-List
FORUMS -
eferrer"
target="_blank">http://forums.matronics.com
b Site -
rel="noreferrer"
“Blessed
Marx
Posted: Mon Mar 21, 2016 2:31 pm Post subject: Elevator/Stabilizer hinge ass'y |
Understood, but in this case the person in question is sharp as a tack. It's MY cognitive acuity that is suspect !
Bill Berle
To: "Kolb list" <kolb-list(at)matronics.com>
Date: Monday, March 21, 2016, 3:13 PM
On Mar 21,
2016, at 1:55 PM, Bill Berle <victorbravo(at)sbcglobal.net>
experience.
LOLÂ
suspect.Trust me, I have
50+ years of experience. Â
rowedenny
Posted: Tue Mar 22, 2016 9:03 am Post subject: Elevator/Stabilizer hinge ass'y |
Somebody notify John Hauck, as Miss Pfer has around 4000 hours on her airframe and has taken an eighty horse and two 100 horse Rotax 912 engines well toward their TBO! The horizontal stabilizer must be ready to fall off at any second.
Maybe I can get a good deal on her since her demise must be imminent. 😉
Bill, just build the dang Firestar to plans and fly it. It won't fall apart.
Dennis "Skid" Rowe
Mk-3 Rotax 690, with a stock Kolb empennage.😱
| Quote: | On Mar 21, 2016, at 6:29 PM, Bill Berle <victorbravo(at)sbcglobal.net> wrote:
Bill Berle
The rear attachment
Rick Girard
extruded hinge.
concerns?
Bill Berle
www.grantstar.net
entities
br>
fts!)
r>
rel="noreferrer"
FORUMS -
eferrer"
b Site -
rel="noreferrer"
“Blessed
Marx
Posted: Tue Mar 22, 2016 9:43 am Post subject: Elevator/Stabilizer hinge ass'y |
I wish I could have placed a bet in Las Vegas as to how quickly some of the people would jump in and say that these airplanes have X number of hours and Y number of landings without failure. I would have been able to buy another Kolb
With all due respect to everyone, I KNOW that these airplanes are not falling out of the sky.
Now, also with all due respect, can someone with engineering knowledge tell me, ON A TECHNICAL ENGINEERING level, how it could EVER be considered as good design practice to essentially cantilever a piano hinge off of a thin wall round tube, with one line of rivets at the tangent contact point, and with flight loads often perpendicular to that axis, where that cantilever loaded hinge is not only connecting two pieces of primary aircraft structure but also attaching a primary control surface ?
Bill Berle
Date: Tuesday, March 22, 2016, 9:59 AM
second.
imminent. 😉
won't fall apart.
Dennis "Skid" Rowe
> Bill Berle
> www.grantstar.net   Â
for-profit entities
ass'y
> The rear attachment
It is
the
is
that
the
my
that
> Rick Girard
qualified
a
stabilizer
(or
asking
wonky.
several
to
load
tube
> extruded hinge.
root
the
the
is
is
tube.
retired
experience.
was
My
at the
same
> concerns?
design,
this
through
elevator,
was
the
> Bill Berle
> www.grantstar.net Â
>Â Â Â Â Â - winning proposals for
> entities
> br>
> fts!)
> r>
> rel="noreferrer"
> target="_blank">http://www.matronics.com/contribution
>Â Â Â Â Â Â Â -Matt
Dralle, List Admin.
>Â FORUMS -
> eferrer"
> b Site -
>Â Â Â Â Â Â Â -Matt
Dralle, List Admin.
> rel="noreferrer"
> “Blessed
light.�   Groucho
> Marx
Lists This Month --
Some AWESOME FREE Gifts!)
Raiser. Click on
more about
Gifts provided
       -Matt
Dralle, List Admin.
Forum -
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
       -Matt
Dralle, List Admin.
ceengland7(at)gmail.com Guest
Posted: Tue Mar 22, 2016 10:51 am Post subject: Elevator/Stabilizer hinge ass'y |
Any way to post a pic of the assembly, or the construction drawing, for
those of us who don't have that model to inspect? Not the entire set of
plans, of course; just the area in question.
On 3/22/2016 12:39 PM, Bill Berle wrote:
Bill Berle
second.
imminent. 😉
won't fall apart.
