rv9jim(at)juno.com Guest
Posted: Thu Jul 06, 2006 4:59 pm Post subject: Oil fittings on the case |
I am doing this again as I think I failed to get the message through
before. I am installing the oil fittings in the case for the oil cooler.
The straight fitting goes in around the center of the accessory case.
The return fitting goes in just above the right mag and just behind the
oil filter. This fitting is a 45 degree unit and I need to know where to
point the fitting. Does it point downward toward the center of the
engine between the oil filter and right mag or out over the mag toward
the #4 cylinder ? Inquiring minds want to know!
Jim Nelson
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Thu Jul 06, 2006 6:01 pm Post subject: Oil fittings on the case |
Jim,
On my Superior XP-I0-360 B1B (180 hp) the 45 degree fitting is rotated so it
points down maybe 20 degrees from horizontal so the hose clears the oil
filter.
Terry
RV-8A
Seattle
dbris200(at)sbcglobal.net Guest
Posted: Thu Jul 06, 2006 6:04 pm Post subject: Oil fittings on the case |
Mine points toward the #4 cylinder but it kind of depends on just where your oil cooler is going to be hung. I think I'd wait until you install the cooler and hoses before picking a final orientation for the fitting.
Dave
James H Nelson wrote: | Quote: | | Quote: | --> RV-List message posted by: James H Nelson <rv9jim(at)juno.com> (rv9jim(at)juno.com)
Jim Nelson
