tires
Goto page Previous  1, 2
PostPosted: Mon Jan 18, 2016 1:51 pm    Post subject: tires Reply with quote
That looks good.  I don't think you have a slippage problem now, unless you try really hard.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell
Sent: Monday, January 18, 2016 1:49 PM
Subject: tires
Our bitter weather has moved Eastward, so I got the tires fixed today. I put some washers under these screws just as a precaution in case the screw might be a bit long. I have 6 lbs of air in them. I anticipate that they will be a bit better when landing in our outback, as well as not ripping off the valve stems.
Larry
The older I get, the less tolerant I am of those who are intolerant.
lcottrell
PostPosted: Mon Jan 18, 2016 3:17 pm    Post subject: tires Reply with quote
How much air do you think I should have. I now have 6 pounds in them and they don't appear to be too low. Perhaps I should put my fat ass in there to see how much they squat?Larry
On Mon, Jan 18, 2016 at 2:47 PM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
From: owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com) [mailto:owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com)] On Behalf Of Larry Cottrell
Subject: Kolb-List: tires
Larry
rickofudall
PostPosted: Mon Jan 18, 2016 4:14 pm    Post subject: tires Reply with quote
Larry, When I put the Nerf tires on the Mk III I ran 6 to 8 lb. Seems like you're in the ballpark.
Rick
On Mon, Jan 18, 2016 at 5:14 PM, Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)> wrote:
Subject: tires
Larry
“Blessed are the cracked, for they shall let in the light.”   Groucho Marx
PostPosted: Mon Jan 18, 2016 4:17 pm    Post subject: tires Reply with quote
I run 6-8 psi when I am doing "real" flying.  10-15 psi when I will be flying in and out of paved strips.  Higher psi works much better on dry pavement for me.
Sent: Monday, January 18, 2016 5:15 PM
Subject: Re: tires
Larry
Subject: tires
Larry
plheureux
PostPosted: Tue Jan 19, 2016 6:29 am    Post subject: tires Reply with quote
I read somewhere that airplane tires should compress so that the edge of the tread touches the ground when loaded. This relates to airplane tires that have the distinctive simple circumferential treads.
Hope this helps
Pierre
Page 2 of 2