Dennis "Skid" Rowe
> Bill Berle
> www.grantstar.net
for-profit entities
ass'y
> The rear attachment
It is
the
is
that
the
my
that
> Rick Girard
qualified
a
stabilizer
(or
asking
wonky.
several
to
load
tube
> extruded hinge.
root
the
the
is
is
tube.
retired
experience.
was
My
at the
same
> concerns?
design,
this
through
elevator,
was
the
> Bill Berle
stuart(at)harnerfarm.net Guest
Posted: Tue Mar 22, 2016 11:31 am Post subject: Elevator/Stabilizer hinge ass'y |
Bill,
I am not an engineer but I did stay in a Holiday Inn last night. No, not really, but I do have a fundamental understanding of load transmission through a structure.
First a question, and please don't be offended. Have you had an opportunity to observe the structure of the Kolb tail while it was being folded and then again when it is bolted into place? I asked this because I found a couple of things in the plans of the Firefly that I did not understand until I was able to actually see it live. Simply put, I had trouble visualizing it from just the plans.
One thing that I think is missing from this discussion is the loads carried by the brace wires. I would posit that most of the forces from the tail that are transmitted to the boom tube are carried by the braces. These, when properly tensioned are actually pre-loaded slightly. This puts the tubes in compression which makes the whole thing quite strong. It also transfers the loads from the horizontals to the steel post of the verticals which in turn is transferred to the boom tube via the steel ring which is bolted and/or riveted to the tube.
Of course some loads are transferred through the hinge points and the front hinge must be able to slide slightly as the elevator moves through its arc of travel. Could this be made stronger? Of course, but not without sacrificing something else such as weight or foldability. It is actually a very clever design and I suspect that the majority of loads that move through the rear hinge come from the elevator and not the stabilizer.
I would also bet that the loads carried through the hinges is far below the shear and tension limits of properly installed rivets.
I am actually more "freaked out" by the fact that everything in the tail depends on that one little 3/16" bolt (Firefly) that holds the lower braces in place. Really, the threads on that bolt are all there is between you and falling out of the sky. To combat this irrationality I swap out the bolt fairly often and the nuts even more often. If it really bothered me, I would stay on the ground.
Perhaps you could send a copy of your plans to Barnaby Wainfan and ask for his analysis. I hear he is a really nice guy. From reading his articles over the years I am sure he could provide the answers you seek.
As Uncle Red used to say: "Remember, if women don't find you handsome, they should at least find you handy"
Stuart
rmurrill(at)cox.net Guest
Posted: Tue Mar 22, 2016 11:33 am Post subject: Elevator/Stabilizer hinge ass'y |
I suffer from the same 50 year malady you mentioned earlier, but would
suggest you propose to your aero/ structures engineer
friend a couple of alternate details. I would agree that the structural
configuration is non standard, with the appearance of some odd geometric
coupling, but it has clearly worked well for many years and tens of
thousands of hours fleet time regardless of the Las Vegas odd makers.
The main point is the loads are very small compared to the strength of the
hardware...arguably by more than an order of magnitude.
Flying downloads on the horizontal tail are probably in the
50 lb maybe 100 lb at the most to provide flyable static pitch and speed
stability. Low aspect ratio and taper puts the center of pressure fairly
close to the wire bracing attachments, probably forward and inboard, so most
of these downloads are taken out as tension in those wires and compression
in the vertical stabilizer tube. Smaller loads are reacted at the root
bolts and across the hinges. One would not attempt to design the structure
for full elevator deflection at
Vne, so reasonably one would only ever see relatively modest changes in the
aero down loads throughout the flight spectrum. A fairly extreme case that
would develop very high pitch rates and require elevator correction would be
full power to idle or the reverse. That would produce about 300 lb of force
at maybe 2 ft
above the cg and would require a change in tail download of about
40 lb assuming the moment arm is about 15 ft. So that’s 20 lb per side.
Each of the hinge rivets assuming they are 1/8th inch is good for 120 lbs
single shear. The load is shared by lots of rivets. The bolts are I
believe 5/16 which are good for 5,500 lb single shear even if only grade 5.
I would argue that the hinges, dozens of rivets and large diameter pivoting
bolts appear
to be overdesigned for the basic small aero loads of this aircraft. Fatigue
loads from the prop wash swirl could be an issue,
but apparently not from fleet experience.
