				 Posted: Sun Dec 27, 2015 3:28 pm    Post subject: Cessna OV protection + DIODE across   ALT side of Master Swi |
				At 07:35 AM 12/26/2015, you wrote:
   	  | Quote: | 	 		  --> AeroElectric-List message posted by: "racerjerry" <gnking2(at)verizon.net>
  Does anyone have any info regarding the internal circuitry of the Cessna over-voltage sensor?   I am wondering if this sensor's internal transistorized circuit contains the equivalent of the removed diode and therefore a separate diode is no longer needed for arc suppression at the ALT side of the master switch.  Hmmm. |
    I proposed a latching ov sensor circuit
    to Cessna about 1970 with a schematic like
    this
   http://tinyurl.com/7g7mn6l
    I never manufactured any and was not involved
    in the qualification so I don't KNOW that
    the drawing cited above exactly matches what
    went into the airplanes  . . . but a technician
    who once worked for Electro-Mech and manufactured
    the device after Hopkins lost the job says it's
    "real close."
    The diode is not included in any of my drawings
    because it is assumed that the REGULATOR already
    has the usual diode from F to ground.
    The diode was part of the original Cessna installations
    because the alternator switch actually controlled the
    field relay inside the electro-mechanical regulators
   http://tinyurl.com/d7ln4mt
    This relay was not fitted with the recommended
    diode. When the electro-mechanical regulators
    were replaced with solid state . . . the diode
    became part of the regulator and no longer
    necessary at the switch.
		racerjerry
  Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
				 Posted: Mon Dec 28, 2015 6:10 pm    Post subject: Re: Cessna OV protection + DIODE across   ALT side of Master |
				Thank you very much, Bob.  That was precisely the info that I needed.
  _________________ Jerry King |
