rv10free2fly(at)yahoo.com Guest
Posted: Sun Feb 21, 2016 3:07 am Post subject: Bonaco Brake Lines Too Short! |
Hi team
I purchased to pre-fabricated Bonaco brake lines some time ago and went to fit them today, however the two lines that interconnect the pilot and co-pilot brake master cylinders are only 31.5" long, as opposed to the 43" called for in the plans.
Has anyone else encountered this problem with the Bonaco brake line kit?
Warm regards
Patrick
philperry9
Posted: Sun Feb 21, 2016 7:47 am Post subject: Bonaco Brake Lines Too Short! |
I believe they modeled them after my setup a number of years ago. Here's a tour.
https://youtu.be/gemgQmVsOYI
Also, you'll want to make sure you adel clamp the tunnel lines frequently. They're long so they don't sag down and rub on rivet heads. I used the factory clamp locations and then added a 2nd pair between those higher on the tunnel walls. So it kinda makes some S-Turns down the sides of the tunnel.
Phil
On Feb 21, 2016, at 5:01 AM, Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)> wrote:
Posted: Sun Feb 21, 2016 11:17 am Post subject: Bonaco Brake Lines Too Short! |
Thanks Phil
I'm only replacing the lines under the panel. They two in question are way too short.
Warm regards
Patrick
On 22 Feb 2016, at 02:13, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
| Quote: | I believe they modeled them after my setup a number of years ago. Here's a tour.
Phil
| Quote: | --> RV10-List message posted by: Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)>
Hi team
Warm regards
Patri===============================================
http://www.matronics.com/Naviga====================================================; - MATRONICS WEB FORUMS -
| =================================== >www.buildersbooks.com matronics.com/contribution =================================== ://www.matronics.com/Navigator?RV10-List =================================== cs.com =================================== matronics.com/contribution ===================================
jrlark
Posted: Sun Feb 21, 2016 12:22 pm Post subject: Bonaco Brake Lines Too Short! |
Patrick, I’m away from my -10 until April 3rd, but I’m wondering if you had the wrong lines sent to you. I recall the 31” lines where for down the gear legs.
Rick
#40956
Southampton, Ont
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Pulis
Sent: Sunday, 21 February, 2016 2:11 PM
Subject: Re: Bonaco Brake Lines Too Short!
Thanks Phil
Warm regards
Patrick
Phil
Hi team
Warm regards
<snbsp; (and get="" some="" awesome="" free="" gifts!)<p; *="" the="" builder's="" bookstore="" http://www.matronics.com/Naviga===========================; - MATRONICS WEB FORUMS -
<="" span="">
</snbsp; (and>
=================================== >www.buildersbooks.com matronics.com/contribution ========== ://www.matronics.com/Navigator?RV10-List ========== cs.com ========== matronics.com/contribution ==========
Checked by AVG - www.avg.com
Version: 2016.0.7442 / 02/21/16
Posted: Sun Feb 21, 2016 8:14 pm Post subject: Bonaco Brake Lines Too Short! |
Yep, I've used the longer lines down the gear legs, thanks for the heads up Rick.
Warm regards
Patrick
On 22 Feb 2016, at 06:48, Rick & Sandra Lark <jrlark(at)bmts.com (jrlark(at)bmts.com)> wrote:
| Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Rick
#40956
Southampton, Ont
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Patrick Pulis
Thanks Phil
Warm regards
Patrick
Phil
Hi team
Warm regards
<="" span="">
</snbsp; (and>
whodja
Joined: 27 Jan 2014 Posts: 50 Location: Apex NC (near Raleigh)
Posted: Mon Feb 22, 2016 4:31 am Post subject: Re: Bonaco Brake Lines Too Short! |
I installed my Bonaco brake lines a couple of weeks ago and they fit perfect. Call Brett to confirm the lengths that he sent you.
| Bonaco brake lines installed |
105.69 KB |
7286 Time(s) |
Posted: Mon Feb 22, 2016 11:31 pm Post subject: Bonaco Brake Lines Too Short! |
All good. My error.
Warm regards
Patrick