Ultimate static strength is most likely dictated by the aluminum tubing
substructure, not by the rivets, hinges, or support bolts....
I recommend not trying to improve the design!
Bob
Jim Baker
Posted: Tue Mar 22, 2016 12:09 pm Post subject: Elevator/Stabilizer hinge ass'y |
Now the onus is on you. Post one single incident of horizontal stab/elevator failure. Just one.
On the other hand, they are experimental and you, the builder, are the experimenter. Press on. Could care less.
Jim Baker
405 426 5377
lcottrell
Posted: Tue Mar 22, 2016 12:13 pm Post subject: Elevator/Stabilizer hinge ass'y |
Berle wrote:"I wish I could have placed a bet in Las Vegas as to how quickly some of thepeople would jump in and say that these airplanes have X number of hours andY number of landings without failure. I would have been able to buy anotherKolb "
Not to put too fine a point on the discussion, but the reason that you heard the phrase that you knew would be coming, is that we too have seen this all before as well. I have at least one friend that always had to improve every thing that he bought, simply because that was his disease. That's ok, what ever spins your prop. If reinventing the wheel is your thing, give er hell.
I have had VG's for years, as have quite a few of the guys. I have had 4130 longer gear legs for at least a couple of years, so have quite a few of the guy's. Yep, it helps the plane perform better. I have also crashed at least three times and the worst that I got besides humility was a sprained left middle finger. So I personally am a fan of the way that Homer designed the plane. It fits my mission perfectly.Â
If the one that you bought does not fit the mission as you see it, by all means tweak it any way that makes you happy.
I have also seen several guys on the list that were convinced that a bit of this and a bit of that would make the plane perform just fine with one of the other types of engines. I don't think any of them are still flying them because it turned a perfectly fine plane into something that flew like a C150, and was about as much fun to fly as watching grass grow. Again, you are a big boy, and apparently you have a better idea, by all mean have at it. I know one guy that just had to have a 1/2 VW on his plane. We on the list went through about 2 years of trying and eventually he gave up, sold the plane and never flew again.
So you see, we too have seen some of this before. Now I personally don't want to hurt your feelings, but the little smiley face in your message didn't quite take all the sting out of your last post. We will see if I can do a bit better, or at least as good. No body here cares if you can improve your plane. It is your and yours alone, tweak it any way you like. If it is a real improvement we might want to do the same, just try to not tell me how stupid I am because mine does just exactly what I want and need.
Larry
On Tue, Mar 22, 2016 at 1:33 PM, Bob <rmurrill(at)cox.net (rmurrill(at)cox.net)> wrote:
[quote]--> Kolb-List message posted by: "Bob" <rmurrill(at)cox.net (rmurrill(at)cox.net)>
at maybe 2 ft
bolts appear
Bob
neilsenrm(at)gmail.com Guest
Posted: Tue Mar 22, 2016 12:19 pm Post subject: Elevator/Stabilizer hinge ass'y |
Bill
It might be helpful to look at a completed airplane. You may not be visualizing correctly the drawings you are looking at. The design works and it can be folded.
Years ago we had a guy that felt he had to fix everything on the Kolb MKIII that he was building. He made a valiant effort in completing the plane. He must have spent 3-4 thousand extra hours working on all the changes. Luckily he never completed the airplane. He was a great guy and is still alive because he didn't ever fly that plane.
My advice is build the plane exactly by the plans. There are a few really good changes that a few people have tried to tell you about but???Â
If you absolutely must make all the changes you are talking about get real good insurance for your love ones and DO NOT call it a Kolb. Don't even mention it started as a Kolb kit. Also please quit talking about all the issues you think are wrong, somebody might think you know what you are talking about and hurt themselves too. Sorry the proof is in the massive hours in the fleet.
Did anyone ever tell you about one of the Kolb employees that took a plane up and intentionally tried to tear the plane apart. He finally with considerable effort ripped the wings off, he threw out a chute and later fixed the point of failure. Our planes are well designed and tested.
Even with all that evidence I will still say my advice is worth what you paid for it.
Rick Neilsen
Redrive VW Powered
On Tue, Mar 22, 2016 at 1:39 PM, Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)> wrote:
Bill Berle
On Tue, 3/22/16, Dennis Rowe <rowedenny(at)windstream.net (rowedenny(at)windstream.net)> wrote:
 second.
 imminent. 😉
 won't fall apart.
