jbyak52(at)gmail.com Guest
Posted: Tue Feb 02, 2016 12:03 pm Post subject: Garmin G3X installation |
I’m installing a Garmin G3X in my Yak52TW and trying to located a place to install the magnetometer (GMU22). Has anyone done this installation in a TW or have a suggestion on a location that meets Garmin’s requirements for the magnetometer?
Jimmy Burke
Jbyak52(at)gmail.com
Viperdoc
Posted: Tue Feb 02, 2016 6:35 pm Post subject: Garmin G3X installation |
Try under the turtle deck aft of the rear cockpit. I did that for my Dynon in the 50. Worked fine on headings after slaving the DG. Mount it first with industrial adhesive backed Velcro. That way you can move it if you do not like it.
Doc
Sent from my iPad
On Feb 2, 2016, at 1:58 PM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)> wrote:
| Quote: | <![endif]--> <![endif]-->
Jimmy Burke
Jbyak52(at)gmail.com (Jbyak52(at)gmail.com)
_________________ Viperdoc |
Posted: Wed Feb 03, 2016 8:18 am Post subject: Garmin G3X installation |
Thanks for the response. Area behind the rear seat has the two air tanks which require 8.2 feet separation, the aft fuselage has control cable that require 3 feet clearance plus the rear landing gear assembly. Wing tips are a possibility, but the nav lights and strobes are a problem plus routing the wiring through the wing. Looks like I may be the first to put a G3X in a TW.
Off line response from Sonny Schilleci at Auric Avionics suggests using a Survey Tool to locate a low noise area.
Jimmy
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Roger Kemp
Sent: Tuesday, February 2, 2016 9:32 PM
To: yak-list(at)matronics.com
Subject: Re: Garmin G3X installation
Doc
Sent from my iPad
Jimmy Burke
McFly
Joined: 21 May 2012 Posts: 101 Location: Scottsdale, AZ
Posted: Wed Feb 03, 2016 9:37 am Post subject: Garmin G3X installation |
Use a simple camping compass. Wherever you want to put it out the compass and see if it swings. If not you are golden.
Used this technique for my Yak 50 as suggested by Stein Air during G3X install.
Todd McCutchanT-34A & Yak-50
Cell: (260) 402-1740
E-mail: todd(at)fastaircraft.com (todd(at)fastaircraft.com)
www.fastaircraft.com
On Feb 3, 2016, at 9:14 AM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)> wrote:
Jimmy
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Roger Kemp
Doc
Sent from my iPad
Jimmy Burke
_________________ Todd McCutchan
Fast Aircraft
T-34A - N134FA
KDVT Hangar 33-13
Cell - 260.402.1740
Email: todd@fastaircraft.com
Skype: tmccutchan
Web: www.fastaircraft.com & www.flyams.com |
jbsoar(at)gmail.com Guest
Posted: Fri Feb 05, 2016 10:18 pm Post subject: Garmin G3X installation |
Does anyone have any idea how much voltage is required to fire the starting vibrator? I believe the batteries in the Yak 55M are old, and low in base voltage. It was cool today, and the airplane was difficult to start.
Is there a replacement starting vibrator available? Do the originals from Russia hold up well?
Thank you!
john b
On Wed, Feb 3, 2016 at 9:14 AM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)> wrote:
Jimmy
Doc
Sent from my iPad
Jimmy Burke
Posted: Sat Feb 06, 2016 4:33 am Post subject: Garmin G3X installation |
If the battery voltage drops down to 22 volts or less, the starting coil may not generate an adequate spark.
The starting coil is probably one of the most reliable electrical components on the airplane. The starting coil wire (7mm) from the starting coil to the left magneto cap may be deteriorated and cracked. If the wire is cracked, it will arc to the braided shield (ground) when you press the start button. That would prevent the spark from going to the mag cap and then to the spark plug.
After you replace the batteries, open up the starting coil container and check the points for mounding. If necessary you can burnish the points to remove any mounds with a point file.
