12V USB Panel Mount Outlet and ADS-b
rv10flyer(at)live.com
PostPosted: Mon Feb 29, 2016 9:15 pm    Post subject: 12V USB Panel Mount Outlet and ADS-b Reply with quote
I have the same setup Linn- my Stratux sits in the baggage area using a 12v
cigarette adaptor with a 2.4A USB, runs from start (when it automatically
powers up to shutdown) Never had an issue with that. BTW- Avare gets you 2-3
times more traffic than FPGo but weather is better on FPGo. With Avare it
uses loads of battery (Samsung Tab 2 has a bad battery to start with) and I
also have the IO app that drives the battery even more, even with all that
load on the Samsung the battery charges faster than it drains.
Les- I have two daughters with two ipad mini running on a 12V USB connection
at the SAME TIME. They both see charging while they use it. I fear you are
using a plug that is either not getting enough power and/or an adaptor that
is overloaded. I think the bluetooth sucks battery on the phone, I usually
disble bluetooth and use the Wifi as a hotspot without battery issues.
This is the one I use and it has worked flawlessly,
http://www.amazon.com/gp/product/B00VH84L5E?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
. For the price it cant be beat it is 2X 2.4Amps.
Best of success!
Pascal
Tim Olson
PostPosted: Mon Feb 29, 2016 10:18 pm    Post subject: 12V USB Panel Mount Outlet and ADS-b Reply with quote
These are what I've been using:
http://www.amazon.com/gp/product/B00E1UWA4O?psc=1&redirect=true&ref_=od_aui_detailpages00
The SCOSCHE USBC242M.
It's also 4.8A total, and does a very fast charge. Costs a little more
than the Anker below,
but is shorter which stays in the socket very well and doesn't stick out
more than
maybe 1/4". I probably own 8 or 10 of them and haven't had one go bad.
Noise free so far in the plane. Just bought 2 more tonight for the RV-14.
The best I've found for AC use that we bring along traveling for the family
(and use at home) is this: (I've bought 3 of them)
http://www.amazon.com/Anker-Charger-PowerPort-Multi-Port-Samsung/dp/B00VH8ZW02/ref=sr_1_1?s=wireless&ie=UTF8&qid=1456812858&sr=1-1&keywords=anker+5-port
The Anker 40W/8A 5-port charger. You can't go wrong with that one.
It charges as fast as the device can take.
Both of the above have replaced all the other various USB chargers
that I've bought or received with phones and devices. Having the
extra port(s) makes them much nicer than the standard ones.
a 12v cigarette adaptor with a 2.4A USB, runs from start (when it
automatically powers up to shutdown) Never had an issue with that.
BTW- Avare gets you 2-3 times more traffic than FPGo but weather is
better on FPGo. With Avare it uses loads of battery (Samsung Tab 2 has
a bad battery to start with) and I also have the IO app that drives
the battery even more, even with all that load on the Samsung the
connection at the SAME TIME. They both see charging while they use it.
I fear you are using a plug that is either not getting enough power
and/or an adaptor that is overloaded. I think the bluetooth sucks
battery on the phone, I usually disble bluetooth and use the Wifi as a
Best of success!
Pascal