 Dennis "Skid" Rowe
 > On Mar 21, 2016, at 6:29 PM, Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)>
 wrote:
 > --> Kolb-List message posted by: Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)>
 > I hope I'm wrong, but my review of the plans indicated
 > Even WITH all the hinges in place, all up and down
 > Also, because of this design the forward stabilizer
 > The only thing that is gained by this unusual
 > Bill Berle
 > www.ezflaphandle.com - safety & performance
 > www.grantstar.net   Â
 for-profit entities
 > On Mon, 3/21/16, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)>
 wrote:
 > Subject: Re: Elevator/Stabilizer hinge
 ass'y
 > To: "kolb-list(at)matronics.com (kolb-list(at)matronics.com)"
 <kolb-list(at)matronics.com (kolb-list(at)matronics.com)>
 > Date: Monday, March 21, 2016, 2:40 PM
 > The rear attachment
 > of the horizontal stabilizer is NOT through the hinge.
 It is
 > through the rear folding weldments that also act as
 the
 > inner hinge. When it is set up correctly the hinge line
 is
 > on the same center as the swivel bolt in the weldment,
 > however there is some allowance for misalignment. In
 that
 > case the weldment in the elevator spar (forward tube of
 the
 > elevator), can slide on the bolt in the swivel
 > weldment.I've seen folding mechanisms on the Kit
 > Fox and repaired the mechanism on the Highlander and in
 my
 > HO Homer's is the most clever. All you have to do to
 > fold the HS on a Kolb is to take out a single bolt
 that
 > attaches the lower wires to the rudder post. I'm not
 > sure how you would make it any simpler.
 > Rick Girard
 > On Mon, Mar 21, 2016
 > at 12:55 PM, Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)>
 > Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)>
 > Are there any Kolb people on this list who are
 qualified
 > mechanical or aero-structure engineers? I want to ask
 a
 > question about the tail attachment mechanism.
 > Before I even mention the question, I want to assure
 > everyone that I AM COMPLETELY AWARE that there are X
 > thousand Kolbs flying around safely with this
 stabilizer
 > attachment. I understand that there have not been many
 (or
 > perhaps any) failures of this mechanism. What I am
 asking
 > about is the theoretical "correctness" of the
 > design, and whether any other "old-school"
 > airplane people think that this system is a little
 wonky.
 > It took a few moments to finally understand how the
 > mechanism works, and after looking at everything
 several
 > times it was clear that there is no direct structural
 > attachment between the main spar tube of the stabilizer
 to
 > the fuselage tube (tailboom). The primary structural
 load
 > path between the root end of the main stabilizer spar
 tube
 > and the fuselage is transmitted through the elevator
 > hinge... and this hinge isn't even the aircraft style
 > extruded hinge.
 > So if the air loads try to lift up or push down on the
 root
 > end of the stabilizer, it puts all that load through
 the
 > hinge, into the elevator pivot, and then finally into
 the
 > steel ring at the back of the fuselage.
 > But that's not even the biggest issue in my head. The
 > larger issue is that (according to plan) the flat hinge
 is
 > riveted to the tubes along one thin "point of
 > contact" line tangent to the tube. So the root
 > stabilizer load is all acting on a hinge, which itself
 is
 > cantilevered off of one tangent point on the
 tube.
 > Now I'm not a degreed engineer, and I'm not a
 > mathematician. So I called a friend of mine who is a
 retired
 > aerospace structural engineer, with 50+ years of
 experience.
 > I showed him the plans and explained my concern, and I
 was
 > informed that my concerns about this system were valid.
 My
 > Kolb will be built with a more stable attachment.
 > My question for any real, degreed, qualified,
 > aircraft-experience engineers is... has anyone looked
 at the
 > stabilizer root attachment load path and had these
 same
 > concerns?
 > ONCE AGAIN, this is not an attack on Mr. Kolb or his
 design,
 > and it is not intended to cause any panic or concern at
 this
 > point. What I want to know is why this load path -
 through
 > two tangent mounted hinge halves, into a movable
 elevator,
 > and then into the fuselage - is good enough, and why it
 was
 > not appropriate to install an attachment bracket onto
 the
 > fuselage at the rear stabilizer spar.
