kearney
Posted: Mon Feb 29, 2016 6:10 pm Post subject: 12V USB Panel Mount Outlet |
Hi
I have found that my IPAD doesn't seem to charge all that well with the USB outlets I installed in my panel / console. They are rated at 2.1 amps but I guess there must be more to it than that.
Does anyone have a part # / recommendation for a mountable USB port.
Inquiring minds need to know....
Cheers
Les
daviid(at)gmail.com Guest
Posted: Mon Feb 29, 2016 6:19 pm Post subject: 12V USB Panel Mount Outlet |
You will need a sub outlet rated for 2.1 or more amps. Here is one that is dual port 4.2amps capable. I
www.aircraftspruce.com/catalog/elpages/eadualusbpanel.php?clickkey=6431
Sent from my iPad
Quote: | On Feb 29, 2016, at 9:10 PM, kearney <kearney(at)shaw.ca> wrote:
Hi
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=453311#453311
flying-nut(at)cfl.rr.com Guest
Posted: Mon Feb 29, 2016 6:23 pm Post subject: 12V USB Panel Mount Outlet |
That should be more than enough to keep your iPAD charging. Do you have
a lot of programs running in the background?
I'm an android guy but I'm constantly killing background programs on my
tablet and my wife's iPAD.
Also, there could be something wrong with your outlet ..... or the
iPAD. Plug your iPAD into a cigarette lighter adapter (if you have
one!) to see if it makes any difference.
Linn
On 2/29/2016 9:00 PM, kearney wrote:
Quote: |
Hi
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=453308#453308
jeff(at)westcottpress.com Guest
Posted: Mon Feb 29, 2016 6:49 pm Post subject: 12V USB Panel Mount Outlet |
Stein sells one that charges like a bat out of hell...
Jeff Carpenter
40304
Ready to Roll
On Feb 29, 2016, at 6:00 PM, kearney wrote:
[quote]--> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi
Cheers
Les
-- Please Support Your Lists This (And Get -Matt Dralle, List - The RV10-List --> &n======================== Westcott Press
1121 Isabel Street
Burbank, CA 91506
jeff(at)westcottpress.com (jeff(at)westcottpress.com)
818-861-7300
kearney
Posted: Mon Feb 29, 2016 7:18 pm Post subject: Re: 12V USB Panel Mount Outlet |
Linn
I have been running fltplan.go on the IPAD without a lot of background apps. It does, however use cell data for get wx etc. Often the connection is only 3g or worse which I believe increase the power consumption.
When I last was flying I tried keeping it plugged in but the battery still drained. It may be my USB outlet in combination with the low quality cell signal. When I am next at the airport I will see if turning the cell data off improves the charging.
Cheers
Les
flying-nut(at)cfl.rr.com wrote: | That should be more than enough to keep your iPAD charging. Do you have
Linn
Quote: |
Hi
Cheers
Les
Posted: Mon Feb 29, 2016 7:39 pm Post subject: 12V USB Panel Mount Outlet |
I've been using fltplan.go on the Samsung tablet along with my homebrew
ADS-B receiver lately. Really don't know how to use the program very well.
The cell conversations will certainly drain the battery faster,
especially if fltplan.go updates weather often. I'm sure that turning
cell data off will make the difference.
Linn
On 2/29/2016 10:18 PM, kearney wrote:
Quote: |
Linn
Cheers
Les
> Linn
>> Hi
>> Cheers
>> Les
http://forums.matronics.com/viewtopic.php?p=453318#453318
Bajajim
Posted: Mon Feb 29, 2016 8:20 pm Post subject: 12V USB Panel Mount Outlet |
Make sure you have a 2ma charger not a .5 like most of them and also an oem cable to the Ipad.
I had the same problem.
Sent from my Verizon Wireless 4G LTE smartphone
Date: 02/29/2016 7:38 PM (GMT-08:00)
Subject: Re: RV10-List: Re: 12V USB Panel Mount Outlet
--> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com>
Linn
Quote: | --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca>
Linn
Cheers
Les
> Linn
>> Hi
>> Cheers
>> Les
_-============================================================
_-=
_-= -- Please Support Your Lists This Month --
_-= (And Get Some AWESOME FREE Gifts!)
_-=
_-= November is the Annual List Fund Raiser. Click on
_-= the Contribution link below to find out more about
_-= this year's Terrific Free Incentive Gifts provided
_-= by:
_-=
_-= * The Builder's Bookstore www.buildersbooks.com
_-=
_-= List Contribution Web Site:
_-=
_-= --> http://www.matronics.com/contribution
_-=
_-= Thank you for your generous support!
_-=
_-= -Matt Dralle, List Admin.
_-=
_-= - The RV10-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?RV10-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - List Contribution Web Site -