Dennis
To: Yak-List Digest Server <yak-list(at)matronics.com>
Sent: Saturday, February 6, 2016 1:14 AM
Thank you!john b
On Wed, Feb 3, 2016 at 9:14 AM, Jim Burke <jbyak52(at)gmail.com (jbyak52(at)gmail.com)> wrote: | Quote: | Thanks for the response. Area behind the rear seat has the two air tanks which require 8.2 feet separation, the aft fuselage has control cable that require 3 feet clearance plus the rear landing gear assembly. Wing tips are a possibility, but the nav lights and strobes are a problem plus routing the wiring through the wing. Looks like I may be the first to put a G3X in a TW.
Jimmy
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Roger KempSent: Tuesday, February 2, 2016 9:32 PMTo: yak-list(at)matronics.com (yak-list(at)matronics.com)Subject: Re: Garmin G3X installation
DocSent from my iPad
| Quote: | I’m installing a Garmin G3X in my Yak52TW and trying to located a place to install the magnetometer (GMU22). Has anyone done this installation in a TW or have a suggestion on a location that meets Garmin’s requirements for the magnetometer?
Jimmy Burke
Ernie
Posted: Sat Feb 06, 2016 4:52 am Post subject: Garmin G3X installation |
These engines are not easy to start in cold weather.
Ernie
On Sat, Feb 6, 2016 at 7:26 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
| Quote: | If the battery voltage drops down to 22 volts or less, the starting coil may not generate an adequate spark.
Dennis
From: John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)>
To: Yak-List Digest Server <yak-list(at)matronics.com (yak-list(at)matronics.com)>
Thank you!john b
Jimmy
Jimmy Burke
Posted: Sat Feb 06, 2016 5:12 am Post subject: Garmin G3X installation |
Absolutely agree and the cold weather just makes it more difficult.
Especially if the battery voltage is low.
Dennis
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 2/6/2016 7:48 AM, Ernest Martinez wrote:
| Quote: | These engines are not easy to start in cold weather.
Ernie
<dsavarese0812(at)bellsouth.net <mailto:dsavarese0812(at)bellsouth.net>> wrote:
Dennis
*From:* John B <jbsoar(at)gmail.com <mailto:jbsoar(at)gmail.com>>
*To:* Yak-List Digest Server <yak-list(at)matronics.com
<mailto:yak-list(at)matronics.com>>
*Sent:* Saturday, February 6, 2016 1:14 AM
*Subject:* Re: Garmin G3X installation
Thank you!
john b
a G3X in a TW.
Jimmy
<mailto:owner-yak-list-server(at)matronics.com>
<mailto:owner-yak-list-server(at)matronics.com>] *On Behalf Of
*Roger Kemp
*Sent:* Tuesday, February 2, 2016 9:32 PM
*To:* yak-list(at)matronics.com <mailto:yak-list(at)matronics.com>
Doc
Sent from my iPad
magnetometer?
Jimmy Burke
Jbyak52(at)gmail.com <mailto:Jbyak52(at)gmail.com>
GeorgeCoy
Posted: Sat Feb 06, 2016 5:30 am Post subject: Garmin G3X installation |
We make a solid-state version that we run any voltage. It was aimed at the homebuilders who want to use a 12 V system
George
Sent from my iPad
| Quote: | On Feb 6, 2016, at 8:09 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> wrote:
Absolutely agree and the cold weather just makes it more difficult. Especially if the battery voltage is low.
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
> Ernie
> On Sat, Feb 6, 2016 at 7:26 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net <mailto:dsavarese0812(at)bellsouth.net>> wrote:
> Dennis
> Thank you!
> john b
> a G3X in a TW.
> Jimmy
> *From:*owner-yak-list-server(at)matronics.com
> *Roger Kemp
> Doc
> Sent from my iPad
> magnetometer?
> Jimmy Burke
g195
Posted: Thu Feb 11, 2016 6:17 am Post subject: Re: Garmin G3X installation |
I installed the Dynon skyview in my TW and I put the magnetometer between the front seat and the rear cockpit instrument panel attached to the bottom of the glare shield for the rear cockpit.
Gary