 > Bill Berle
 > - safety & performance upgrade for light aircraft
 >     - winning proposals for
 > entities
 > br>
 > fts!)
 > r>
 > target="_blank">www.buildersbooks.com
 > rel="noreferrer"
 > target="_blank">http://www.matronics.com/contribution
 >       -Matt
 Dralle, List Admin.
 > -List" rel="noreferrer"
 > target="_blank">http://www.matronics.com/Navigator?Kolb-List
 > FORUMS -
 > eferrer"
 > target="_blank">http://forums.matronics.com
 > b Site -
 >       -Matt
 Dralle, List Admin.
 > rel="noreferrer"
 > “Blessed
 > are the cracked, for they shall let in the
 light.�   Groucho
 > Marx
 Lists This Month --
 Raiser. Click on
 more about
 Gifts provided
        -Matt
 Dralle, List Admin.
 Forum -
        -Matt
 Dralle, List Admin.
br> fts!)
FORUMS -
b Site -
Posted: Tue Mar 22, 2016 12:40 pm Post subject: Elevator/Stabilizer hinge ass'y |
Thank you all for the replies. I appreciate the opportunity to discuss this, without people thinking that I am trashing the aircraft, or insulting Mr. Kolb's legacy.
Yes I had considered that some part of the tail loads are carried by the brace wires, this is why I referred to the questionable part as the stabilizer "root loads" instead of the whole stabilizer. Of course, just like a strut braced wing there is a large "inward" (compression) load on the tube, but since the elevator is tapered there is still a large portion of the force generated that is vertical at the root end.
Those rivets holding the hinge may well be capable of 120 pounds in shear, or perhaps even in tension. I have no quarrel whatsoever with the strength of the rivets on such a light and slow aircraft. And yes there are a lot of them.
But the angular ORIENTATION of the hinges, and the fact that the hinges are somewhat "cantilevered" as I have called it, puts a "peel" load on those fasteners, like a crow bar trying to peel and pop the heads off the rivets at an angle. That is probably the worst case for those rivets. The failure mode would be that the loads are rocking the rivets slowly back and forth, loosening them.
Also, the hinges themselves are not designed for the loads to be hanging out 3/8 or 1/2 inch from their attachment, like a diving board.
One person replied that I may not be understanding the mechanism, and how it folds, and that the front attachment moves a little. I have taken a little time to study the plans and try to understand this. I believe that I understand it (whether I agree with the design or not). If the rear stabilizer attachment is in fact located on exactly the same axis as the elevator hinge, then the front of the stabilizer should not need to move fore and aft at all with elevator deflection. Elevator deflection could create fore-aft (or up-down) movement ONLY if there IS some amount of offset between the hinge axis and the rear stabilizer mounting. If the two axes are concentric, there could not be any linear motion by definition.
I believe that the only reason the front stabilizer attachment has to be able to slide a little is because in reality for the average builder it is very difficult to locate the hinges at precisely the center of the welded elevator horn/ pivot mechanism. Without any jig or fixture to guarantee the exact location of the hinge pin in open space, it is etoo asy for the hinge pin to be a little bit fore-aft or up-down... while the holes are drilled and the rivets are installed.
So I am guessing that to make it easier for the builder, and to prevent binding and cracking of the parts, the front attachment was left a little loose and the rear attachment was eliminated.
Bill Berle
Posted: Tue Mar 22, 2016 1:14 pm Post subject: Elevator/Stabilizer hinge ass'y |
Wow. Please forgive me if anyone thought that I was being too aggressive or questioning. Holy Mackerel, I was discussing innovation, experimentation, and individuality in light aircraft construction.
Apparently there is no room for improvement in the design, and there were no compromises made in manufacturing the kits. Thankfully, none of this reliance on status quo was in force back when Mr. Kolb was experimenting with a new way to build and improve on his personal aircraft designs.
My sincerest apology for the unintended effect of there being a "Sting" in any of my comments. Absolutely unintentional.
| Quote: | From this point I will try to constrain my questions and comments within direct relevance to the existing design, or what has been done (or modified) already.
Bill Berle
Date: Tuesday, March 22, 2016, 1:19 PM
Bill
folded.
fly that plane.
but???Â
the fleet.
tested.
Rick NeilsenRedrive VW Powered
at 1:39 PM, Bill Berle <victorbravo(at)sbcglobal.net>
another Kolb
Bill Berle
www.grantstar.net  Â
entities
ass'y
Â
two
 second.
be
 imminent. 😉
It
 won't fall apart.
 Dennis "Skid" Rowe
 > On Mar 21, 2016, at 6:29 PM, Bill Berle <victorbravo(at)sbcglobal.net>
indicated
rearward
the
you
rivets
up
to
pair
any
 > Bill Berle
 > www.ezflaphandle.comÂ
 Â
 for-profit entities
 > On Mon, 3/21/16, Richard Girard <aslsa.rng(at)gmail.com>
 ass'y
 > To: "kolb-list(at)matronics.com"
hinge.
 It is
 the
line
 is
weldment,
 that
of
 the
in
 my
to
 that
not
 > Rick Girard
 > at 12:55 PM, Bill Berle <victorbravo(at)sbcglobal.net>
 > wrote:
 > Bill Berle <victorbravo(at)sbcglobal.net>
 qualified
ask
 a
 stabilizer
many
 (or
 asking
the
 wonky.
 several
structural
stabilizer
 to
 load
spar
 tube
style
 > extruded hinge.
the
 root
 the
into
 the
The
hinge
 is
itself
 is
 tube.
a
 retired
 experience.
I
 was
valid.
 My
looked
 at the
 same
 > concerns?
 design,
at
 this
 through
 elevator,
it
 was
onto
 the
 > Bill Berle
aircraft
 > entities
 > br>
 > fts!)
 > r>
rel="noreferrer"
 > rel="noreferrer"
 >       -Matt
 Dralle, List Admin.
 > FORUMS -
 > eferrer"
 > b Site -
 >       -Matt
 Dralle, List Admin.
 > rel="noreferrer"
 > “Blessed
 light.�   Groucho
 > Marx
 Lists This Month --
 Raiser. Click on
 more about
 Gifts provided
        -Matt
 Dralle, List Admin.
 Forum -
Site -
        -Matt
 Dralle, List Admin.
br>
fts!)
r>
rel="noreferrer"
FORUMS -
eferrer"
b Site -
rel="noreferrer"
undoctor(at)rcn.com Guest
Posted: Tue Mar 22, 2016 2:09 pm Post subject: Elevator/Stabilizer hinge ass'y |
Bill,
If you search through the archives or Google Kolb Aircraft history, you may find a photo of Homer sitting on his Kolb Flyer dated 1956. That's about 60 years ago and 30 years before ultralights existed as a classification of aircraft. It was powered by 4 chain saw engines.
Prior to that photo, Homer, the farm boy who wanted to fly, experimented with aircraft he built that was pulled by a boat on the Schuylkill River. One day a young lad was sitting on the bank of the river and witnessed a wing fold and Homer took a bath.
There were two results of that incident: first, Homer stopped using hardware store eye bolts, and second, the young lad got an education in aeronautical engineering and later went to work for Homer. He is the man who was testing G's, folded a wing and threw out the hand held 'chute in order to live.
Also, as has been mentioned, Kolbs have been proven over many years and tens of thousands of hours. I believe the problem lies in that, whether or not you realize it, you come across as having the opinion that before you came on the scene there was never anyone who could think things through as thoroughly and analytically as you.
Trust me when I tell you that that's a huge error.
Enjoy your building time, Bill. As you should have already noticed there's a lot of experience and helpful people on the list. Be careful not to abuse their kindness.
Dave Kulp
Bethlehem, PA
ex: Chicken Hawk
ex: Ultrastar
ex: FireFly
Sent from my Verizon Wireless 4G LTE smartphone
Date:03/22/2016 5:10 PM (GMT-05:00)
Subject: Re: Kolb-List: Elevator/Stabilizer hinge ass'y
--> Kolb-List message posted by: Bill Berle <victorbravo(at)sbcglobal.net>
Bill Berle
Bill
folded.
fly that plane.
but???
the fleet.
tested.
another Kolb
Bill Berle
www.grantstar.net
entities
ass'y
two
second.
be
imminent. 😉
It
won't fall apart.
Dennis "Skid" Rowe
indicated
rearward
the
you
rivets
up
to
pair
any
> Bill Berle
> www.grantstar.net
for-profit entities
ass'y
> The rear attachment
hinge.
It is
the
line
is
weldment,
that
of
the
in
my
to
that
not
> Rick Girard
qualified
ask
a
stabilizer
many
(or
asking
the
wonky.
several
structural
stabilizer
to
load
spar
tube
style
> extruded hinge.
the
root
the
into
the
The
hinge
is
itself
is
tube.
a
retired
experience.
I
was
valid.
My
looked
at the
same
> concerns?
design,
at
this
through
elevator,
it
was
onto
the
> Bill Berle
aircraft
> www.grantstar.net
> entities
> br>
> fts!)
> r>
rel="noreferrer"
> rel="noreferrer"
> -Matt
Dralle, List Admin.
> FORUMS -
> eferrer"
> b Site -
> -Matt
Dralle, List Admin.
> rel="noreferrer"
> “Blessed
light.� Groucho
> Marx
Lists This Month --
Raiser. Click on
more about
Gifts provided
-Matt
Dralle, List Admin.
Forum -
Site -
-Matt
Dralle, List Admin.
br>
fts!)
r>
rel="noreferrer"
FORUMS -
eferrer"
b Site -
rel="noreferrer"
_-============================================================
_-=
_-= -- Please Support Your Lists This Month --
_-= (And Get Some AWESOME FREE Gifts!)
_-=
_-= November is the Annual List Fund Raiser. Click on
_-= the Contribution link below to find out more about
_-= this year's Terrific Free Incentive Gifts provided
_-= by:
_-=
_-= * The Builder's Bookstore www.buildersbooks.com
_-=
_-= List Contribution Web Site:
_-=
_-= --> http://www.matronics.com/contribution
_-=
_-= Thank you for your generous support!
_-=
_-= -Matt Dralle, List Admin.
_-=
_-= - The Kolb-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Kolb-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - List Contribution Web Site -
Posted: Tue Mar 22, 2016 2:33 pm Post subject: Elevator/Stabilizer hinge ass'y |
Thank you Dave,
There was and is no intention of coming across like nobody else had thought this through. Quite the contrary; if I remember correctly, my first post on the subject that started all this turmoil was actually asking about whether other people had questioned this before I came along, and what the reasons were for designing that mechanism in a counter-intuitive manner. I was more surprised than anyone to find that I appeared to be the first person who asked about it.
Bill
you. Trust me when I tell you that that's a huge error.Â
Dave Kulp Bethlehem, PA
Posted: Tue Mar 22, 2016 3:03 pm Post subject: Elevator/Stabilizer hinge ass'y |
Nobody here cares if you can improve your plane.
Larry
This aircraft will be flying over a densely populated area. I believe the vast majority of Kolbs are not being flown over populated areas... am I right about this? The majority of people who have flown with 2 stroke engines over time have had emergency landings due to inflight failures. Even the people who have figured out how to reliably operate the 2 strokes recommend against it when I say that I'm based out of a big city municipal airport. So my discussion about alternate engines was based on this reality. Believe me, it would be quick, cheap and easy to just bolt a 503 on the FireStar like it was designed for.
I'd be absolutely thankful if you would be able to recommend a truly reliable engine for this aircraft (for safe flying over a densely populated area) that is as affordable as a used 503 2 stroke. I already know where to look for engines that are not affordable.
I do NOT "have a better idea", I just have a different priority requirement than most of the Kolb operators do. I need something that is more reliable than the Rotax 2 strokes.
Did me or anyone else tell you that you were stupid, at any time, inferred or expressed?
Posted: Tue Mar 22, 2016 3:32 pm Post subject: Elevator/Stabilizer hinge ass'y |
Bill B/Kolbers:
I'll tell you if there was a cheap, reliable, alternate four stroke power plant for a Kolb aircraft, it would be flying on a lot of Kolbs and other makes of ULs and home builts.
Sometimes one must pay for what he wants. I have. Haven't had an engine out in well over 3,000 hours. Did have a couple engine outs caused by bad fuel, but that was pilot error and had nothing to do with engine reliability.
Some of us have tried to share with you a little of our experience, but it seems you don't want to hear what we have to say.
By now you should recognize there is no elevator hinge problem. If you want to change yours when you get around to getting your hands dirty and actually building a Kolb, have at it.
Fort Campbell, Kentucky
_________________ John Hauck
Titus, Alabama |
